01-14-2005 10:20 AM - edited 03-13-2019 07:39 AM
We need to have Blind/Handicap visitors access the building. They need to press an intercom button and have that ring on an extension inside at the secretarys desk so she can pick up the call and talk to them. We want to know if we can program another button on the phone that can be wired to an external switch to open the contacts on our security door ?
What other devices do we need to purchase to complete this task..... Pls Help
Solved! Go to Solution.
01-15-2005 12:42 PM
Check out this Valcom unit:
http://www.valcom.com/v2901a.htm
You would connect to a FXO port on a router set as a PLAR to the phone you want to ring. To unlock the door you enter a code from the phone keypad.
I have had good luck with Valcom products.
01-15-2005 12:42 PM
01-25-2005 07:46 AM
Thank you so much. I suggested this to the client and they went for it and its working great !
01-26-2005 07:46 AM
Cool! Thanks for the feedback/rating.
