Caller ID on VG200 with FXO-M1 H.323 Gateway
Jake Pratt
I am running CUCM 7.1.3, and I have one H.323 gateway (a VG200), which uses 2 FXO-M1 (2-port) cards to terminate local analog lines.  This particular gateway will not pass caller ID.  My other gateways, which use a PRI voice T1 work fine with caller ID.  It's been a long time since we hooked this up, but I seem to remember the CCIE that hooked it up saying that it is a limitation of either the card, or the VG200.  I don't remember.
Anyway, I'm trying to figure out if I can get this caller ID enabled on this gateway, or perhaps upgrade the componant that is not supported.
Here is one of my voice ports:
voice-port 1/0/0
connection plar opx 2501
caller-id enable
And the dial-peer for that port:
dial-peer voice 5 pots
preference 3
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
port 1/0/0
If anyone has any information or ideas on this, I would greatly appreciate it.  Please let me know if you need additional information from my gateway, call manager, or debug info on the calls.
You need to ask telco to give you CLID service, then test it with a regular display phone.
Jake Pratt
I have looked at a few other articles, and it seems that these cards won't pass caller ID with an MGCP gateway, but they should with an H.323, is that right?  I just pulled some "debug voip ccapi inout" stats while I made an inbound call, and it looks like I'm not getting caller ID at the gateway.  Here is the debug output.
*Mar 29 16:20:07.537: cc_handle_periodic_timer: Calling the callback, ccTimerctx - 0x80DE44B8
*Mar 29 16:20:07.537: ccTimerStart: ccTimerctx - 0x80DE44B8
*Mar 29 09:20:24: %VTSP-4-FSM_BAD_EVENT: Invalid FSM Input on channel UNKNOWN: state=-1 event=-2145953604
*Mar 29 16:20:24.473: cc_api_call_setup_ind (vdbPtr=0x810E7784, callInfo={called=2501,called_oct3=0x81,calling=,calling_oct3=0x0,calling_oct3a=0x0,calling_xlated=false,subscriber_type_str=RegularLine,fdest=1,peer_tag=5, prog_ind=3,callingIE_present 0},callID=0x8126BD20)
*Mar 29 16:20:24.473: cc_api_call_setup_ind calling number is null, answer addr  dest pattern 9T e164_ans_addr 0 e164_dest_pattern 0
*Mar 29 16:20:24.473: cc_api_call_setup_ind type 2 , prot 0
*Mar 29 16:20:24.477: cc_process_call_setup_ind (event=0x810BDF4C)
*Mar 29 16:20:24.477: >>>>CCAPI handed cid 1817 with tag 5 to app "DEFAULT"
*Mar 29 16:20:24.477: sess_appl: ev(24=CC_EV_CALL_SETUP_IND), cid(1817), disp(0)
*Mar 29 16:20:24.477: sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(1817), disp(0)
*Mar 29 16:20:24.477: ssaCallSetupInd
*Mar 29 16:20:24.477: ccCallSetContext (callID=0x719, context=0x8126EE58)
*Mar 29 16:20:24.481: ssaCallSetupInd cid(1817), st(SSA_CS_MAPPING),oldst(0), ev(24)ev->e.evCallSetupInd.nCallInfo.finalDestFlag = 1
*Mar 29 16:20:24.481: ssaCallSetupInd finalDest cllng(), clled(2501)
*Mar 29 16:20:24.481: ssaCallSetupInd cid(1817), st(SSA_CS_CALL_SETTING),oldst(0), ev(24)dpMatchPeersMoreArg result= 0
