Showing results forĀ
Search instead forĀ
Did you mean:Ā
Can i use cube & cme at same device ?
a6z69@yahoo.com
Dear Mates,
                  We have Cisco ISR4331 working as CUBE now, We need to add CME commands to can register fxo/fxs at same device.
We will plan to connect 2 sip connection & 1 E1 connection & Webex connect.
M02@rt37
Hello a6z69@yahoo.com
Yes you could do that !
Best regards
Can you share reference & template of configuration ?
You need to config the CUBE and CME in different tenants
The below case will help you in do that:
https://community.cisco.com/t5/ip-telephony-and-phones/cube-and-cme-on-the-same-router-how-to-set-source-interface-per/td-p/4305608
Also for more details regarding tenants configuration check the below link:
https://www.youtube.com/watch?v=2EQkEXmmMsA
