Caller ID on VG200 with FXO-M1 H.323 Gateway
Jake Pratt
Beginner
Beginner
I am running CUCM 7.1.3, and I have one H.323 gateway (a VG200), which uses 2 FXO-M1 (2-port) cards to terminate local analog lines.  This particular gateway will not pass caller ID.  My other gateways, which use a PRI voice T1 work fine with caller ID.  It's been a long time since we hooked this up, but I seem to remember the CCIE that hooked it up saying that it is a limitation of either the card, or the VG200.  I don't remember.
Anyway, I'm trying to figure out if I can get this caller ID enabled on this gateway, or perhaps upgrade the componant that is not supported.
Here is one of my voice ports:
voice-port 1/0/0
connection plar opx 2501
caller-id enable
And the dial-peer for that port:
dial-peer voice 5 pots
preference 3
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
port 1/0/0
If anyone has any information or ideas on this, I would greatly appreciate it.  Please let me know if you need additional information from my gateway, call manager, or debug info on the calls.
You need to ask telco to give you CLID service, then test it with a regular display phone.
Jake Pratt
Beginner
Beginner
I have looked at a few other articles, and it seems that these cards won't pass caller ID with an MGCP gateway, but they should with an H.323, is that right?  I just pulled some "debug voip ccapi inout" stats while I made an inbound call, and it looks like I'm not getting caller ID at the gateway.  Here is the debug output.
*Mar 29 16:20:07.537: cc_handle_periodic_timer: Calling the callback, ccTimerctx - 0x80DE44B8
*Mar 29 16:20:07.537: ccTimerStart: ccTimerctx - 0x80DE44B8
*Mar 29 09:20:24: %VTSP-4-FSM_BAD_EVENT: Invalid FSM Input on channel UNKNOWN: state=-1 event=-2145953604
*Mar 29 16:20:24.473: cc_api_call_setup_ind (vdbPtr=0x810E7784, callInfo={called=2501,called_oct3=0x81,calling=,calling_oct3=0x0,calling_oct3a=0x0,calling_xlated=false,subscriber_type_str=RegularLine,fdest=1,peer_tag=5, prog_ind=3,callingIE_present 0},callID=0x8126BD20)
*Mar 29 16:20:24.473: cc_api_call_setup_ind calling number is null, answer addr  dest pattern 9T e164_ans_addr 0 e164_dest_pattern 0
*Mar 29 16:20:24.473: cc_api_call_setup_ind type 2 , prot 0
*Mar 29 16:20:24.477: cc_process_call_setup_ind (event=0x810BDF4C)
*Mar 29 16:20:24.477: >>>>CCAPI handed cid 1817 with tag 5 to app "DEFAULT"
*Mar 29 16:20:24.477: sess_appl: ev(24=CC_EV_CALL_SETUP_IND), cid(1817), disp(0)
*Mar 29 16:20:24.477: sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(1817), disp(0)
*Mar 29 16:20:24.477: ssaCallSetupInd
*Mar 29 16:20:24.477: ccCallSetContext (callID=0x719, context=0x8126EE58)
*Mar 29 16:20:24.481: ssaCallSetupInd cid(1817), st(SSA_CS_MAPPING),oldst(0), ev(24)ev->e.evCallSetupInd.nCallInfo.finalDestFlag = 1
*Mar 29 16:20:24.481: ssaCallSetupInd finalDest cllng(), clled(2501)
*Mar 29 16:20:24.481: ssaCallSetupInd cid(1817), st(SSA_CS_CALL_SETTING),oldst(0), ev(24)dpMatchPeersMoreArg result= 0
*Mar 29 16:20:24.481: ssaSetupPeer cid(1817) peer list:  tag(100) called number (2501)  tag(101) called number (2501)
*Mar 29 16:20:24.481: ssaSetupPeer cid(1817), destPat(2501), matched(0), prefix(), peer(81099ACC), peer->encapType (2)
*Mar 29 16:20:24.481: ccCallProceeding (callID=0x719, prog_ind=0x0)
*Mar 29 16:20:24.481: ccCallSetupRequest (Inbound call = 0x719, outbound peer =100, dest=, params=0x810C82C8 mode=0, *callID=0x810C8638, prog_ind = 3) callingIE_present 0
*Mar 29 16:20:24.485: ccCallSetupRequest numbering_type 0x81
*Mar 29 16:20:24.485: ccCallSetupRequest encapType 2 clid_restrict_disable 1 null_orig_clg 1 clid_transparent 0 callingNumber