*Mar 29 16:20:24.481: ssaSetupPeer cid(1817) peer list:  tag(100) called number (2501)  tag(101) called number (2501)
*Mar 29 16:20:24.481: ssaSetupPeer cid(1817), destPat(2501), matched(0), prefix(), peer(81099ACC), peer->encapType (2)
*Mar 29 16:20:24.481: ccCallProceeding (callID=0x719, prog_ind=0x0)
*Mar 29 16:20:24.481: ccCallSetupRequest (Inbound call = 0x719, outbound peer =100, dest=, params=0x810C82C8 mode=0, *callID=0x810C8638, prog_ind = 3) callingIE_present 0
*Mar 29 16:20:24.485: ccCallSetupRequest numbering_type 0x81
*Mar 29 16:20:24.485: ccCallSetupRequest encapType 2 clid_restrict_disable 1 null_orig_clg 1 clid_transparent 0 callingNumber
*Mar 29 16:20:24.485: dest pattern .T, called 2501, digit_strip 0
*Mar 29 16:20:24.485: callingNumber=, calledNumber=2501, redirectNumber= display_info= calling_oct3a=0
*Mar 29 16:20:24.485: accountNumber=, finalDestFlag=1,
guid=217b.c7a2.2b78.11cc.860c.ad7c.6266.e7f6
*Mar 29 16:20:24.485: peer_tag=100
*Mar 29 16:20:24.485: ccIFCallSetupRequestPrivate: (vdbPtr=0x81041FE8, dest=, callParams={called=2501,called_oct3=0x81, calling=,calling_oct3=0x0, calling_xlated=false,  subscriber_type_str=RegularLine, fdest=1, voice_peer_tag=100},mode=0x0) vdbPtr type = 1
*Mar 29 16:20:24.485: ccIFCallSetupRequestPrivate: (vdbPtr=0x81041FE8, dest=, callParams={called=2501, called_oct3 0x81,  calling=,calling_oct3 0x0, calling_xlated=false,  fdest=1, voice_peer_tag=100}, mode=0x0, xltrc=-5)
*Mar 29 16:20:24.489: ccSaveDialpeerTag (callID=0x719, dialpeer_tag=0x64)
*Mar 29 16:20:24.489: ccCallSetContext (callID=0x71A, context=0x8125B638)
*Mar 29 16:20:24.489: ccCallReportDigits (callID=0x719, enable=0x0)
*Mar 29 16:20:24.489: cc_api_call_report_digits_done (vdbPtr=0x810E7784, callID=0x719, disp=0)
*Mar 29 16:20:24.489: sess_appl: ev(53=CC_EV_CALL_REPORT_DIGITS_DONE), cid(1817), disp(0)
*Mar 29 16:20:24.489: cid(1817)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_REPORT_DIGITS_DONE)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(1)fDest(1)
*Mar 29 16:20:24.489: -cid2(1818)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
*Mar 29 16:20:24.489: ssaReportDigitsDone cid(1817) peer list:  tag(101) called number (2501)
*Mar 29 16:20:24.493: ssaReportDigitsDone callid=1817 Reporting disabled.
*Mar 29 16:20:24.633: cc_api_call_proceeding(vdbPtr=0x81041FE8, callID=0x71A,
      prog_ind=0x0)
*Mar 29 16:20:24.633: sess_appl: ev(21=CC_EV_CALL_PROCEEDING), cid(1818), disp(0)
*Mar 29 16:20:24.633: cid(1818)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(0)fDest(0)
*Mar 29 16:20:24.637: -cid2(1817)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
*Mar 29 16:20:24.637: ssaCallProc
*Mar 29 16:20:24.637: ccGetDialpeerTag (callID=0x719)
*Mar 29 16:20:24.637: ssaIgnore cid(1818), st(SSA_CS_CALL_SETTING),oldst(1), ev(21)
*Mar 29 16:20:24.641: cc_api_call_alert(vdbPtr=0x81041FE8, callID=0x71A, prog_ind=0x0, sig_ind=0x1)
