SFP channel
M.Sultan
What does the term ''channel'' mean with SFP+ mean?  channelling them like ether channel?
just to give an idea, SFP+ plus gives 40G with in single channel.
6 Replies 6
balaji.bandi
this is mux channels
BB
M.Sultan
what does mux mean?
have you come across anytime - google.com
BB
anyway i didn't get my answer.
Marvin Rhoads
Some SFP+ transceivers use multiplexing (shorthand term = "mux"). The mux technique takes multiple channels (sometimes referred to as "lanes") running at a lower bit rate and combines them on a given pair of fibers to achieve a higher effective throughput. for instance. 100 Gbps is often comprised of four separate 25 Gbps lanes.
Reference: https://en.wikipedia.org/wiki/Multiplexing
Joseph W. Doherty
You're asking about "ordinary" optical transceivers, not CWDM/DWDM transceivers?  (I ask because channels also is used with the latter.)  I believe SFP+ is the transceiver's port module format, the plus being a SFP port that supports gig or 10g SFP transceivers.
It's also possible you're asking about QSFP+ 40g transceiver which supports 4 channels of 10g or 1 channel of 40g.
