CM re-routing calls
wesley_lim
Is it possible for re-route calls from PSTN to a location within the on-net network?
For eg:
1. Calls come in from PSTN
2. CM answers the call & issues a dialtone
3. Calling party presses the extension number within the on-net network of the CM cluster/trunks.
Further to that, can this work with or without using CRS/AutoAttendant function?
Chris Deren
I guess you could use H.323 GW and do not place "Direct-inward0-dial" on the incoming pots dial-peer, this way you'll get another dialtone and will need to enter the DN.
Chris
