Difference between cm & cme
akbar1
I just want to know the difference between call manager & call manager express
3 Accepted Solutions
thisisshanky
Level 11
Level 11
Mainly features and number of phones supported by each product. You can think of Callmanager as a replacement for your enterprise class PBX, while CME replaces a key system.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Rob Huffman
Hi Mohammed,
Here is a little addition to Sankar's good post;
Cisco CallManager Express Description
Cisco CallManager Express is a feature-rich entry-level IP telephony solution that is integrated directly into Cisco IOS software. Cisco CallManager Express allows small business customers and autonomous small enterprise branch offices to deploy voice, data, and IP telephony on a single platform for small offices, thereby streamlining operations and lowering network costs.
From this doc;
Cisco CallManager Express: Overview
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide_chapter09186a00802d2476.html#wp2169372
Cisco CallManager serves as the software-based, call-processing component of the Cisco IP Telephony Solution for the Enterprise part of Cisco AVVID (Architecture for Voice, Video and Integrated Data). The Cisco IP Telephony Applications Server provides a high-availability server platform for Cisco CallManager call processing, services, and applications.
The Cisco CallManager system extends enterprise telephony features and functions to packet telephony network devices such as IP phones, media processing devices, voice-over-IP (VoIP) gateways, and multimedia applications. Additional data, voice, and video services such as unified messaging, multimedia conferencing, collaborative contact centers, and interactive multimedia response systems interact through Cisco CallManager open telephony application program interface (API).
Cisco CallManager provides signaling and call control services to Cisco integrated telephony applications as well as third-party applications
From this doc;
Cisco IP Telephony Overview Cisco CallManager System Guide, Release 4.1(3)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803eda7e.html
Hope this helps!
Rob
Please remember to rate helpful posts.....
i recon all post were excellent and amazing.........to make it pretty simple........call manger now is called unified call manger (its same thing but just the name change) is a software based ip telphony solution which replaces PBX's and are installed on server which does all the funcnion of PBX.......even more control.....now call manger express is used by small company as it has bit limited function and even express can be configured on cisco routers (some routers support it not all) so u dont have to buy specific servers.......inshort u can say that its the small version or limited version of CCM.....pleae rate all post
5 Replies 5
thisisshanky
Level 11
Level 11
Sankar Nair
Rob Huffman
Hi Mohammed,
From this doc;
From this doc;
Hope this helps!
Rob
akbar1
Thanks to all of you, your post helped me alot in understanding the difference between cme &cm
I am thankful to everyone who have answered to he question, I was able to understand it. Thanks again!!
