h323-disconnect-cause = 60?
p.kodzis
hello,
what is the h323 disconnect cause = 60?
today I have been started recieving that disconnect cause when I am calling one of mobiles network. Via the same PRI to Alcatel4400 I route calls to 2 different mobile operators and that problem is with the one. No changes in configuration of the router have been made.
===router config (3660, 12.2(11)T===
voice-card 6
isdn switch-type primary-net5
isdn voice-call-failure 0
voice call carrier capacity active
controller E1 6/0
pri-group timeslots 1-31
interface Serial6/0:15
no ip address
no logging event link-status
isdn overlap-receiving
isdn incoming-voice voice
isdn T306 60000
isdn T310 60000
isdn bchan-number-order ascending
no cdp enable
dial-peer cor custom
dial-peer voice 4 pots
!!!mobile 1
destination-pattern 46........
no digit-strip
port 6/0:15
dial-peer voice 5 pots
!!!mobile 2
destination-pattern 45........
no digit-strip
port 6/0:15
===radius accouting====
Mon Oct 14 09:13:32 2002
h323-connect-time = "h323-connect-time=09:13:30.659 CET Mon Oct 14 2002"
h323-disconnect-time = "h323-disconnect-time=09:13:32.989 CET Mon Oct 14 2002"
h323-disconnect-cause = "h323-disconnect-cause=60 "
===some debug===
Oct 14 12:33:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x6311DF2C]
Oct 14 12:33:50: //623/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnected: (vdbPtr=0x0, callID=0x26F, cause=0x60)
Oct 14 12:33:50: //623/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(11=CC_EV_CALL_DISCONNECTED), cid(623), disp(0)
Oct 14 12:33:50: //623/FA60A6BD8355/SSAPP:2:281/ssaTraceSct: cid(623)st(SSA_CS_ACTIVE)ev(SSA_EV_CALL_DISCONNECTED)
oldst(SSA_CS_CONFERENCING_ALERT)cfid(281)csize(0)in(1)fDest(1)
13 Replies 13
hwei
the ISDN cause 60 was SERVICE NOT ALLOWED. Could you also capture "debug isdn q931" and "debug isdn event"?
all topology is:
[Mobile_Net]-PRI-[Alcatel_4400]-PRI-[ RouterA,3660,12.2(11)T ]-ip-[ RouterB,3660,12.2(11)T, BRI ]-BRI-[ Panasonic]-[ phone ]
probem occure only if I am calling from phone connected to panasonic PBX - I can call only one of two mobile networks.
uses connected to Alcatel PBX with normal phones can call both mobile networks.
I am not able to test that problem by makeing phone calls from RouterA - there is only voip E1.
As I was written configuration of the routers wasn't changed. PBX conf also wasn't changed.
problem is I dial the number, I wait for connection and when someone is answering the connection is disconnected.
any idea?
========================RouterA=========================================================================
Oct 15 07:42:01: ISDN Se6/0:15 Q931: TX -> SETUP pd = 8 callref = 0x01DD
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x81, '225760511'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '4501705401'
High Layer Compat i = 0x9181
Oct 15 07:42:01: ISDN Se6/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x81DD
Oct 15 07:42:01: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x81DD calltype 2 CALL_SETUP_ACK
Oct 15 07:42:05: ISDN Se6/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x81DD
Progress Ind i = 0x8288 - In-band info or appropriate now available
Oct 15 07:42:05: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x81DD calltype 2 CALL_PROCEEDING
Oct 15 07:42:05: ISDN Se6/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x81DD
Oct 15 07:42:05: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x81DD calltype 2 CALL_PROGRESS
Oct 15 07:42:18: ISDN Se6/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x81DD
Date/Time i = 0x020A0F092A
Oct 15 07:42:18: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x81DD calltype 2 CALL_CONNECT
Oct 15 07:42:18: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x81DD calltype 2 CALL_PROGRESS
Oct 15 07:42:18: ISDN Se6/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x01DD
Oct 15 07:42:20: ISDN Se6/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x01DD
Cause i = 0x80E0 - Mandatory information element missing
Oct 15 07:42:20: ISDN Se6/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x81DD
Cause i = 0x8190 - Normal call clearing
Oct 15 07:42:20: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x81DD calltype 2 CALL_CLEARED
Oct 15 07:42:20: ISDN Se6/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x01DD
========================RouterB=========================================================================
Oct 15 09:42:01: ISDN BR2/0 Q931: RX <- SETUP pd = 8 callref = 0x5B
Standard = CCITT
Channel ID i = 0x89
Called Party Number i = 0x81, '050170540'
Oct 15 09:42:01: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x209 calltype 2 HOST_INCOMING_CALL
Oct 15 09:42:01: ISDN BR2/0 Q931: TX -> SETUP_ACK pd = 8 callref = 0xDB
Channel ID i = 0x89
Oct 15 09:42:01: ISDN BR2/0 Q931: RX <- INFORMATION pd = 8 callref = 0x5B
Called Party Number i = 0x81, '1'
Oct 15 09:42:01: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x209 calltype 2 HOST_INFORMATION
Oct 15 09:42:05: ISDN BR2/0 Q931: TX -> ALERTING pd = 8 callref = 0xDB
Oct 15 09:42:18: ISDN BR2/0 Q931: TX -> FACILITY pd = 8 callref = 0xDB
Oct 15 09:42:18: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x209 calltype 2 HOST_CONNECT
Oct 15 09:42:18: ISDN BR2/0 Q931: TX -> CONNECT pd = 8 callref = 0xDB
Channel ID i = 0x89
Oct 15 09:42:18: ISDN BR2/0 Q931: RX <- STATUS pd = 8 callref = 0x5B
Cause i = 0x81E01C - Mandatory information element missing
Call State i = 0x04
Oct 15 09:42:18: ISDN BR2/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xDB
Cause i = 0x82E0 - Mandatory information element missing
Oct 15 09:42:18: ISDN BR2/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x5B
Oct 15 09:42:18: ISDN BR2/0 **ERROR**: Ux_BadMsg: Invalid Message for call state 11, call id 0x209, call ref 0xDB, event 0xF
Oct 15 09:42:18: ISDN BR2/0 Q931: TX -> STATUS pd = 8 callref = 0xDB
Cause i = 0x80E20F - Message not compatible with call state or not implemented
Call State i = 0x0C
Oct 15 09:42:20: ISDN BR2/0 Q931: RX <- RELEASE pd = 8 callref = 0x5B
Cause i = 0x81E0 - Mandatory information element missing
Oct 15 09:42:20: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x209 calltype 2 HOST_DISCONNECT_ACK
Oct 15 09:42:20: ISDN BR2/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xDB
"Cause i = 0x80E0 - Mandatory information element missing " I can see for all calls, not only when I am calling problem mobile net.
best regards
Can you post the configuration for Router B and the output of debug voip ccapi inout for good and bad calls?