*Mar 29 16:20:24.641: sess_appl: ev(7=CC_EV_CALL_ALERT), cid(1818), disp(0)
*Mar 29 16:20:24.641: cid(1818)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_ALERT)
oldst(SSA_CS_CALL_SETTING)cfid(-1)csize(0)in(0)fDest(0)
*Mar 29 16:20:24.641: -cid2(1817)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
*Mar 29 16:20:24.641: ssaAlert
*Mar 29 16:20:24.641: ccGetDialpeerTag (callID=0x719)
*Mar 29 16:20:24.641: ccCallAlert (callID=0x719, prog_ind=0x0, sig_ind=0x1)
*Mar 29 16:20:24.889: cc_api_call_notify(vdbPtr=0x81041FE8, callID=0x71A
*Mar 29 16:20:24.889: sess_appl: ev(20=CC_EV_CALL_NOTIFY), cid(1818), disp(0)
*Mar 29 16:20:24.889: cid(1818)st(SSA_CS_ALERT_RCVD)ev(SSA_EV_CALL_NOTIFY)
*Mar 29 16:20:24.889: -cid2(1817)st2(SSA_CS_ALERT_RCVD)oldst2(SSA_CS_CALL_SETTING)
*Mar 29 16:20:24.889: ssaNotify
*Mar 29 16:20:24.893: ccCallNotify (callID=0x719)
*Mar 29 16:20:27.789: cc_api_call_notify(vdbPtr=0x81041FE8, callID=0x71A
*Mar 29 16:20:27.789: sess_appl: ev(20=CC_EV_CALL_NOTIFY), cid(1818), disp(0)
*Mar 29 16:20:27.789: cid(1818)st(SSA_CS_ALERT_RCVD)ev(SSA_EV_CALL_NOTIFY)
oldst(SSA_CS_ALERT_RCVD)cfid(-1)csize(0)in(0)fDest(0)
*Mar 29 16:20:27.789: -cid2(1817)st2(SSA_CS_ALERT_RCVD)oldst2(SSA_CS_CALL_SETTING)
*Mar 29 16:20:27.789: ssaNotify
*Mar 29 16:20:27.793: ccCallNotify (callID=0x719)
*Mar 29 16:20:28.149: cc_api_call_connected(vdbPtr=0x81041FE8, callID=0x71A), prog_ind = 0cc_api_call_connected: setting callEntry->connected to TRUE
*Mar 29 16:20:28.153: sess_appl: ev(8=CC_EV_CALL_CONNECTED), cid(1818), disp(0)
*Mar 29 16:20:28.153: cid(1818)st(SSA_CS_ALERT_RCVD)ev(SSA_EV_CALL_CONNECTED)
*Mar 29 16:20:28.153: -cid2(1817)st2(SSA_CS_ALERT_RCVD)oldst2(SSA_CS_CALL_SETTING)
*Mar 29 16:20:28.153: ssaConnect
*Mar 29 16:20:28.153: ccGetDialpeerTag (callID=0x719)
*Mar 29 16:20:28.153: ccConferenceCreate (confID=0x810C869C, callID1=0x719, callID2=0x71A, tag=0x0)
*Mar 29 16:20:28.157: cc_api_bridge_done (confID=0x37C, srcIF=0x81041FE8, srcCallID=0x71A, dstCallID=0x719, disposition=0, tag=0x0)
*Mar 29 16:20:28.157: cc_api_bridge_done (confID=0x37C, srcIF=0x810E7784, srcCallID=0x719, dstCallID=0x71A, disposition=0, tag=0x0)
*Mar 29 16:20:28.157: cc_api_caps_ind (dstVdbPtr=0x81041FE8, dstCallId=0x71A, srcCallId=0x719,
     caps={codec=0x2EBFB, fax_rate=0x7F, vad=0x3, modem=0x2
           codec_bytes=0, signal_type=3})
*Mar 29 16:20:28.157: cc_api_caps_ind (Playout: mode 0, initial 60,min 40, max 200)
*Mar 29 16:20:28.157: cc_api_caps_ind (dstVdbPtr=0x810E7784, dstCallId=0x719, srcCallId=0x71A,
     caps={codec=0x1, fax_rate=0x2, vad=0x1, modem=0x0
           codec_bytes=160, signal_type=1})
*Mar 29 16:20:28.161: cc_api_caps_ack (dstVdbPtr=0x810E7784, dstCallId=0x719, srcCallId=0x71A,
           codec_bytes=160, signal_type=1, seq_num_start=3415})
*Mar 29 16:20:28.161: cc_api_caps_ack (dstVdbPtr=0x81041FE8, dstCallId=0x71A, srcCallId=0x719,
