12-18-2008 04:55 AM - edited 03-13-2019 05:56 PM
Hi all,
I have a problem with my Cisco Unity Express.
It works great when I call it from internal calls, but I can't call it from outside.
We use a sip trunk to made calls from and to outside.
So if I try to made a call to a users with a ip phone, its works great.
But it doesn't work when I try to join the directory number of the cti port corresponding to the CUE.
I think it's a problem of transcoding, because the trunk sip use g729 and cue g711...
But I configured a transcoder, and it works for remote site which call in g729, but it doesn't work with ouside calls.
Is someone have a idea?
12-18-2008 07:02 AM
Sounds like a transcoder issue, check out this link, there's some config guidance at the bottom:
12-18-2008 12:43 PM
Try:
voice service voip
allow sip-to-sip
12-19-2008 01:01 AM
I forgot to say that I use a CCM v5.1 and a VG 2851 with CUE 3.0, not a CME...
I try on the VG
voice service voip
allow sip-to-sip
but it doesn't work.
12-20-2008 05:36 AM
Try making it so that the region to region codec for an outside call to CUE uses G711. You may need to create a new region for CUE to do this.
01-06-2009 04:46 AM
Ok,I created a new region for the CUE. I will try to play with the region to region codec.
01-06-2009 04:57 AM
I tried and it doesn't work.
The Sip Trunk is on a region and the CUE is on another one.
I tried to configure the transcoder on the same device pool than the sip trunk and than the CUE, without result.
I tried to change the codec between sip trunk region and CUE region, without result.
I really don't know how to do ...
