ā05-13-2013 07:38 AM - edited ā03-15-2019 05:26 AM
I am trying
to install DMM-5.3.0.244.isov in the UCS B-series server | |
i am getting the below error |
Could anyone help.
Please give me the alias for DMM.
Solved! Go to Solution.
ā05-13-2013 07:49 AM
Which C series?
ā05-13-2013 08:02 AM
So I do have the same iso image you are trying to use. I think you may have an incorrect hardware configuration on your C210. Is it an off the shelf C210 or was it purchased as a DMM? I'm pretty sure DMM is only supported on a C210 that has hardware specd specifically for the DMM. Basically it is an appliance.
Cisco Digital Media Manager 5.3.x on UCS C210 (DMM-SVR-C210-K9)
I don't think I can't help you from here. You will have to contact TAC.
ā05-13-2013 07:42 AM
DMM is not supported on the B series.
ā05-13-2013 07:46 AM
Hi Mike,
I have also tried with the c-series server, am getting the same error.
Please help.
Can you give alias for DMM.
ā05-13-2013 07:47 AM
This document describes how to set up and administer the following Cisco Digital Media System (DMS) 5.2.x appliances:
ā¢Cisco Show and Share appliances:
āCisco Show and Share 5.3.x on MCS 7835-H3
āCisco Show and Share 5.3.x on WAVE-574
āCisco Show and Share 5.3.x on UCS C210 (SNS-SVR-C210EN-K9)
āCisco Show and Share 5.3.x and Cisco Show and Share Reports 5.2.2 on UCS C200 (SNS-SVR-C200WG-K9)
ā¢Cisco Digital Media Manager appliances:
āCisco Digital Media Manager 5.3.x on MCS 7835-H3
āCisco Digital Media Manager 5.3.x on UCS C210 (DMM-SVR-C210-K9)
Which C series?
ā05-13-2013 07:51 AM
C210 series i have installed but getitng error
Thanks a lot.
ā05-13-2013 07:56 AM
WHere did you get the iso you are using? I'm not familiar with that version. Is this a fresh install or an upgrade? Normally you have to upgrade from 5.2 to get to 5.3. You can't do a fresh 5.3 install unless you have a special iso that someone from Cisco posted to you.
ā05-13-2013 11:33 AM
i have 2 doubts still
1. i have only ucs server which is not purchased as dmm, can i try with DMM 5.4 VM image whether it will work.
2.
I need to implement Digital signage solution in my office workplace.
I have DMP 4400G and TV only , can I implement the solution without DMM,SNS,Stadium vision director.
Please suggest me your valuable inputs
Thanks a lot for your great support.
Rajesh