Shelly
below data - 3 parts: routerB voip config, bad call debug, good call debug. best regards
###ROUTER B CONFIG START############################################################################################
class-map match-all voice
match access-group 111
policy-map voicepolicy
class voice
priority 220
class class-default
fair-queue
isdn switch-type basic-net3
fax interface-type fax-mail
mta receive maximum-recipients 0
interface BRI2/0
no ip address
isdn protocol-emulate network
isdn layer1-emulate network
isdn T306 60000
isdn skipsend-idverify
line-power
interface BRI2/1
no ip address
isdn T306 60000
line-power
interface Serial3/0
bandwidth 2048
ip address 10.10.250.109 255.255.255.252
ip accounting output-packets
no ip route-cache
no ip mroute-cache
service-policy output voicepolicy
no cdp enable
ip rtp priority 16384 16383 648
interface BRI4/0
no ip address
isdn T306 60000
line-power
interface BRI4/1
no ip address
isdn T306 60000
line-power
access-list 111 permit udp any any range 16384 32767
access-list 111 permit tcp any any range 16384 32767
access-list 111 permit ip any any precedence critical
call rsvp-sync
voice-port 2/0/0
compand-type a-law
cptone PL
voice-port 2/0/1
compand-type a-law
cptone PL
voice-port 4/0/0
compand-type a-law
cptone PL
voice-port 4/0/1
compand-type a-law
cptone PL
mgcp profile default
dial-peer voice 1 pots
destination-pattern 225760...
no digit-strip
direct-inward-dial
port 2/0/0
forward-digits all
no digit-strip
direct-inward-dial
port 2/0/1
forward-digits all
dial-peer voice 6 voip
destination-pattern 06........
session target ipv4:10.10.3.1
ip qos dscp cs5 media
ip qos dscp cs5 signaling
no vad
dial-peer voice 7 voip
destination-pattern 05........
no vad
dial-peer voice 10 pots
no digit-strip
direct-inward-dial
port 4/0/0
forward-digits all
dial-peer voice 11 pots
no digit-strip
direct-inward-dial
port 4/0/1
forward-digits all
###ROUTER B END#####################################################################################################
###BAD CALL START###################################################################################################
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x6370C1E4], magic[FACE0FFF]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDUtilAddDataToUsrContainer: container=0x6370C1E4, tagID=6, dataSize=16, instID=-1,modifier=1
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructInstanceTDObject: tdObject[0x63715174], nxtElem[0x0], magic[0xFACE0FFF] tagID[6], dataLen[16], modif[1]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToContainer: Adding tdObject[0x63715174] instID[-1] into container[0x6370C1E4]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDUtilAddDataToUsrContainer: container=0x6370C1E4, tagID=5, dataSize=276, instID=-1,modifier=1
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructInstanceTDObject: tdObject[0x63737604], nxtElem[0x0], magic[0xFACE0FFF] tagID[5], dataLen[276], modif[1]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToContainer: Adding tdObject[0x63737604] instID[-1] into container[0x6370C1E4]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
Oct 15 22:16:56: cc_api_call_setup_ind:
Oct 15 22:16:56: cisco-username=
Oct 15 22:16:56: ----- ccCallInfo IE subfields -----
Oct 15 22:16:56: cisco-ani=225760101
Oct 15 22:16:56: cisco-anitype=0
Oct 15 22:16:56: cisco-aniplan=1
Oct 15 22:16:56: cisco-anipi=0
Oct 15 22:16:56: cisco-anisi=0
Oct 15 22:16:56: dest=0501705401
Oct 15 22:16:56: cisco-desttype=0
Oct 15 22:16:56: cisco-destplan=1
Oct 15 22:16:56: cisco-rdn=
Oct 15 22:16:56: cisco-rdntype=-1
Oct 15 22:16:56: cisco-rdnplan=-1
Oct 15 22:16:56: cisco-rdnpi=-1
Oct 15 22:16:56: cisco-rdnsi=-1
Oct 15 22:16:56: cisco-redirectreason=-1
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: (vdbPtr=0x631E5194, callInfo={called=0501705401,called_oct3=0x81,calling=225760101,calling_oct3=0x81,calling_oct3a=0x0,calling_xlated=false,subscriber_type_str=RegularLine,fdest=1,peer_tag=1, prog_ind=0,callingIE_present 1, src_route_label=, tgt_route_label= clid_transparent=0},callID=0x63433040)
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: type 6 , prot 0
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
Oct 15 22:16:56: ccCheckClipClir: calling number is: "225760101", calling oct3a is: 0x0
Oct 15 22:16:56: Calling Party number is User Provided
Oct 15 22:16:56: Leaving ccCheckClipClir
calling oct3 is: 0x81
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: Increment call volume: 0
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: current call volume: 1
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: entry's incoming TRUE.
