Block Specific Incoming Calls
jimmy.c
I want to block specific incoming calls that have caller ID's. We are running Unity 2.4.6.102 for the auto attendant and using CCM 3.0(9). Is there a way to send certain callers to a busy or disconnect tone. We have a terminated employee who keeps calling from his house and routing to a specific extension by using the dial by name feature on Unity. Any insights would be helpful.
Thanks!
tim.medley
Level 2
Level 2
What type of gateways are you using for PSTN connectivity?
If you are using H323 gateways, you could create a translation rule on the gateway to block these inbound calls. I think there's a way to do this with MGCP, but I'm not fully versed in MGCP.
Tim Medley - CCNP+Voice, CCDP
Sr. Network Architect
VoIP Group
iReadyWorld
Any general examples, or for VG200 running 12.2(4.2a)??
