02-21-2003 07:55 AM - edited 03-12-2019 10:46 PM
I'm currently trying to install CallManager 3.3.2 on an MCS 7835 ( 2 hard drive and 1 GB of memory) but after starting the CallManager installation and entering the SQL sa password I clixk on Install and get the following message:
-----------------------------------------------------------------------------------------------------------The Wizard was interrupted before Cisco CallManager could be completely installed.
I never had this problem on any other hardware, so I guess it might be hardware related. It was also the first time I had to insert CD7 to install
Windows 2000
At this point any help would be welcome.
Frédéric Mottier
Swisscom
02-28-2003 07:50 AM
I had a similar issue. It was due to the "Call Manager Key". Did you check for the service parameter ?? Are you performing a 'Same Server Recovery' ? If so, check if you have set it to "Same Server Recovery". Setting it, should help you solve the problem.
03-10-2003 04:48 PM
All,
This is a bug # CSCea15871.
There is a work around listed in the Bug Toolkit.
Ted B Peterson
Network Data Systems
