01-31-2005 05:33 AM - edited 03-13-2019 07:51 AM
Hi everybody,
I would like to use a FAX machine connected to an ATA registered in sccp to a CME 3.2.
My question is if the IOS voice gateway is the same router in which is running CME, excluding to change the parameters of AUDIO and CONNECT mode of the the ATA, have I still to configure on the gateway/CME a dial-peer voip with session target the IP add. of the ATA (like in a H.323 environment)?
01-31-2005 11:27 AM
Nope - the ATA will use skinny only when running a skinny image, so wouldn't know what to do with a h323 message...
Aaron
02-01-2005 05:20 AM
Noticed you have had the same problem as me. You do not have to do anything on CME just let the ATA Auto Register all you have to do is Web Browse to the ATA and look for the ConnectMode setting. Change this to 0xd0008401 and you should be away. Worked for me
Thanks Nathan
02-02-2005 02:36 AM
Thanks Nathan,
I tried with 0xd0008401 and I can receive FAX from PSTN but I still don't succeed to transmit outside.
Can you tell me what are your settings for the AudioMode ?
Marcello.
02-03-2005 12:16 AM
HI Marcello
My Audio Mode is set to 0x00350035 and the LBRCodec is set to 3
I Have also attached the voice parts of my config below.
I Am also running CME ver 3.2.1 on a New Cisco 2811
Thanks Nathan
voice-card 0
dspfarm
voice service voip
sip
header-passing
registrar server
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn twait-disable
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
isdn skipsend-idverify
interface BRI0/0/1
no ip address
isdn twait-disable
isdn static-tei 0
interface BRI0/1/0
no ip address
isdn twait-disable
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn twait-disable
isdn static-tei 0
tftp-server flash:P00303020214.bin
tftp-server flash:P00305000301.sbn
tftp-server flash:P00403020214.bin
tftp-server flash:ATA030100SCCP040211A.zup
tftp-server flash:CP7912040000SCCP040701A.sbin
control-plane
voice-port 0/0/0
disc_pi_off
compand-type a-law
cptone GB
voice-port 0/0/1
disc_pi_off
compand-type a-law
cptone GB
voice-port 0/1/0
disc_pi_off
compand-type a-law
cptone GB
voice-port 0/1/1
disc_pi_off
compand-type a-law
cptone GB
dial-peer voice 91 pots
translation-profile incoming append-in
preference 1
destination-pattern 9.T
direct-inward-dial
port 0/0/0
dial-peer voice 92 pots
preference 2
direct-inward-dial
port 0/0/1
dial-peer voice 93 pots
preference 3
direct-inward-dial
port 0/1/0
dial-peer voice 94 pots
preference 4
direct-inward-dial
port 0/1/1
telephony-service
load 7910 P00403020214
load 7960-7940 P00305000301
load ATA ATA030100SCCP040211A.zup
load 7912 CP7912040000SCCP040701A.sbin
max-ephones 36
max-dn 100
ip source-address 172.16.22.1 port 2000
auto assign 1 to 20
service phone pcPort 1
service phone garap 1
service phone forwardingDelay 1
service phone voiceVlanAccess 1
service phone settingsAccess 1
timeouts interdigit 3
timeouts ringing 30
network-locale GB
time-format 24
date-format dd-mm-yy
create cnf-files version-stamp 7960 Jan 27 2005 15:08:52
dialplan-pattern 1 01315618... extension-length 4
max-conferences 4 gain -6
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9.T
secondary-dialtone 9
ephone-dn 2 dual-line
number 8341
ephone-dn 3 dual-line
number 8342
ephone 2
mac-address 0012.0196.6109
type ata
button 1:2
ephone 3
mac-address 0012.43E0.4ECB
type 7912
button 1:8
02-02-2005 11:20 AM
If you are using a ATA with fax with CME you have to use a H323 load as fax on ATA is not supported on CME with skinny.
CSCed47764
Call Manager Express does not allow for fax passthrough configuration
When configuring CallManager Express for use with and ATA and a fax machine, it is required
to setup the gateway and ATA to do fax passthrough. On the ATA in Skinny mode, the device
can be setup to do the call as g711 and have VAD disabled, but on the CME, there is no
way in Skinny to configure modem passthrough as prescribed by Cisco documentation.
The workaround is to load an h323 image to ATA and configure it for g711 and disable VAD,
and on the CME setup an inbound h323 dial-peer as follows:
dial-peer voice 555XXXX voip
incoming called-number .
destination-pattern 555XXXX
session target ipv4:192.168.X.X
modem passthrough nse codec g711ulaw
fax rate disable
02-02-2005 11:39 AM
David,
I have the same probrem with using ATA and CME for fax. I set the same configuration but the system doent work. Can you sen me the configuration file or the snapshot of the ATA configuration please?
