block a call
mymite060708
I have a customer that wants to block a certain number calling a certain extension. eg
Calling Number = 01244 381551
Called Number = 345678
any suggestions on the best way to do this?
Chris Deren
I am assuming you have CallManager, if so if your gateway is H.323 GW then you can use reject translation rules on the GW, if you use MGCP then there is nothibg you can do.
Here are some sample configurations
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
Please rate all helpful posts!
Chris
jbarcena
Level 9
Level 9
cderen is correct, CCM does not have the ability to block calls per calling number, you can only do this with H.323. Take a look to this document:
TAC CASE COLLECTION - How to block incoming calls based on calling number and called number information with a Cisco IOS H.323 gateway
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K15182736
One method of doing this is to send all calls to unity first (for this number) then you can use a routing rule based on calling number and use a CH to send the call some where else (like a blocked message)
