You can use a AS53XX, 26XX, or 36XX and the IOS IVR in conjunction with AAA to perform this function.
The CCM will set up the call to the AS53XX and the IOS IVR will prompt them to enter an access code. It then verifies the access code against AAA. A search under CCO for IOS IVR should answer your questions.
