10-22-2004 01:21 AM - edited 03-13-2019 06:46 AM
Is it possible to use ethernet switch port on an IP phone with 1000BaseTX available PC if IP Phone is connected through a 1000BaseTX switch?
10-22-2004 05:44 AM
No the 2 ethernet ports on the 7960/40 for example are 10/100mbps only. 100/1000BT NIC should autonegotiate to 100mbps with the IP Phone. Look on the back of the phone and atop of the ethernet ports you will see the speeds (10/100SW and 10/100pc).
Here is a link to the doc for the 7960/40.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_ipphon/english/ipp7960/iph60pdf.pdf
HTH,
Mike
Log in to Community