Tkx
My problem:
I use cisco 3745 for Voice gateway with CME 3.2 installed.
In the C3745 i have 8 FXO ports and i reserved 1 FXO for FAX. Below are my configuration:
voice service voip
voice-port 1/1/2
connection plar 501
dial-peer voice 99 voip
incoming called-number 88.T
destination-pattern 501
session target ipv4:10.1.1.10
codec g711ulaw
fax rate disable
dial-peer voice 4 pots
destination-pattern 88.T
port 1/1/2
Tkx for your helps
Romain
02-02-2005 01:09 PM
The only thing on the ATA that is non-default is the audiomode which is set for 0x00150015. This is based on the documentation at http://www.cisco.com/univercd/cc/td/doc/product/voice/ata/ataadmn/sccp/sccpaapd.htm
Also make sure the ATA is not configured on the router as an ephone.
02-08-2005 10:12 AM
David,
I've done the configuration like you said but i have error when trying to use fax.
Below are the output of the ATA 186 device collected by prserv.exe utility.
501 active @0x51c758bd (GK @0x25642025)
[0]StartTone 0
[0]DTMF 3 , insum:793005
[0]StopTone
[0]DTMF 1 , insum:782536
[0]DTMF 2 , insum:773278
[0]DTMF 2 , insum:759268
[0]DTMF 6 , insum:787446
[0]DTMF 5 , insum:811814
Calling 312265
SCC->(0 0)
CLIP
SCC->(0 0)
<0 0> dial<312265>
block queue <- (18 1518692 0)
Connect to <0xa010101 1720>..
>>>>>>>> TX CALLER ID : 0x1 0x80 5
Q931<-0:Setup:CRV 15306
Q931->0:Proceeding
Connect H245...
Q931->0:Alerting
Connect H245...
SCC:ev=10[0:0] 3 0
[0]StartTone 3
block queue <- (19 1518692 539594)
NuConnectDispatcher: 0x3bca
H245 TCP conn 51c750bd 11093
CESE/MSDSE start:<0 0 0 0>
capSize = 3
H245->0:Cese
[0]: OOB DTMF
RmtInputCap <15 5>
RmtInputCap <15 4>
RmtInputCap <15 1>
RmtAudioCap <4 11>
MD/FRM 11 2
RmtAudioCap <4 10>
Capability set accepted
H245->0:MSD:
[0]Slave Tx:10 TxRemote:10
H245->0:CeseAck
H245->0:MsdAck
h323.c 2118: cstate : 4
->H245<0> OLC
H245<-0:LcseOpen
TxAud = G729A 2 fpp
SetG723Mode: 2 0
H245->0:LcseOpen
H245->0:OLC mode 10
remote OpenLogicalReq G711/G729(10) : 2 fpp
OpenRtpRxPort(0,0x0,16384):8
RTP Rx Init: 0, 0
RTP->0:<0x51c758bd 16384>
CESE/MSDSE start:<3 4 0 2>
capSize = 3
H245->0:LcseOpenAck
OnReceivedAckPDU: sessionID missing
RTP<-0:<0x51c750bd 17314>
[0]Enable encoder 18
[0]: EC 1
RTP TX[0]:SSRC_ID = f3c46ff0
RTP Tx Init: 0, 0
Q931->0:Connect
Enable LEC adapt [0]=1
[0]StopTone
SCC:ev=12[0:0] 3 0
[0]StopTone
Q931->0:ReleaseComplete: reason 16, tone = 13
H245<-0:EndSessionCmd 1
0: Close RTPRX
Enable LEC adapt [0]=0
[0:0]Rel LBRC Res
Q931<-*:ReleaseComplete
SCC:ev=13[0:0] 4 0
[0:0]SCC: Disconnected
SCC:ev=13[0:0] 11 0
[0]StartTone 2
[0]StopTone
SCC->(0 0)
CCBS expired
[0]MPT mode 0
Please i need your help, if you need the complet configuration of the GW and the ATA please write to me at rleguede@hotmail.com
Tkx
02-18-2005 04:38 AM
I have installed to day CME with ata-188 and with a FAX
On the ATA-box I used the following setting:
Audio to 0x00150015
I defined also beneth the dial-peer the following:
Fax rate voice
And this works fine
Jan Meeling
09-01-2005 12:29 PM
hi Jan,
i am studing for voice CCIE and i havn't seen such a connect mode in the documentation, could you please tell me where did you find this value?
regards
eric
