10-10-2020 09:10 AM
My provider is delivering internet over a 10Gb SM fiber to my Cisco ISR 4331 which has a 1Gb SFP. The ISP policed the ckt at 1Gb. Can I accept it on my 1Gb SFP?
10-10-2020 10:41 AM
Sure if you do not have an option, the other side auto-negotiate with your port. make sure you use right SFP optic.
10-10-2020 11:17 AM
I don't believe so.
A SFP+ port will work with gig or 10g optical transceiver, but believe the transceivers need to match on both ends of the fiber link.
10-10-2020 04:42 PM
Not going to work. Both optical modules must be of the same speed and the same wavelength.
If the ISP is presenting SFP-10G-LR then the customer end must "match" the optics with the same type and wavelength.
10-11-2020 10:11 AM
What if the provider replaced their SFP+ with a SFP? We ordered a 1Gb ckt with the ability to upgrade to 2Gb, so it was delivered via a 10Gb ckt on which they police us to the bandwidth we pay for. But if they could replace their SFP to match our own then it should come up as a 1Gb ckt, correct?
10-12-2020 09:22 AM
Yes, correct.
10-11-2020 10:39 AM
Although both ends should have same modules, but I think if you use SFP optics it would work since SFP+ ports are compatible with those.
