03-08-2006 12:10 PM - edited 03-15-2019 04:09 AM
Hi all,
i do some tests with a small CCME environment: Cisco 2611XM, 1* ISDN PRI (E1). So, nearly everthing is working realy fine, all outgoing calls are OK, all incoming calls from fixed lines are also working.
But i have a problem with incoming calls from mobiles (i tried different providers, all the same), after dialing i get a call conected signal, after a few seconds i got busy signal.
I´ve done some isdn q931/q921 and vtsp debugging and found some differences but i were not able to interpret them ...
When i call from mobile the router does not send a TX -> SETUP_ACK, instead a TX -> CALL_PROC is send.
On VTSP i could see
vtsp_process_event: [state:S_DIGIT_COLLECT, eveent:E_TSP_PROCEEDING]
vtsp_process_event: [state:S_DIGIT_COLLECT, event:E_TSP_DISCONNECT_PI_IND]
instead of [state:S_SETUP_INDICATED, event:E_TSP_INFO_IND] when i called from fixed line.
Any ideas where i have to search for a solution ?
Cisco 2610XM, IOS 2600-ipvoice-mz.124-7.bin, (CME 3.3)
kind regards,
Dietmar
03-08-2006 02:24 PM
Dietmar,
I think the router is doing just fine.
Notice that 23 seconds after the connect ack, we get a disconnect coming in from the telco. I wanted to make sure they are not timing out on anything. It does not look like it is a timer popping, because I cannot think of any timer that goes off in 23 seconds..
Mar 8 19:55:13.496: ISDN Se1/0:15 Q931: DISCONNECT pd = 8 callref = 0x09E3
Cause i = 0x8090 - Normal call clearing
You do not need to send a setup ack. Calls should still work without a setup ack, as long as you send a proceed soon enough (which in this case we are)..
You can ignore the VTSP debugs in this case.
I had a similar issue before.. Calls from only some cell phone providers were failing. We later found out that it was only providers that used older technologies (verizon for example) failed. GSM calls worked just fine.. We were never able to determine why the difference.. I belive it is something to do with their switching setup.
Try to make calls from different cell phones:
nextel
verizon
sprint
AT&T
TMobile
etc.. Do you see a difference?
03-08-2006 10:39 PM
thank you for your answer.
I tried it once again, the 23sec are the time after i hang up the call on my mobile.
I tried 3 Providers, the output of the Debug is the same.
The isdn setup starts and continue until:
ISDN Se1/0:15 CC: CCPRI_Go: source id 0x300, call id 0x20, event 0x341 (pre-ccb recovery)
ISDN Se1/0:15 CC: CCPRI_Go: dispatching event 0x92 call id 0x20 cref 0x8DC4 Source->L3
ISDN Se1/0:15 CC: CCPCC_CallRoutingIn: executing with event = 92 in state = CALL ROUTING_IN
Here i got for about 10 sec a connected signal (continuous tone), then it change to a fast busy.
After that, nothing happen and i quit the call on the mobile.
Mar 8 18:24:51.744: ISDN Se1/0:15 CC: CCPRI_Go: source id 0x500, call id 0x0, event 0x4B (pre-ccb recovery)
Mar 8 18:24:51.744: ISDN Se1/0:15 CC: CCPRI_Go: call_id 0x20 cref 0x8DC4 event 0x4B Source->HOST
Mar 8 18:24:51.748: ISDN Se1/0:15 CC: CCPCC_CallConnected: event 0x4B b channel 20 nfas int_id 0 call_id 0x20
So, i´m not realy sure were i have the problem - if it is on the ISDN setup, call routing or whatever ...
regards,
Dietmar
03-09-2006 01:21 AM
Solution: direct-inward-dial
After a collegue gave me some hints i started to debug dialpeers.
The problem was that i did´nt configure "direct-inward-dial" in the dial-peer statement.
dial-peer voice 100 pots
destination-pattern 0.T
direct-inward-dial
port 1/0:15
Now both calls - from fixed and from mobile - are working.
Dietmar
Dietmar
