Cisco gateways and Clarent Gateways (interacting)
gviera
I am having trouble to make Cisco gateways interact with my clarent gateways. If I send calls through a clarent gateway to a cisco gateways (I am using Clarent Gatekeeper) the cisco places the call to the pstn and I connect and hear the other part talking but hey connot hear me.
I thought that it was a codec problem but I chaged so many time the codec that I could certanly say that's not. So Can someone that has Clarent Cisco interaction experience give some tips.
Thanks.
murabi
Level 4
Level 4
There are some documented limitations involving Clarent, listed at the link below:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/voipsol/longd.htm#80904
nmouts
Hi, Really it seems like a codec problem. Please provide me the sw releases of the Clarent GWs and GKs as well as cisco GWs release. I have succeeded interoperability with some sw versions so if youare using the same i can provide you some tips. Thanks
Hi, can you send me any sample configs for Cisco ? Do you have any experience with Clarent GK <-> Cisco GK interoperability?
Thank you in advance. My email is nika@hotmail.ge
eyabane
We have the solution to your problem.
I work for a company that makes VoIP software for this very purpose. Many of our customers are using our product to interface between Clarent and Cisco networks. drop me a note at epatasse@nextone.com and i will make sure you get all the information you need.
E.
