11-14-2003 08:05 AM - edited 03-13-2019 02:34 AM
I am getting echo for the first 3-4 seconds of all calls going out my analog lines(ground start). I am running CM 3.3.2 ES 45 and a 3725 with an NM-HDA. Is there anything I can do to solve this?
Frank
11-14-2003 08:41 AM
do you have "echo-cancel coverage" running on the port? if not set it to 24 that should take care of your problem.
Geoff
11-14-2003 08:47 AM
I have tried every echo coverage option available. None of them help. The echo canceler does work but until it kicks in (after 3-4 seconds) i hear bad echo.
11-14-2003 09:16 AM
Under newer code with EchoBeach, you have the option of using "echo suppressor". This turns the conversation into half-duplex for (by default) the first 7 seconds of the call while the ECANs are converging, thus eliminating the startup time echo.
11-14-2003 10:58 AM
The echo suppressor can only be used on DSPs when the default Cisco G.165 EC is used. The echo suppressor cannot be used with the extended EC.
11-14-2003 08:42 PM
So far as I know, and my routers running in G.168 mode seem to confirm, suppressor is available in both G.165 and G.168 modes. The gimmick is that suppressor is supposed to be unnecessary in G.168 mode, because G.168 is supposed to converge very fast - and in my experience, it does seem to converge in under one second.
If you're getting 3 or 4 seconds of echo, I would think you are using the G.165 canceller. That URL I posted alleges that G.168 is unavailable on the NM-HDA when on the 2600 platform, which I don't understand, but so be it. I poked at a 2600 + NM-HDA running 12.3(2)T1 this evening to see what the real deal is. I can configure ecan-extended, but I don't get a 64ms coverage option or an ERL adjustment option, so I suspect we're still in G.165 mode regardless.
If you're still in G.165 mode, that would explain your 3 or 4 seconds of convergence time. So, in my opinion, suppressor is still the tool for the job. Is your router not accepting the command?