*Mar 29 16:20:28.161: cc_api_voice_mode_event , callID=0x719
*Mar 29 16:20:28.161: Call Pointer =8126EE58
*Mar 29 16:20:28.161: sess_appl: ev(29=CC_EV_CONF_CREATE_DONE), cid(1817), disp(0)
*Mar 29 16:20:28.165: cid(1817)st(SSA_CS_CONFERENCING)ev(SSA_EV_CONF_CREATE_DONE)
oldst(SSA_CS_CALL_SETTING)cfid(892)csize(2)in(1)fDest(1)
*Mar 29 16:20:28.165: -cid2(1818)st2(SSA_CS_CONFERENCING)oldst2(SSA_CS_ALERT_RCVD)
*Mar 29 16:20:28.165: ssaConfCreateDone
*Mar 29 16:20:28.165: ccCallConnect (callID=0x719), prog_ind = 0ccCallConnect: setting callEntry->connected to TRUE
*Mar 29 16:20:28.165: ssaFlushPeerTagQueue cid(1817) peer list:  tag(101) called number (2501)
*Mar 29 16:20:28.165: sess_appl: ev(51=CC_EV_VOICE_MODE_DONE), cid(1817), disp(0)
*Mar 29 16:20:28.165: cid(1817)st(SSA_CS_ACTIVE)ev(SSA_EV_VOICE_MODE_DONE)
oldst(SSA_CS_CONFERENCING)cfid(892)csize(2)in(1)fDest(1)
*Mar 29 16:20:28.165: -cid2(1818)st2(SSA_CS_ACTIVE)oldst2(SSA_CS_ALERT_RCVD)
*Mar 29 16:20:28.169: ssaIgnore cid(1817), st(SSA_CS_ACTIVE),oldst(5), ev(51)
*Mar 29 16:20:28.169: cc_process_notify_bridge_done (event=0x810C15C8)
*Mar 29 16:20:28.921: cc_api_call_disconnected(vdbPtr=0x810E7784, callID=0x719, cause=0x10)
*Mar 29 16:20:28.921: sess_appl: ev(11=CC_EV_CALL_DISCONNECTED), cid(1817), disp(0)
*Mar 29 16:20:28.921: cid(1817)st(SSA_CS_ACTIVE)ev(SSA_EV_CALL_DISCONNECTED)
oldst(SSA_CS_ACTIVE)cfid(892)csize(2)in(1)fDest(1)
*Mar 29 16:20:28.921: -cid2(1818)st2(SSA_CS_ACTIVE)oldst2(SSA_CS_ALERT_RCVD)
*Mar 29 16:20:28.921: ssa: Disconnected cid(1817) state(5) cause(0x10)
*Mar 29 16:20:28.921: ccConferenceDestroy (confID=0x37C, tag=0x0)
*Mar 29 16:20:28.925: cc_api_bridge_drop_done (confID=0x37C, srcIF=0x81041FE8, srcCallID=0x71A, dstCallID=0x719, disposition=0 tag=0x0)
*Mar 29 16:20:28.925: cc_api_bridge_drop_done (confID=0x37C, srcIF=0x810E7784, srcCallID=0x719, dstCallID=0x71A, disposition=0 tag=0x0)
*Mar 29 16:20:28.925: sess_appl: ev(30=CC_EV_CONF_DESTROY_DONE), cid(1817), disp(0)
*Mar 29 16:20:28.925: cid(1817)st(SSA_CS_CONF_DESTROYING)ev(SSA_EV_CONF_DESTROY_DONE)
oldst(SSA_CS_ACTIVE)cfid(-1)csize(2)in(1)fDest(1)
*Mar 29 16:20:28.925: -cid2(1818)st2(SSA_CS_CONF_DESTROYING)oldst2(SSA_CS_ALERT_RCVD)
*Mar 29 16:20:28.925: ssaConfDestroyDone
*Mar 29 16:20:28.925: ccCallDisconnect (callID=0x719, cause=0x10 tag=0x0)
*Mar 29 16:20:28.925:  ccCallDisconnect: existing_cause = 0x0, new_cause = 0x10
*Mar 29 16:20:28.929: ccCallDisconnect (callID=0x71A, cause=0x10 tag=0x0)
*Mar 29 16:20:28.929:  ccCallDisconnect: existing_cause = 0x0, new_cause = 0x10
*Mar 29 16:20:28.937: cc_api_call_disconnect_done(vdbPtr=0x810E7784, callID=0x719, disp=0, tag=0x0)
*Mar 29 16:20:28.937: sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(1817), disp(0)
*Mar 29 16:20:28.937: cid(1817)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_CONF_DESTROYING)cfid(-1)csize(2)in(1)fDest(1)
