11-30-2005 02:37 PM - edited 03-15-2019 03:54 AM
hello,
I have the follwing sceanario:
callManager(10.0.0.2)--|switch---Router1--------Router2-FXS------|analog phone(800)
IP phone(110)----------|
router1
dial-peer voice 1 voip
destination-pattern 8..
session target ipv4:192.168.0.1
dial-peer voice 2 voip
destination-pattern ...
session target ipv4:10.0.0.2
router2
dial-peer voice 1 pots
destination-pattern 800
port 1/0/1
session target ipv4:10.0.0.1
it's not working :-(
thanks in advanced,
Hugo
Solved! Go to Solution.
11-30-2005 03:00 PM
hugo,
you are trying to route calls from callmanager to a h323-gateway and from this to an other h-323 gateway.
you cant make this working:))
1. create a h323-gateway in ccm with the ip address of the router2
2. create a route-pattern (number 800) which is pointing to router2
3. router 2 config:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
dial-peer voice 100 voip
destination-pattern [^8..]
session-target ipv4:10.0.0.2
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 800 pots
port 1/0/1
i assume the router 1 hasnt any voice interfaces?
greetings
mehmet
11-30-2005 03:00 PM
hugo,
3. router 2 config:
voice class codec 1
voice-class codec 1
no vad
port 1/0/1
greetings
mehmet
12-07-2005 06:36 AM
thank you very much, it's working now,
Hugo