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: is_incoming is TRUE
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructHashProfileTab: profileTable[0x6370DDAC], numBuckets[11], numEntries[0]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6370DDAC] with objects in container[0x6370C1E4]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[5] for the tag[6]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x6370DDAC], tdObject[0x63715174]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[0] for the tag[5]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x6370DDAC], tdObject[0x63737604]
Oct 15 22:16:56: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6370DDAC], numBuckets[11], numEntries[2]
Oct 15 22:16:56: Bucket { 0 } ------>0x63737604[0x0,t-5,l-276,d-0x63737624,m-1,u-350604,g-FACE0FFF]
Oct 15 22:16:56:
Oct 15 22:16:56: Bucket { 5 } ------>0x63715174[0x0,t-6,l-16,d-0x63715194,m-1,u-350604,g-FACE0FFF]
Oct 15 22:16:56:
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x6370C1E4]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: not the VoIP or MMoIP
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x72F, mask=2
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x72F, mask=2 flag=1
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByRef: No tdObject found in profileTable for tagID[26] of callID[1839]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x72F, mask=1 flag=1
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x72F, mask=1
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1839], tagID[17], instID[-1]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[17] of callID[1839]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1839], tagID[18], instID[-1]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[18] of callID[1839]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1839], tagID[15], instID[-1]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[15] of callID[1839]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1839], tagID[16], instID[-1]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[16] of callID[1839]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1839], tagID[23], instID[-1]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[23] of callID[1839]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1839], tagID[21], instID[-1]
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[21] of callID[1839]
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/cc_process_call_setup_ind: (event=0x631A5110)
Oct 15 22:16:56: //1839/E30B0455887A/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 1839 with tag 1 to app "DEFAULT"
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(24=CC_EV_CALL_SETUP_IND), cid(1839), disp(0)
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(1839), disp(0)
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/SSAPP:-1:-1/ssaCallSetupInd:
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccCallSetContext: (callID=0x72F, context=0x6376478C)
Oct 15 22:16:56: //1839/E30B0455887A/SSAPP:1:-1/ssaCallSetupInd: cid(1839), st(SSA_CS_MAPPING),oldst(0), ev(24)ev->e.evCallSetupInd.nCallInfo.finalDestFlag = 1
Oct 15 22:16:56: //1839/E30B0455887A/SSAPP:1:-1/ssaCallSetupInd: src route label=, tgt route label= tg_label_flag 0x0
Oct 15 22:16:56: //1839/E30B0455887A/SSAPP:1:-1/ssaCallSetupInd: finalDest cllng(225760101), clled(0501705401) tgt_route_label()tg_label_flag 0x0
Oct 15 22:16:56: //1839/E30B0455887A/SSAPP:1:-1/ssaCallSetupInd: cid(1839), st(SSA_CS_CALL_SETTING),oldst(0), ev(24)dpMatchPeersMoreArg result= 0
Oct 15 22:16:56: //1839/E30B0455887A/SSAPP:1:-1/ssaDebugPeers: ssaSetupPeer cid(1839) peer list: tag(7) called number (0501705401) tag(224) called number (0501705401)
Oct 15 22:16:56: //1839/E30B0455887A/SSAPP:1:-1/ssaSetupPeer: dialpeer tags in rotary= 7 224
Oct 15 22:16:56: //1839/E30B0455887A/SSAPP:1:-1/ssaSetupPeer: cid(1839), destPat(0501705401), matched(2), prefix(), peer(63491868), peer->encapType (2)
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/cc_can_gateway: Call legs: In=6, Out=1
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest: (Inbound call = 0x72F, outbound peer =7, dest=,
params=0x631C0AE0 mode=0, *callID=0x631C1074, prog_ind = 0callingIE_present 1)
Oct 15 22:16:56: //1839/E30B0455887A/CCAPI/ccCallSetupRequest:
Oct 15 22:16:56: ccCallSetupRequest numbering_type 0x81
Oct 15 22:16:56: ccCallSetupRequest: calling number is:225760101
Oct 15 22:16:56: //1839/E30B0455887A/CCAPI/ccCallSetupRequest: calling oct3a is:0x0
Oct 15 22:16:56: //1839/E30B0455887A/CCAPI/ccCallSetupRequest: after ccCheckClipClir - calling oct3a is:0x0
Oct 15 22:16:56: //1839/E30B0455887A/CCAPI/ccCallSetupRequest: dest pattern 05........, called 0501705401, digit_strip 0
Oct 15 22:16:56: callingNumber=225760101, calledNumber=0501705401, redirectNumber= display_info= calling_oct3a=0
Oct 15 22:16:56: accountNumber=, finalDestFlag=1,
guid=e30b.0455.dfb1.11d6.887a.b975.8016.80b1
Oct 15 22:16:56: peer_tag=7
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate: (vdbPtr=0x62FF69D4, dest=, callParams={called=0501705401,called_oct3=0x81, calling=225760101,calling_oct3=0x81, calling_oct3a= 0x0, calling_xlated=false, subscriber_type_str=RegularLine, fdest=1, voice_peer_tag=7},mode=0x0)
Oct 15 22:16:56: ccIFCallSetupRequestPrivate: src route label tgt route label tg_label_flag 0x0
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate: vdbPtr type = 1
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate: (vdbPtr=0x62FF69D4, dest=, callParams={called=0501705401, called_oct3 0x81, calling=225760101,calling_oct3 0x81, calling_oct3a 0x0, calling_xlated=false, fdest=1, voice_peer_tag=7}, mode=0x0, xltrc=-5)
Oct 15 22:16:56: //1840/E30B0455887A/CCAPI/cc_insert_call_entry: not incoming entry
Oct 15 22:16:56: //1840/E30B0455887A/CCAPI/cc_insert_call_entry: entry's incoming FALSE.
Oct 15 22:16:56: //1840/E30B0455887A/CCAPI/cc_insert_call_entry: is_incoming is FALSE
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccSaveDialpeerTag: (callID=0x72F, dialpeer_tag=7)
Oct 15 22:16:56: //1840/xxxxxxxxxxxx/CCAPI/ccCallSetContext: (callID=0x730, context=0x634719AC)
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/ccCallReportDigits: (callID=0x72F, enable=0x0)
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done: (vdbPtr=0x631E5194, callID=0x72F, disp=0)
Oct 15 22:16:56: //1839/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(54=CC_EV_CALL_REPORT_DIGITS_DONE), cid(1839), disp(0)
Oct 15 22:16:56: //1839/E30B0455887A/SSAPP:1:-1/ssaTraceSct: cid(1839)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_REPORT_DIGITS_DONE)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(1)fDest(1)
Oct 15 22:16:56: //1839/E30B0455887A/SSAPP:1:-1/ssaTraceSct: -cid2(1840)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
Oct 15 22:16:56: //1839/E30B0455887A/SSAPP:1:-1/ssaDebugPeers: ssaReportDigitsDone cid(1839) peer list: tag(224) called number (0501705401)
Oct 15 22:16:56: //1839/E30B0455887A/SSAPP:1:-1/ssaReportDigitsDone: callid=1839 Reporting disabled.
