Cisco call manager 10.5.2 SIP trunk status reason reference document
johnnychan77
I have recently upgraded our call manager from 9.1 to 10.5.2. I really like the new SIP trunk status added. I have been trying to find a reference document on the SIP trunk status reason (e.g local=2) with no luck. I would be appreciated if someone have these information. Thanks in advance.
The Status Reason codes are provided below:
Local=1 (request timeout)
Local=2 (local SIP stack is not able to create a socket connection with the remote peer)
Local=3 (DNS query failed)
These error codes can be found in the following System Error Messages Guide for UC_CALLMANAGER-3-SIPTrunkOOS alarm.
Ref: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/err_msgs/8_x/ccmalarms861.html#UC_CALLMANAGER-5-SIPNormalizationAutoResetDisabled
12 Replies 12
can you pleas tell me where do you see the reason local=2, if you are talking about the system error message then pls refer the below doc:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/err_msgs/9_x/ccmalarms901.html
Venkatesh
It's in the SIP Information section on the trunk configuration:
Per
So, what was the solution?
Matthew, did you get the SIP local=0 error code too?   If yes, your solution is enabling a service in IM&P server?
I have found the same problem while configuring a secure SIP trunk between CUCM and CUCxN. I have followed this link to set it:
http://www.cisco.com/c/en/us/support/docs/unified-communications/unity-connection/200504-Configure-and-Troubleshoot-Secure-Integr.html#anc4>
and i have double-checked each step: both servers are reachable, certificates are correct, i have restarted CM service...however, siptrunk status is no service local=2.
Is it mandatory to configure AXL servers in phone system (unity)? any idea about what else i can check?
Thanks in advance¡
Hello I am getting below SIPTRUNKOOS error with Local=1 (Request timeout). How to troubleshoot this issue. Please assist
Mar  8 11:40:00 DEDA1VMUCS13 local7 3 ccm: Received SIPTrunkOOS alarm
Mar  8 11:40:40 DEDA1VMUCS13 local7 3 ccm: 565: DEDA1VMUCS13: Mar 08 2018 10:40:40.344 UTC :  %UC_CALLMANAGER-3-SIPTrunkOOS: %[DeviceName=AMS-CVP2-SIPTRK][UnavailableRemotePeersWithReasonCode=10.149.213.226, 5060, local=1][AppID=Cisco CallManager][ClusterID=STRASBOURG-CCM1-Cluster][NodeID=DEDA1VMUCS13]: All remote peers are out of service and unable to handle calls for this SIP trunk
Mar  8 11:40:40 DEDA1VMUCS13 local7 3 ccm: Received SIPTrunkOOS alarm
Mar  8 11:42:39 DEDA1VMUCS13 local7 3 : 1: DEDA1VMUCS13: Mar 08 2018 10:42:39.466 UTC :  %UC_-3-UNKNOWN_ALARM:IDSEngineAttention: %[class_id=71][class_msg=ER][specific_msg=  Network connection disconnected.:Network connection was dropped from the server g_4_ccm10_5_2_13900_12 to the server g_5_ccm10_][AppID=Cisco Database Layer Monitor][ClusterID=STRASBOURG-CCM1-Cluster][NodeID=DEDA1VMUCS13]:
hello ptoft
how did you solve this issue?
Hi folks,
On my CUCM, SIP Trunk Status shows down and Status Reason local = 0.
Am creating SIP trunk between Avaya CM and CUCM. From Avaya, SIP trunk signalling shows Far end bypass error.
Can you suggest what causing these error?
regards,
Ritesh Desai
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
Did got the resolution for this issue? If YES kindly shares with us.
I just worked through this same issue and found the problem to be that I did not have the Presence Engine activated under Control Center - Feature Services.
Hope this helps :)
