05-22-2003 04:38 AM - edited 03-12-2019 11:59 PM
This has been asked before but no answer was given. I am running console attendant 1.1(2a) and the user "ac" has all the speed dials set up. Is there a way of exporting/importing to other users. I can't find where these are stored.
Also i do not seem to have the option for sending a caller straight to a subscribers voicemail. What version of Attendant Console has this feature?
Ben
05-28-2003 06:57 AM
I heard that the AC speed dials are usually stored in the DC directory. You may want to check that.
05-28-2003 08:05 AM
Here is a little script you can run from the command line (dos window) on the call manager:
show -f sd.txt db t SpeedDial
this command is case sinsitive.
this will export your speeddials to the sd.txt file
Todd