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data: data_mode=0x10082
Oct 15 22:16:56: //1840/xxxxxxxxxxxx/CCAPI/cc_api_get_ic_leg_obtained_numbers: callID=0x730
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: remote IP is 10.10.3.1
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: hwidb is Serial3/1
Oct 15 22:16:56: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: added for entry: 12, voip: 12, mmoip: 0
Oct 15 22:16:56: //1840/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x730, mask=2
Oct 15 22:16:56: //1840/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x730, mask=2 flag=1
Oct 15 22:16:56: //1840/E30B0455887A/CCAPI/ccTDPvtProfileTableObjectAccessManager: No profileTable set for callID[1840]
Oct 15 22:16:56: //1840/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByRef: No tdObject found in profileTable for tagID[26] of callID[1840]
Oct 15 22:16:56: //1840/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x730, mask=1 flag=1
Oct 15 22:16:56: //1840/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x730, mask=1
Oct 15 22:16:56: //1840/xxxxxxxxxxxx/CCAPI/ccTDUtilGetInstanceCount: For tagID[1] of callID[1840]
Oct 15 22:16:56: //1840/xxxxxxxxxxxx/CCAPI/ccTDUtilGetInstanceCount: For tagID[2] of callID[1840]
Oct 15 22:17:00: //1840/xxxxxxxxxxxx/CCAPI/cc_api_call_alert: (vdbPtr=0x62FF69D4, callID=0x730, prog_ind=0x0, sig_ind=0x1)
Oct 15 22:17:00: //1840/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(7=CC_EV_CALL_ALERT), cid(1840), disp(0)
Oct 15 22:17:00: //1840/E30B0455887A/SSAPP:0:-1/ssaTraceSct: cid(1840)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_ALERT)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(0)fDest(0)
Oct 15 22:17:00: //1840/E30B0455887A/SSAPP:0:-1/ssaTraceSct: -cid2(1839)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
Oct 15 22:17:00: //1839/E30B0455887A/SSAPP:1:-1/ssaAlert:
Oct 15 22:17:00: //1839/xxxxxxxxxxxx/CCAPI/ccGetDialpeerTag: (callID=0x72F)
Oct 15 22:17:00: //1839/xxxxxxxxxxxx/CCAPI/ccCallAlert: (callID=0x72F, prog_ind=0x0, sig_ind=0x1)
Oct 15 22:17:20: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63725910], magic[FACE0FFF]
Oct 15 22:17:20: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructHashProfileTab: profileTable[0x63749608], numBuckets[11], numEntries[0]
Oct 15 22:17:20: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:17:20: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x63749608] with objects in container[0x63725910]
Oct 15 22:17:20: ccTDUtilDumpAllElemInProfileTab: profileTable[0x63749608], numBuckets[11], numEntries[0]
Oct 15 22:17:20: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63725910]
Oct 15 22:17:20: //1840/xxxxxxxxxxxx/CCAPI/cc_api_call_cut_progress: (vdbPtr=0x62FF69D4, callID=0x730, prog_ind=0x8, sig_ind=0x1)
Oct 15 22:17:20: //1840/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(22=CC_EV_CALL_PROGRESS), cid(1840), disp(0)
Oct 15 22:17:20: //1840/E30B0455887A/SSAPP:0:-1/ssaTraceSct: cid(1840)st(SSA_CS_ALERT_RCVD)ev(SSA_EV_CALL_PROGRESS)
oldst(SSA_CS_CALL_SETTING)cfid(-1)csize(0)in(0)fDest(0)
Oct 15 22:17:20: //1840/E30B0455887A/SSAPP:0:-1/ssaTraceSct: -cid2(1839)st2(SSA_CS_ALERT_RCVD)oldst2(SSA_CS_CALL_SETTING)
Oct 15 22:17:20: //1839/E30B0455887A/SSAPP:1:-1/ssaCutProgress:
Oct 15 22:17:20: //1839/xxxxxxxxxxxx/CCAPI/ccGetDialpeerTag: (callID=0x72F)
Oct 15 22:17:20: //1839/xxxxxxxxxxxx/CCAPI/ccCallCutProgress: (callID=0x72F, prog_ind=0x8, sig_ind=0x1)
Oct 15 22:17:20: //1839/xxxxxxxxxxxx/CCAPI/ccConferenceCreate: (confID=0x631C1184, callID1=0x72F, callID2=0x730, tag=0x0)
Oct 15 22:17:20: //1840/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done: (confID=0x2A8, srcIF=0x62FF69D4, srcCallID=0x730, dstCallID=0x72F, disposition=0, tag=0x0)
Oct 15 22:17:20: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x62FE6688], magic[FACE0FFF]
Oct 15 22:17:20: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6370DDAC] with objects in container[0x62FE6688]
Oct 15 22:17:20: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6370DDAC], numBuckets[11], numEntries[2]
Oct 15 22:17:20: Bucket { 0 } ------>0x63737604[0x0,t-5,l-276,d-0x63737624,m-1,u-350604,g-FACE0FFF]
Oct 15 22:17:20:
Oct 15 22:17:20: Bucket { 5 } ------>0x63715174[0x0,t-6,l-16,d-0x63715194,m-2,u-350604,g-FACE0FFF]
Oct 15 22:17:20:
Oct 15 22:17:20: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x62FE6688]
Oct 15 22:17:20: //1839/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done: (confID=0x2A8, srcIF=0x631E5194, srcCallID=0x72F, dstCallID=0x730, disposition=0, tag=0x0)
Oct 15 22:17:20: //1839/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (dstVdbPtr=0x62FF69D4, dstCallId=0x730, srcCallId=0x72F,
caps={codec=0x2EBFB, fax_rate=0xBF, vad=0x3, modem=0x2
codec_bytes=80, signal_type=3})
Oct 15 22:17:20: //1839/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (Playout: mode 0, initial 60,min 40, max 300)
Oct 15 22:17:20: //1839/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(29=CC_EV_CONF_CREATE_DONE), cid(1839), disp(0)
Oct 15 22:17:20: //1839/E30B0455887A/SSAPP:1:680/ssaTraceSct: cid(1839)st(SSA_CS_CONFERENCING_PROGRESS)ev(SSA_EV_CONF_CREATE_DONE)
