I assume you have a VG350 BAT Template you're importing against, yes?
Then you need to configure the very first port, before CUCM will let you BAT in the VG350. If you have multiple cards of 72 ports, then configure the first port on each card. This is in the template, and so you'll need a line template on the port, just like you'd have on a BAT Phone Template.
