SFP-10G-LR-S vs SFP-10G-LR
Manu MP
What is the mail difference between SFP-10G-LR-S and  SFP-10G-LR. I have tried to collect information from datasheet and other forums. But no details got.
balaji.bandi
C and S Class :
10 Gbps S-class vs. C-class.
For UA to core campus applications, S-class are quite suitable.
C-Class
S-Class
Multi-rate vs Single-rate
Multi-rate optics:
  • Ethernet
  • OTN
  • WAN-PHY
Single-rate optics:
  • Ethernet only
Operating temperature range
  • Commercial (0C to 70C)
  • Extended (-5C to 85C)
  • Industrial (-40C to 85C)
  • Commercial (0C to 70C) only
good compare here from FS- same applies most of the SFP.
https://medium.com/@cadyzhang/sfp-10g-lr-s-vs-sfp-10g-lr-whats-the-difference-7ad9e3036b6
BB
marce1000
 - FYI : https://medium.com/@cadyzhang/sfp-10g-lr-s-vs-sfp-10g-lr-whats-the-difference-7ad9e3036b6#:~:text=Temperature%20Range,than%20SFP%2D10G%2DLR.
 M.
Hi Manu,
The main difference between the two Cisco SFPs is that SFP-10G-LR supports FCoE, whereas SFP-10G-LR-S does not support FCoE.
This is why the variant 10G-LR and 10G-LR-S have a slight difference in prices.
Which means that if you have an interconnectivity between the two distant sites and you need to pass the FCoE traffic, you must consider SFP-10G-LR
This will also be helpful for you in planning the relevant BoQ.
Please mark all the helpful responses