oldst(SSA_CS_CALL_SETTING)cfid(680)csize(0)in(1)fDest(1)
Oct 15 22:17:20: //1839/E30B0455887A/SSAPP:1:680/ssaTraceSct: -cid2(1840)st2(SSA_CS_CONFERENCING_PROGRESS)oldst2(SSA_CS_ALERT_RCVD)
Oct 15 22:17:20: //1840/E30B0455887A/SSAPP:0:680/ssaConfCreateDoneAlert:
Oct 15 22:17:20: //1840/E30B0455887A/SSAPP:0:680/ssaConfCreateDoneAlert: Other call leg not found
Oct 15 22:17:20: //-1/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done: (event=0x631A7C30)
Oct 15 22:17:21: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x6370DF88], magic[FACE0FFF]
Oct 15 22:17:21: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:17:21: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x63749608] with objects in container[0x6370DF88]
Oct 15 22:17:21: ccTDUtilDumpAllElemInProfileTab: profileTable[0x63749608], numBuckets[11], numEntries[0]
Oct 15 22:17:21: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x6370DF88]
Oct 15 22:17:21: //1840/xxxxxxxxxxxx/CCAPI/cc_api_call_cut_progress: (vdbPtr=0x62FF69D4, callID=0x730, prog_ind=0x2, sig_ind=0x1)
Oct 15 22:17:21: //1840/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(22=CC_EV_CALL_PROGRESS), cid(1840), disp(0)
Oct 15 22:17:21: //1840/E30B0455887A/SSAPP:0:680/ssaTraceSct: cid(1840)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_PROGRESS)
oldst(SSA_CS_ALERT_RCVD)cfid(680)csize(0)in(0)fDest(0)
Oct 15 22:17:21: //1840/E30B0455887A/SSAPP:0:680/ssaTraceSct: -cid2(1839)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCING_PROGRESS)
Oct 15 22:17:21: //1839/E30B0455887A/SSAPP:1:680/ssaProgIndProgress:
Oct 15 22:17:21: //1839/xxxxxxxxxxxx/CCAPI/ccGetDialpeerTag: (callID=0x72F)
Oct 15 22:17:21: //1839/xxxxxxxxxxxx/CCAPI/ccCallProgIndProgress: (callID=0x72F)
Oct 15 22:17:21: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63725910], magic[FACE0FFF]
Oct 15 22:17:21: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6370DDAC] with objects in container[0x63725910]
Oct 15 22:17:21: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6370DDAC], numBuckets[11], numEntries[2]
Oct 15 22:17:21: Bucket { 0 } ------>0x63737604[0x0,t-5,l-276,d-0x63737624,m-1,u-350604,g-FACE0FFF]
Oct 15 22:17:21:
Oct 15 22:17:21: Bucket { 5 } ------>0x63715174[0x0,t-6,l-16,d-0x63715194,m-2,u-350604,g-FACE0FFF]
Oct 15 22:17:21:
Oct 15 22:17:21: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63725910]
Oct 15 22:17:22: //1840/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (dstVdbPtr=0x631E5194, dstCallId=0x72F, srcCallId=0x730,
caps={codec=0x4, fax_rate=0x2, vad=0x1, modem=0x0
codec_bytes=20, signal_type=2})
Oct 15 22:17:22: //1840/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (Playout: mode 0, initial 60,min 40, max 300)
Oct 15 22:17:22: //1840/xxxxxxxxxxxx/CCAPI/cc_api_caps_ack: (dstVdbPtr=0x631E5194, dstCallId=0x72F, srcCallId=0x730,
codec_bytes=20, signal_type=2, seq_num_start=7348})
Oct 15 22:17:22: //1840/xxxxxxxxxxxx/CCAPI/cc_api_call_facility: (vdbPtr=0x62FF69D4, callID=0x730
Oct 15 22:17:22: //1839/xxxxxxxxxxxx/CCAPI/cc_api_caps_ack: (dstVdbPtr=0x62FF69D4, dstCallId=0x730, srcCallId=0x72F,
Oct 15 22:17:22: //1839/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode_event: callID=0x72F
Oct 15 22:17:22: //1839/E30B0455887A/CCAPI/cc_api_voice_mode_event: Call Pointer =6376478C
Oct 15 22:17:22: //1840/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(14=CC_EV_CALL_FACILITY), cid(1840), disp(0)
Oct 15 22:17:22: //1840/E30B0455887A/SSAPP:0:680/ssaTraceSct: cid(1840)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_FACILITY)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(680)csize(0)in(0)fDest(0)
Oct 15 22:17:22: //1840/E30B0455887A/SSAPP:0:680/ssaTraceSct: -cid2(1839)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCING_PROGRESS)
Oct 15 22:17:22: //1839/E30B0455887A/SSAPP:1:680/ssaFacility:
Oct 15 22:17:22: //1839/xxxxxxxxxxxx/CCAPI/ccCallFacility: (callID=0x72F)
Oct 15 22:17:22: //1839/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(52=CC_EV_VOICE_MODE_DONE), cid(1839), disp(0)
Oct 15 22:17:22: //1839/E30B0455887A/SSAPP:1:680/ssaTraceSct: cid(1839)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_VOICE_MODE_DONE)
oldst(SSA_CS_CONFERENCING_PROGRESS)cfid(680)csize(0)in(1)fDest(1)
Oct 15 22:17:22: //1839/E30B0455887A/SSAPP:1:680/ssaTraceSct: -cid2(1840)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:17:22: //1839/E30B0455887A/SSAPP:1:680/ssaIgnore: cid(1839), st(SSA_CS_CONFERENCED_ALERT),oldst(4), ev(52)
Oct 15 22:17:22: //1840/xxxxxxxxxxxx/CCAPI/cc_api_call_connected: (vdbPtr=0x62FF69D4, callID=0x730), prog_ind = 2
Oct 15 22:17:22: //1840/E30B0455887A/CCAPI/cc_api_call_connected: setting callEntry->connected to TRUE
Oct 15 22:17:22: //1840/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(8=CC_EV_CALL_CONNECTED), cid(1840), disp(0)
Oct 15 22:17:22: //1840/E30B0455887A/SSAPP:0:680/ssaTraceSct: cid(1840)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_CONNECTED)
Oct 15 22:17:22: //1840/E30B0455887A/SSAPP:0:680/ssaTraceSct: -cid2(1839)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:17:22: //1840/E30B0455887A/SSAPP:0:680/ssaConnectAlert: .