*Mar 29 16:20:24.485: dest pattern .T, called 2501, digit_strip 0
*Mar 29 16:20:24.485: callingNumber=, calledNumber=2501, redirectNumber= display_info= calling_oct3a=0
*Mar 29 16:20:24.485: accountNumber=, finalDestFlag=1,
guid=217b.c7a2.2b78.11cc.860c.ad7c.6266.e7f6
*Mar 29 16:20:24.485: peer_tag=100
*Mar 29 16:20:24.485: ccIFCallSetupRequestPrivate: (vdbPtr=0x81041FE8, dest=, callParams={called=2501,called_oct3=0x81, calling=,calling_oct3=0x0, calling_xlated=false,  subscriber_type_str=RegularLine, fdest=1, voice_peer_tag=100},mode=0x0) vdbPtr type = 1
*Mar 29 16:20:24.485: ccIFCallSetupRequestPrivate: (vdbPtr=0x81041FE8, dest=, callParams={called=2501, called_oct3 0x81,  calling=,calling_oct3 0x0, calling_xlated=false,  fdest=1, voice_peer_tag=100}, mode=0x0, xltrc=-5)
*Mar 29 16:20:24.489: ccSaveDialpeerTag (callID=0x719, dialpeer_tag=0x64)
*Mar 29 16:20:24.489: ccCallSetContext (callID=0x71A, context=0x8125B638)
*Mar 29 16:20:24.489: ccCallReportDigits (callID=0x719, enable=0x0)
*Mar 29 16:20:24.489: cc_api_call_report_digits_done (vdbPtr=0x810E7784, callID=0x719, disp=0)
*Mar 29 16:20:24.489: sess_appl: ev(53=CC_EV_CALL_REPORT_DIGITS_DONE), cid(1817), disp(0)
*Mar 29 16:20:24.489: cid(1817)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_REPORT_DIGITS_DONE)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(1)fDest(1)
*Mar 29 16:20:24.489: -cid2(1818)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
*Mar 29 16:20:24.489: ssaReportDigitsDone cid(1817) peer list:  tag(101) called number (2501)
*Mar 29 16:20:24.493: ssaReportDigitsDone callid=1817 Reporting disabled.
*Mar 29 16:20:24.633: cc_api_call_proceeding(vdbPtr=0x81041FE8, callID=0x71A,
      prog_ind=0x0)
*Mar 29 16:20:24.633: sess_appl: ev(21=CC_EV_CALL_PROCEEDING), cid(1818), disp(0)
*Mar 29 16:20:24.633: cid(1818)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(0)fDest(0)
*Mar 29 16:20:24.637: -cid2(1817)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
*Mar 29 16:20:24.637: ssaCallProc
*Mar 29 16:20:24.637: ccGetDialpeerTag (callID=0x719)
*Mar 29 16:20:24.637: ssaIgnore cid(1818), st(SSA_CS_CALL_SETTING),oldst(1), ev(21)
*Mar 29 16:20:24.641: cc_api_call_alert(vdbPtr=0x81041FE8, callID=0x71A, prog_ind=0x0, sig_ind=0x1)
*Mar 29 16:20:24.641: sess_appl: ev(7=CC_EV_CALL_ALERT), cid(1818), disp(0)
*Mar 29 16:20:24.641: cid(1818)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_ALERT)
oldst(SSA_CS_CALL_SETTING)cfid(-1)csize(0)in(0)fDest(0)
*Mar 29 16:20:24.641: -cid2(1817)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
*Mar 29 16:20:24.641: ssaAlert
*Mar 29 16:20:24.641: ccGetDialpeerTag (callID=0x719)
*Mar 29 16:20:24.641: ccCallAlert (callID=0x719, prog_ind=0x0, sig_ind=0x1)
*Mar 29 16:20:24.889: cc_api_call_notify(vdbPtr=0x81041FE8, callID=0x71A
*Mar 29 16:20:24.889: sess_appl: ev(20=CC_EV_CALL_NOTIFY), cid(1818), disp(0)
*Mar 29 16:20:24.889: cid(1818)st(SSA_CS_ALERT_RCVD)ev(SSA_EV_CALL_NOTIFY)
*Mar 29 16:20:24.889: -cid2(1817)st2(SSA_CS_ALERT_RCVD)oldst2(SSA_CS_CALL_SETTING)
*Mar 29 16:20:24.889: ssaNotify
*Mar 29 16:20:24.893: ccCallNotify (callID=0x719)
*Mar 29 16:20:27.789: cc_api_call_notify(vdbPtr=0x81041FE8, callID=0x71A
*Mar 29 16:20:27.789: sess_appl: ev(20=CC_EV_CALL_NOTIFY), cid(1818), disp(0)
*Mar 29 16:20:27.789: cid(1818)st(SSA_CS_ALERT_RCVD)ev(SSA_EV_CALL_NOTIFY)
oldst(SSA_CS_ALERT_RCVD)cfid(-1)csize(0)in(0)fDest(0)
*Mar 29 16:20:27.789: -cid2(1817)st2(SSA_CS_ALERT_RCVD)oldst2(SSA_CS_CALL_SETTING)
*Mar 29 16:20:27.789: ssaNotify
*Mar 29 16:20:27.793: ccCallNotify (callID=0x7
