04-24-2023 06:10 AM
Hello people,
Is there any document about the compatibility for expressway X8.11.4 with esxi 7.0 and esxi 7.0. su1
It is not clear on the document for installation x8.11, if I have understand correctly it is only supported with up to esxi 6.5
Can anyone confirm?
Solved! Go to Solution.
04-24-2023 07:04 AM
It is not supported and besides that this version is past everything. It is not even mentioned anymore in the virtualization guide for Expressway. You should seriously consider updating to something a lot more current. Based on the current guide you'd need to be on X12.6.2 to use ESXi 7.
04-24-2023 07:04 AM
02-27-2024 02:22 AM
hello,
Does that mean it will be compatible with all esxi updates, release 6.5, updates 1,2 and 3 ??
02-27-2024 03:37 AM
@AliHassan wrote:
hello,
Not sure what you refer to with "it". Can you please elaborate? Apart from that you're question is off-topic to the OP as that question was about version 7 of ESXi, so it would likely be better if you where to ask it in your own post. Also from what I know ESXi version 6.5 is end of support.
04-25-2023 12:53 AM
There is this site: https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/cisco-collaboration-virtualization.html
And I strongly recommend you to bookmark it.