Oct 15 22:17:22: //1839/xxxxxxxxxxxx/CCAPI/ccGetDialpeerTag: (callID=0x72F)
Oct 15 22:17:22: //1839/xxxxxxxxxxxx/CCAPI/ccCallConnect: (callID=0x72F), prog_ind = 2
Oct 15 22:17:22: //1839/E30B0455887A/CCAPI/ccCallConnect: setting callEntry->connected to TRUE
Oct 15 22:17:22: //1839/E30B0455887A/SSAPP:1:680/ssaDebugPeers: ssaFlushPeerTagQueue cid(1839) peer list: tag(224) called number (0501705401)
foR-1-1#
foR-1-1#
foR-1-1#
foR-1-1#
foR-1-1#
foR-1-1#
foR-1-1#
foR-1-1#
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63715664], magic[FACE0FFF]
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6370DDAC] with objects in container[0x63715664]
Oct 15 22:17:30: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6370DDAC], numBuckets[11], numEntries[2]
Oct 15 22:17:30: Bucket { 0 } ------>0x63737604[0x0,t-5,l-276,d-0x63737624,m-1,u-350604,g-FACE0FFF]
Oct 15 22:17:30:
Oct 15 22:17:30: Bucket { 5 } ------>0x63715174[0x0,t-6,l-16,d-0x63715194,m-2,u-350604,g-FACE0FFF]
Oct 15 22:17:30:
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63715664]
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnected: (vdbPtr=0x631E5194, callID=0x72F, cause=0x60)
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(11=CC_EV_CALL_DISCONNECTED), cid(1839), disp(0)
Oct 15 22:17:30: //1839/E30B0455887A/SSAPP:1:680/ssaTraceSct: cid(1839)st(SSA_CS_ACTIVE)ev(SSA_EV_CALL_DISCONNECTED)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(680)csize(0)in(1)fDest(1)
Oct 15 22:17:30: //1839/E30B0455887A/SSAPP:1:680/ssaTraceSct: -cid2(1840)st2(SSA_CS_ACTIVE)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:17:30: ssa: Disconnected cid(1839) state(5) cause(0x60)
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy: (confID=0x2A8, tag=0x0)
Oct 15 22:17:30: //1840/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done: (confID=0x2A8, srcIF=0x62FF69D4, srcCallID=0x730, dstCallID=0x72F, disposition=0 tag=0x0)
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done: (confID=0x2A8, srcIF=0x631E5194, srcCallID=0x72F, dstCallID=0x730, disposition=0 tag=0x0)
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(30=CC_EV_CONF_DESTROY_DONE), cid(1839), disp(0)
Oct 15 22:17:30: //1839/E30B0455887A/SSAPP:1:-1/ssaTraceSct: cid(1839)st(SSA_CS_CONF_DESTROYING)ev(SSA_EV_CONF_DESTROY_DONE)
oldst(SSA_CS_ACTIVE)cfid(-1)csize(0)in(1)fDest(1)
Oct 15 22:17:30: //1839/E30B0455887A/SSAPP:1:-1/ssaTraceSct: -cid2(1840)st2(SSA_CS_CONF_DESTROYING)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:17:30: //1840/E30B0455887A/SSAPP:0:680/ssaConfDestroyDone:
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: (callID=0x72F, cause=0x60 tag=0x0)
Oct 15 22:17:30: //1839/E30B0455887A/CCAPI/ccCallDisconnect: existing_cause = 0x60, new_cause = 0x60
Oct 15 22:17:30: //1839/E30B0455887A/CCAPI/ccCallDisconnect: using the existing_cause 0x60
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/CCAPI/cc_api_get_transfer_info: (callID=0x72F)
Oct 15 22:17:30: //1840/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: (callID=0x730, cause=0x60 tag=0x0)
Oct 15 22:17:30: //1840/E30B0455887A/CCAPI/ccCallDisconnect: existing_cause = 0x0, new_cause = 0x60
Oct 15 22:17:30: //1840/xxxxxxxxxxxx/CCAPI/cc_api_get_transfer_info: (callID=0x730)
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x72F, mask=1
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1839], tagID[22], instID[-1]
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[22] of callID[1839]
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x72F, mask=2
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: not the VoIP or MMoIP
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done: (vdbPtr=0x631E5194, callID=0x72F, disp=0, tag=0x0)
Oct 15 22:17:30: //1839/E30B0455887A/CCAPI/cc_delete_call_entry: ccFreeRawMsgInfo(0x631B1B74)
Oct 15 22:17:30: //1839/E30B0455887A/CCAPI/cc_delete_call_entry: Decrement call volume counter 1
Oct 15 22:17:30: //1839/E30B0455887A/CCAPI/cc_delete_call_entry: current call volume: 0
Oct 15 22:17:30: //1839/E30B0455887A/CCAPI/cc_delete_call_entry: entry's incoming TRUE.
