GateKeeper and Gateway
wongsusanto
I am having a problem setting up a gatekeep and some Voip gateways. I want to set a security if the gateways try to register to the gatekeeper. I am using radius as an authentication server. Does any one have the sample config...? I tried to follow the sample on cisco web site but it doens't work. The gateways always try to authenticate but the radius didn;t accept it because there is invalid...These are the configs on my routers
GateKeeperaaa new-model
aaa authentication login h323 group radius
aaa authentication ppp h323 group radius
aaa authentication nasi h323 group radius
aaa accounting network h323 start-stop group radius
aaa accounting connection h323 start-stop group radius
aaa session-id common
radius-server host 192.168.0.32 auth-port 1812 acct-port 1813
radius-server retransmit 3
radius-server key test
radius-server vsa send accounting
radius-server vsa send authentication
gatekeeper
zone local HQ cisco.com 192.168.0.232
accounting vsa
security h323-id
security password default h323
arq reject-unknown-prefix
lrq forward-queries
no shutdown
GATEWAY
interface FastEthernet0/0
ip address 192.168.0.243 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id HQ ipaddr 192.168.0.232 1718
h323-gateway voip h323-id BR2
h323-gateway voip tech-prefix 200#
h323-gateway voip bind srcaddr 192.168.0.243
gateway
security password 02243609 level all
Debugging result : radius and aaa authentication
01:17:29: AAA: parse name=<no string> idb type=-1 tty=-1
01:17:29: AAA/MEMORY: create_user (0x63942684) user='BR2' ruser='NULL' ds0=0 port='NULL' rem_addr='NULL' authen_type=ASCII service=LOGIN priv=0 initial_task_id='0'
01:17:29: AAA/AUTHEN/START (3421315262): port='' list='h323' action=LOGIN service=LOGIN
01:17:29: AAA/AUTHEN/START (3421315262): found list h323
01:17:29: AAA/AUTHEN/START (3421315262): Method=radius (radius)
01:17:29: AAA/AUTHEN(3421315262): Status=GETPASS
01:17:29: AAA/H323: Password:
01:17:29: AAA/AUTHEN/CONT (3421315262): continue_login (user='BR2')
01:17:29: AAA/AUTHEN(3421315262): Method=radius (radius)
01:17:29: RADIUS: ustruct sharecount=1
01:17:29: Radius: radius_port_info() success=0 radius_nas_port=1
01:17:29: RADIUS: Send to unknown id 42 192.168.0.32:1812, Access-Request, len 55
01:17:29: RADIUS: authenticator 88 5F 76 55 D9 B5 1B 1C - 5A 7E 55 F1 D0 5B B2 C5
01:17:29: RADIUS: NAS-IP-Address [4] 6 192.168.0.232
01:17:29: RADIUS: NAS-Port-Type [61] 6 Async [0]
01:17:29: RADIUS: User-Name [1] 5 "BR2"
01:17:29: RADIUS: User-Password [2] 18 *
R8#
R8#
R8#
01:17:34: RADIUS: Retransmit id 42
01:17:34: RADIUS: Received from id 42 192.168.0.32:1812, Access-Reject, len 20
01:17:34: RADIUS: authenticator 13 E4 71 47 D9 AD FD 66 - D5 17 5C 4E 8A 10 1A 49
01:17:34: RADIUS: saved authorization data for user 63942684 at 0
01:17:34: AAA/AUTHEN(3421315262): Status=FAIL
01:17:34: AAA/MEMORY: free_user (0x63942684) user='BR2' ruser='NULL' port='NULL' rem_addr='NULL' authen_type=ASCII service=H323 priv=0
01:17:34: RADIUS: Cannot find corresponding request for response
Thanks and Regards
pacameron
Level 4
Level 4
Make sure the gateways and gatekeepers are NTP synchronised. The time difference between the 2 devices has to be within around 30 seconds of each other otherwise they will not authenticate.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t1/h323v2p2.htm#xtocid255056
"The security mechanisms described above require the gateway and
gatekeeper clocks to be synchronized within 30 seconds of each other by
using a Network Time Protocol (NTP) server."
If you don't have access to a NTP server, set up the gatekeeper as a NTP master and set the router clock, then point the gateways to the gatekeeper so they sync their time off it:
gatekeeper router -
ntp master
gateway router -
ntp server
The radius server needs to have a username of the remote router and a corresponding password in it's database. You also need the following line in the gatekeeper config-
security token required-for all
Here are configs for 2 gateways authenticating to a gatekeeper -
multi-3-3#sh run
Building configuration...
