Cisco CODEC Pro with Quadcam
CokKraan14115
I am looking to replace a Codec Pro codec with Quadcam (first version) for a new Codec EQ with reuse of the Quadcam (so no version Quadcam2).
Does anyone have experience or advice if this will work? Purpose is to introduce USBC passtrough for the customer without Inogeni or other devices.
Best regards,
Cornelis Kraan
The Quadcam included with the Codec PRO and the EQ are same , so you can reuse it with the EQ, and it will work.
I have a customer who replaced all their Codec PRO with EQ , using the existing Quadcam.
Response Signature
Response Signature
Hi Nithin, thanks for your answer! This helps!