Oct 15 22:17:30: //1839/E30B0455887A/CCAPI/cc_delete_call_entry: is_incoming is TRUE
Oct 15 22:17:30: //1839/E30B0455887A/CCAPI/cc_delete_call_entry: Deleting profileTable[0x6370DDAC]
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDHashProfileTab: Destructor Profile Table (0x6370DDAC)
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructInstanceTDObject: tdObject[0x63737604] tagID[5]
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructInstanceTDObject: tdObject[0x63715174] tagID[6]
Oct 15 22:17:30: //1839/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(1839), disp(0)
Oct 15 22:17:30: //1839/E30B0455887A/SSAPP:1:-1/ssaTraceSct: cid(1839)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_CONF_DESTROYING)cfid(-1)csize(0)in(1)fDest(1)
Oct 15 22:17:30: //1839/E30B0455887A/SSAPP:1:-1/ssaTraceSct: -cid2(1840)st2(SSA_CS_DISCONNECTING)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:17:30: //1839/E30B0455887A/SSAPP:1:-1/ssaDisconnectDone:
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif: expect factor = 0
Oct 15 22:17:30: //1840/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x730, mask=1
Oct 15 22:17:30: //1840/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x730, mask=2
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: the remote IP is 10.10.3.1
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: hwidb is Serial3/1
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: reduce callnum of entry: 11, voip: 11, mmoip: 0
Oct 15 22:17:30: //1840/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done: (vdbPtr=0x62FF69D4, callID=0x730, disp=0, tag=0x0)
Oct 15 22:17:30: //1840/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByRef: No tdObject found in profileTable for tagID[6] of callID[1840]
Oct 15 22:17:30: //1840/E30B0455887A/CCAPI/cc_delete_call_entry: not incoming entry
Oct 15 22:17:30: //1840/E30B0455887A/CCAPI/cc_delete_call_entry: entry's incoming FALSE.
Oct 15 22:17:30: //1840/E30B0455887A/CCAPI/cc_delete_call_entry: is_incoming is FALSE
Oct 15 22:17:30: //1840/E30B0455887A/CCAPI/cc_delete_call_entry: Deleting profileTable[0x63749608]
Oct 15 22:17:30: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDHashProfileTab: Destructor Profile Table (0x63749608)
Oct 15 22:17:30: //1840/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(1840), disp(0)
Oct 15 22:17:30: //1840/E30B0455887A/SSAPP:0:-1/ssaTraceSct: cid(1840)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(-1)csize(1)in(0)fDest(0)
Oct 15 22:17:30: //1840/E30B0455887A/SSAPP:0:-1/ssaDisconnectDone:
####BAD CALL END###########################################################################################
####GOOD CALL START########################################################################################
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63759298], magic[FACE0FFF]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDUtilAddDataToUsrContainer: container=0x63759298, tagID=6, dataSize=16, instID=-1,modifier=1
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructInstanceTDObject: tdObject[0x6370AD60], nxtElem[0x0], magic[0xFACE0FFF] tagID[6], dataLen[16], modif[1]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToContainer: Adding tdObject[0x6370AD60] instID[-1] into container[0x63759298]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDUtilAddDataToUsrContainer: container=0x63759298, tagID=5, dataSize=276, instID=-1,modifier=1
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructInstanceTDObject: tdObject[0x63152460], nxtElem[0x0], magic[0xFACE0FFF] tagID[5], dataLen[276], modif[1]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToContainer: Adding tdObject[0x63152460] instID[-1] into container[0x63759298]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
Oct 15 22:17:35: cc_api_call_setup_ind:
Oct 15 22:17:35: cisco-username=
Oct 15 22:17:35: ----- ccCallInfo IE subfields -----
Oct 15 22:17:35: cisco-ani=225760405
Oct 15 22:17:35: cisco-anitype=0
Oct 15 22:17:35: cisco-aniplan=1
Oct 15 22:17:35: cisco-anipi=0
Oct 15 22:17:35: cisco-anisi=0
Oct 15 22:17:35: dest=0605655258
Oct 15 22:17:35: cisco-desttype=0
Oct 15 22:17:35: cisco-destplan=1
Oct 15 22:17:35: cisco-rdn=
Oct 15 22:17:35: cisco-rdntype=-1
Oct 15 22:17:35: cisco-rdnplan=-1
Oct 15 22:17:35: cisco-rdnpi=-1
Oct 15 22:17:35: cisco-rdnsi=-1
Oct 15 22:17:35: cisco-redirectreason=-1
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: (vdbPtr=0x631E5194, callInfo={called=0605655258,called_oct3=0x81,calling=225760405,calling_oct3=0x81,calling_oct3a=0x0,calling_xlated=false,subscriber_type_str=RegularLine,fdest=1,peer_tag=1, prog_ind=0,callingIE_present 1, src_route_label=, tgt_route_label= clid_transparent=0},callID=0x63433040)
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: type 6 , prot 0
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
Oct 15 22:17:35: ccCheckClipClir: calling number is: "225760405", calling oct3a is: 0x0
Oct 15 22:17:35: Calling Party number is User Provided
Oct 15 22:17:35: Leaving ccCheckClipClir
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: Increment call volume: 0
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: current call volume: 1
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: entry's incoming TRUE.
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: is_incoming is TRUE
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructHashProfileTab: profileTable[0x636F40E0], numBuckets[11], numEntries[0]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x636F40E0] with objects in container[0x63759298]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[5] for the tag[6]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x636F40E0], tdObject[0x6370AD60]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[0] for the tag[5]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x636F40E0], tdObject[0x63152460]
Oct 15 22:17:35: ccTDUtilDumpAllElemInProfileTab: profileTable[0x636F40E0], numBuckets[11], numEntries[2]
Oct 15 22:17:35: Bucket { 0 } ------>0x63152460[0x0,t-5,l-276,d-0x63152480,m-1,u-350643,g-FACE0FFF]
Oct 15 22:17:35:
Oct 15 22:17:35: Bucket { 5 } ------>0x6370AD60[0x0,t-6,l-16,d-0x6370AD80,m-1,u-350643,g-FACE0FFF]
Oct 15 22:17:35:
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63759298]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: not the VoIP or MMoIP
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x731, mask=2
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x731, mask=2 flag=1