Current configuration : 1534 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname multi-3-3
logging buffered 250000 debugging
logging rate-limit console 10 except errors
enable password cisco
memory-size iomem 10
ip subnet-zero
no ip finger
no ip domain-lookup
isdn switch-type basic-net3
call rsvp-sync
cns event-service server
interface Loopback0
ip address 33.1.1.1 255.255.255.0
h323-gateway voip id Gatekeeper3_4 ipaddr 34.1.1.1 1718
h323-gateway voip h323-id Gateway3_3
h323-gateway voip bind srcaddr 33.1.1.1
ip address 10.1.1.3 255.255.255.0
speed 10
half-duplex
interface BRI1/0
no ip address
isdn incoming-voice voice
interface BRI1/1
no ip address
router eigrp 1
network 10.0.0.0
network 33.0.0.0
no auto-summary
no eigrp log-neighbor-changes
ip kerberos source-interface any
ip classless
no ip http server
voice-port 1/0/0
compand-type a-law
voice-port 1/0/1
dial-peer cor custom
dial-peer voice 100 pots
destination-pattern 1
port 1/0/0
dial-peer voice 200 voip
destination-pattern 2........
session target ras
dtmf-relay cisco-rtp
ip precedence 5
gateway
security password 0822455D0A16 level all
gatekeeper
shutdown
line con 0
transport input none
line aux 0
line vty 0 4
password cisco
login
no scheduler allocate
ntp server 10.1.1.4
end
multi-3-3#
multi-3-4#sh run
Current configuration : 1499 bytes
! Last configuration change at 18:52:04 UTC Mon Dec 10 2001
! NVRAM config last updated at 18:52:41 UTC Mon Dec 10 2001
version 12.1
hostname multi-3-4
aaa new-model
aaa authentication login h323 local
username Gateway3_3 password 0 cisco
username Gateway3_5 password 0 cisco
memory-size iomem 30
ip subnet-zero
no ip finger
no ip domain-lookup
call rsvp-sync
voice rtp send-recv
interface Loopback0
ip address 34.1.1.1 255.255.255.0
h323-gateway voip bind srcaddr 34.1.1.1
interface Ethernet0/0
ip address 10.1.1.4 255.255.255.0
half-duplex
router eigrp 1
network 10.0.0.0
network 34.0.0.0
no auto-summary
ip classless
ip http server
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
gateway
gatekeeper
zone local Gatekeeper3_4 cisco.com 34.1.1.1
zone prefix Gatekeeper3_4 1*
zone prefix Gatekeeper3_4 2*
gw-type-prefix 1* gw ipaddr 33.1.1.1 1720
gw-type-prefix 2* gw ipaddr 35.1.1.1 1720
no shutdown
line con 0
line aux 0
line vty 0 4
password cisco
line vty 5 15
ntp master
end
multi-3-4#
multi-3-5#sh run
Current configuration : 1655 bytes
! Last configuration change at 18:50:14 UTC Mon Dec 10 2001
version 12.1
hostname multi-3-5
memory-size iomem 15
ip subnet-zero
no ip finger
no ip domain-lookup
call rsvp-sync
interface Loopback0
ip address 35.1.1.1 255.255.255.0
h323-gateway voip h323-id Gateway3_5
h323-gateway voip bind srcaddr 35.1.1.1
ip address 10.1.1.5 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface BRI1/0
no ip address
interface BRI1/1
no ip address
router eigrp 1
network 10.0.0.0
network 35.0.0.0
no auto-summary
ip classless
ip http server
voice-port 1/0/0
compand-type a-law
voice-port 1/0/1
dial-peer voice 200 pots
port 1/0/0
dial-peer voice 100 voip
destination-pattern 1........
session target ras
ip precedence 5
gateway
security password 1511021F0725 level all
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
login
ntp clock-period 17179886
ntp server 10.1.1.4
end
multi-3-5#
It's working NOW...thanks for your help...yo're right i need to synchronize the time using ntp.....but i can't still authenticate using radius server...i think somethig wrong with the radius server i fixed later...anyway...if i follow your configuration...i just can make a call from one site.....when I called 2xxxxxx it will trigger the call to the other router...but from another router i press...1xxxxxx....the call can't go through......i did debugging on the router i called nothing happened....it seems like the call didnt go to the other router.....do you have any idea...why ???
again..thanks for you help....
regards
Have a look at the AAA configs on the config I pasted earlier and use local authentication based on username/password. This will confirm if the problem is with your radius server or not.
If you have a second gateway then the gatekeeper will need a config to route the call back to the other gateway. In the original config I don't see anything that will handle the 1X or the 2X numbers.
