CUCM Operating System Administrator Password Recovery | does not work
sprintership-il
I have fallowed this link in order to reset OS Admin password of CCUm version 8.6 with no luck:
https://supportforums.cisco.com/document/60721/cucm-operating-system-administrator-password-recovery
Is there any other way ?  Thanks,
Aaron O'Hare
What happens when you try?
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cucos/8_6_1/cucos/osg_861_cm/iptpch2.html#wp1053218
-AO
I believe we have to wait for a tac suport to us etheir magic , thank you though
They have better access then we ever will :)
Good luck.
-AO
zdesignstudio
Level 4
Level 4
Are you able to get into the utility and follow the prompts completely or are you getting stopped somewhere? If you are able to go through all the prompts and change the password but teh password doesnt "take" then you will need to get a TAC case opened so an engineer can use their magic root access tool to get in for you.
Please rate useful posts and mark answers as "correct" if applicable.
Please rate useful posts and mark answers as correct if applicable.
