CM4.1 Auto-Registration btwn Main and Remote Site
aamercado
Level 4
Level 4
I turn on auto-registration on only one CM in my cluster but there is 2 devise pool - one for Main site and another for remote site. How do I specify which DP for auto-registration to use for the respective sites?
These DP will be only for internal, local, and 911 calls so that the right dp will send the correct 911 out the right GW.
Thx
agopala
You cannot auto register like that. Your only bet would be to first register all your main site phones. Then, change the configs in call manager server, and then register the remote phones.. This also means when a new phone registers, you have to go and make sure it was put in the right DP.
You can also use http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_user_guide_chapter09186a008011b50e.html#wp1030269
TAPS is part of BAT. see if that works for you.
Thanks!
