expressway X8.11.4 compatibility with esxi 7.0 and 7.0 su1
Hello people,
Is there any document about the compatibility for expressway X8.11.4 with esxi 7.0 and esxi 7.0. su1
It is not clear on the document for installation x8.11, if I have understand correctly it is only supported with up to esxi 6.5
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/install_guide/Cisco-Expressway-Virtual-Machine-Install-Guide-X8-11-1.pdf
Can anyone confirm?
It is not supported and besides that this version is past everything. It is not even mentioned anymore in the virtualization guide for Expressway. You should seriously consider updating to something a lot more current. Based on the current guide you'd need to be on X12.6.2 to use ESXi 7.
Response Signature
Response Signature
hello,
Does that  mean it will be compatible with all esxi updates, release 6.5, updates 1,2 and 3 ??
@AliHassan wrote:
hello,
Not sure what you refer to with "it". Can you please elaborate? Apart from that you're question is off-topic to the OP as that question was about version 7 of ESXi, so it would likely be better if you where to ask it in your own post. Also from what I know ESXi version 6.5 is end of support.
Response Signature
b.winter
