FAX Problem - ATA186
nenad_2007
I traied to send FAX IP to IP, from Central Site to Remote Office, but unsuccessful. I have error on sending site (Central Ofiice) Tx Canceled - Error 0091. First Fax is connected on port1 Cisco ATA186 on Central Site. I have Remote Office connected with WAN link to Central Site. Fax at the Remote Office is also connected on first port ATA 186. On CallMAnager 4.1.3 I have defined Device Pool DP_FAX with Region G.711 within region. For FAX machine on Central and Remote Site , I have defined same Device Pool. All communication between FAX machines on Central and Remote Site is trough G.711 codec.
I capture debug information from both ATA 186 with prserv.exe:
At the Central Site(SENDING SIDE), Point of problem:
[1]MPT mode 3
[1]speed up@40170400->40170560, 40170000->40170080, bc 8, td 0, df 1
97:30;6,6,0,0,
<-|EndCall[1]
<-|SK[1]:9, L=1, FGR=340ea17
[1]StopTone
->CloseRxChn[1]
|->StopMediaTx[1]
|->CallState[1]=2 L=1 R=340ea17 FG=0 r=340ea17,0
IDLE[1]
|->SetRingerMode[1]:1
98:00;6,6,0,0,
At the REMOTE FAX (RECEIVING SIDE), output is in atachment problem beggin after [1]MPT mode 3.
Can anybody help.
harris.h
What mode do you have configured for the Fax service?
Is it configured constant on Gateways and ATA?
Also what speed link are you using?
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_administration_guide_chapter09186a00800c4d1e.html#1013219