*Mar 29 16:20:28.937: -cid2(1818)st2(SSA_CS_DISCONNECTING)oldst2(SSA_CS_ALERT_RCVD)
*Mar 29 16:20:28.941: ssaDisconnectDone
*Mar 29 16:20:29.133: cc_api_icpif: expect factor = 0
*Mar 29 16:20:29.137: cc_api_call_disconnect_done(vdbPtr=0x81041FE8, callID=0x71A, disp=0, tag=0x0)
*Mar 29 16:20:29.137: sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(1818), disp(0)
*Mar 29 16:20:29.137: cid(1818)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_ALERT_RCVD)cfid(-1)csize(1)in(0)fDest(0)
*Mar 29 16:20:29.137: ssaDisconnectDone
Perhaps, I don't have the service on the lines, or perhaps it's in the way the VG200 is configured.  Here is my "sanitized" VG200 config.  Does it look like I'm missing something?  Or do I just need to verify that I have caller ID service on my lines?
version 12.2
no service pad
service timestamps log datetime localtime
service password-encryption
hostname STGeorge-VG200
logging buffered 4096 debugging
enable secret 5 $1$tIqo$/Z/vge98mUOWXcoJ8m5vJ.
clock timezone MST -7
clock summer-time MST recurring
ip subnet-zero
no ip domain-lookup
call rsvp-sync
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
interface FastEthernet0/0
ip address 10.1.112.3 255.255.255.0
speed 100
full-duplex
h323-gateway voip bind srcaddr 10.1.112.3
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.112.1
no ip http server
ip pim bidir-enable
logging trap debugging
logging ******
snmp-server community ******* RO
snmp-server enable traps tty
voice-port 1/0/0
description ****
caller-id enable
voice-port 1/0/1
description ****
caller-id enable
voice-port 1/1/0
description ****
caller-id enable
voice-port 1/1/1
description ****
caller-id enable
preference 3
port 1/0/0
dial-peer voice 6 pots
preference 2
port 1/0/1
dial-peer voice 7 pots
preference 1
port 1/1/0
dial-peer voice 8 pots
port 1/1/1
dial-peer voice 100 voip
destination-pattern .T
voice-class codec 1
voice-class h323 1
session target ipv4:10.1.1.21
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 101 voip
preference 1
voice-class codec 1
voice-class h323 1
session target ipv4:10.1.1.20
no vad
line con 0
line aux 0
line vty 0 4
privilege level 15
password ******
login
end
Pablo, you were correct.  I contacted the telco, and discovered that we did not have caller ID service on those FXO lines.  I had them add the service, then about a week later, when the service was activated, caller ID started displaying on the phones.  I did another debug on the VG200 to verify what was coming through, and the number and name of the calling party is now showing up in the debug.  So, it looks like my configuration DID support it, I just didn't have the service.  I swear I remember my CCIE Voice guy tell me it wasn't supported.  But, oh well.  It works now, so that's all I care about.  Thanks again for your help!
He was probably referring to MGCP, but with H.323 all is good.
Thank you for the nice rating and good luck!
