ATA 186 with fax and anlog phone
zcody
I am using ATA 186 in H.323 mode with CME. I have a fax connected to L1 and I am planning to connect an analog phone to L2. Can both ( fax and phone) devices work simultaneously on the same ATA?
azam_anwar
Level 2
Level 2
As per the admin guide:
The Cisco ATA supports two independent
RJ-11 telephone ports that can connect to any standard analog telephone device. Each port supports
either voice calls or fax sessions, and both ports can be used simultaneously.
