2811 Router will not Register to CallManager MGCP
NPT_2
Level 2
Level 2
Has anyone had any luck getting a 2811 router to register via MGCP to Callmanager. I am running 4.12 ES03 callmanager and the latest 12.3(11)T2 code on the 2811. The router never completes registration and debugs for errors on ccm and mgcp show the following:
Dec 21 23:47:59.618: cmapp_mgr_process_ev_active_host_failed: Active host 0
(17
2.16.1.20) failed
*Dec 21 23:47:59.618: mgcp_endpt_get_call_record: null pointer specified for
end
point.
*Dec 21 23:48:29.618: cmapp_mgr_process_ev_active_host_failed: Active host 1
(17
2.16.1.15) failed
*Dec 21 23:48:29.618: cmapp_mgcpapp_go_down: Setting mgc status to
NO_RESPONSE
*Dec 21 23:48:29.618: mgcp_endpt_get_call_record: null pointer specified for
end
point.
also in the callmanager even logs I get the following:
Error: DeviceTransientConnection - Transient connection attempt.
This occurs over and over again. I have a TAC case open but they have yet to come up with a solution. Any thoughts? All my other routers are registering fine with MGCP.
Erick Bergquist
Level 6
Level 6
Does the DOMAIN Name in Call manager for this gateway match the routers domain name exactly?
In the event log, the domain name being sent from router should be in the error.
Can you post the CCM MGCP domain name, as well as the router host and domain name configuration?
The router will combine the host and domain name to get the domainname it sends to ccm for registration.
Router config:
hostname AVVID_RTR
ip domain name avvid-rocks.com
MGCP domain name sent: AVVID_RTR.avvid-rocks.com
Only way to see this is with 'debug mgcp packet'
2w1d: send_mgcp_msg, MGCP Packet sent --->
2w1d: RSIP 1 aaln/S1/SU0/0@AVVID_RTR.avvid-rocks.com MGCP 0.1
RM: restart
Router config:
hostname AVVID_RTR
(no IP Domain name configured)
You are right, it turns out I was not using the dns name in my callmanager gateway config, but I did have it configured on the router with a ip domian name command. Once I added the domain to the config everything is working fine.
g-pate
I am running CCM 4.0(2a)sr1, and I do have a 2811 registered using MGCP. Here are the things in the router pertinent to MGCP. I hope this helps.
network-clock-participate wic 0
isdn switch-type primary-ni
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.2.100.201
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.1.100.201
ccm-manager config
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface Serial0/0/0:23
no ip address
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
call application alternate default
voice-port 0/0/0:23
voice-port 0/1/0
voice-port 0/1/1
mgcp
mgcp call-agent 10.1.100.201 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/1
mgcp bind media source-interface FastEthernet0/1
mgcp profile default
dial-peer voice 1 pots
application mgcpapp
dial-peer voice 2 pots
application mgcpapp