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByRef: No tdObject found in profileTable for tagID[26] of callID[1841]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x731, mask=1 flag=1
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x731, mask=1
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1841], tagID[17], instID[-1]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[17] of callID[1841]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1841], tagID[18], instID[-1]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[18] of callID[1841]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1841], tagID[15], instID[-1]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[15] of callID[1841]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1841], tagID[16], instID[-1]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[16] of callID[1841]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1841], tagID[23], instID[-1]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[23] of callID[1841]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1841], tagID[21], instID[-1]
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[21] of callID[1841]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/cc_process_call_setup_ind: (event=0x631ABCE0)
Oct 15 22:17:35: //1841/FA773F1A887D/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 1841 with tag 1 to app "DEFAULT"
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(24=CC_EV_CALL_SETUP_IND), cid(1841), disp(0)
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(1841), disp(0)
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/SSAPP:-1:-1/ssaCallSetupInd:
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccCallSetContext: (callID=0x731, context=0x636C55F8)
Oct 15 22:17:35: //1841/FA773F1A887D/SSAPP:1:-1/ssaCallSetupInd: cid(1841), st(SSA_CS_MAPPING),oldst(0), ev(24)ev->e.evCallSetupInd.nCallInfo.finalDestFlag = 1
Oct 15 22:17:35: //1841/FA773F1A887D/SSAPP:1:-1/ssaCallSetupInd: src route label=, tgt route label= tg_label_flag 0x0
Oct 15 22:17:35: //1841/FA773F1A887D/SSAPP:1:-1/ssaCallSetupInd: finalDest cllng(225760405), clled(0605655258) tgt_route_label()tg_label_flag 0x0
Oct 15 22:17:35: //1841/FA773F1A887D/SSAPP:1:-1/ssaCallSetupInd: cid(1841), st(SSA_CS_CALL_SETTING),oldst(0), ev(24)dpMatchPeersMoreArg result= 0
Oct 15 22:17:35: //1841/FA773F1A887D/SSAPP:1:-1/ssaDebugPeers: ssaSetupPeer cid(1841) peer list: tag(6) called number (0605655258) tag(224) called number (0605655258)
Oct 15 22:17:35: //1841/FA773F1A887D/SSAPP:1:-1/ssaSetupPeer: dialpeer tags in rotary= 6 224
Oct 15 22:17:35: //1841/FA773F1A887D/SSAPP:1:-1/ssaSetupPeer: cid(1841), destPat(0605655258), matched(2), prefix(), peer(634901A4), peer->encapType (2)
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/cc_can_gateway: Call legs: In=6, Out=1
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest: (Inbound call = 0x731, outbound peer =6, dest=,
Oct 15 22:17:35: //1841/FA773F1A887D/CCAPI/ccCallSetupRequest:
Oct 15 22:17:35: ccCallSetupRequest numbering_type 0x81
Oct 15 22:17:35: ccCallSetupRequest: calling number is:225760405
Oct 15 22:17:35: //1841/FA773F1A887D/CCAPI/ccCallSetupRequest: calling oct3a is:0x0
Oct 15 22:17:35: //1841/FA773F1A887D/CCAPI/ccCallSetupRequest: after ccCheckClipClir - calling oct3a is:0x0
Oct 15 22:17:35: //1841/FA773F1A887D/CCAPI/ccCallSetupRequest: dest pattern 06........, called 0605655258, digit_strip 0
Oct 15 22:17:35: callingNumber=225760405, calledNumber=0605655258, redirectNumber= display_info= calling_oct3a=0
Oct 15 22:17:35: accountNumber=, finalDestFlag=1,
guid=fa77.3f1a.dfb1.11d6.887d.b975.8016.80b1
Oct 15 22:17:35: peer_tag=6
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate: (vdbPtr=0x62FF69D4, dest=, callParams={called=0605655258,called_oct3=0x81, calling=225760405,calling_oct3=0x81, calling_oct3a= 0x0, calling_xlated=false, subscriber_type_str=RegularLine, fdest=1, voice_peer_tag=6},mode=0x0)
Oct 15 22:17:35: ccIFCallSetupRequestPrivate: src route label tgt route label tg_label_flag 0x0
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate: vdbPtr type = 1
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate: (vdbPtr=0x62FF69D4, dest=, callParams={called=0605655258, called_oct3 0x81, calling=225760405,calling_oct3 0x81, calling_oct3a 0x0, calling_xlated=false, fdest=1, voice_peer_tag=6}, mode=0x0, xltrc=-5)
Oct 15 22:17:35: //1842/FA773F1A887D/CCAPI/cc_insert_call_entry: not incoming entry
Oct 15 22:17:35: //1842/FA773F1A887D/CCAPI/cc_insert_call_entry: entry's incoming FALSE.
Oct 15 22:17:35: //1842/FA773F1A887D/CCAPI/cc_insert_call_entry: is_incoming is FALSE
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccSaveDialpeerTag: (callID=0x731, dialpeer_tag=6)
Oct 15 22:17:35: //1842/xxxxxxxxxxxx/CCAPI/ccCallSetContext: (callID=0x732, context=0x6374E5E0)
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/ccCallReportDigits: (callID=0x731, enable=0x0)
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done: (vdbPtr=0x631E5194, callID=0x731, disp=0)
Oct 15 22:17:35: //1841/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(54=CC_EV_CALL_REPORT_DIGITS_DONE), cid(1841), disp(0)
Oct 15 22:17:35: //1841/FA773F1A887D/SSAPP:1:-1/ssaTraceSct: cid(1841)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_REPORT_DIGITS_DONE)
Oct 15 22:17:35: //1841/FA773F1A887D/SSAPP:1:-1/ssaTraceSct: -cid2(1842)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
Oct 15 22:17:35: //1841/FA773F1A887D/SSAPP:1:-1/ssaDebugPeers: ssaReportDigitsDone cid(1841) peer list: tag(224) called number (0605655258)
Oct 15 22:17:35: //1841/FA773F1A887D/SSAPP:1:-1/ssaReportDigitsDone: callid=1841 Reporting disabled.
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data: data_mode=0x10082
Oct 15 22:17:35: //1842/xxxxxxxxxxxx/CCAPI/cc_api_get_ic_leg_obtained_numbers: callID=0x732
Oct 15 22:17:35: //1842/xxxxxxxxxxxx/CCAPI/ccTDUtilGetInstanceCount: For tagID[1] of callID[1842]
Oct 15 22:17:35: //1842/FA773F1A887D/CCAPI/ccTDPvtProfileTableObjectAccessManager: No profileTable set for callID[1842]
Oct 15 22:17:35: //1842/xxxxxxxxxxxx/CCAPI/ccTDUtilGetInstanceCount: For tagID[2] of callID[1842]
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: remote IP is 10.10.3.1
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: hwidb is Serial3/0
Oct 15 22:17:35: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: added for entry: 8, voip: 8, mmoip: 0
Oct 15 22:17:35: //1842/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x732, mask=2
Oct 15 22:17:35: //1842/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x732, mask=2 flag=1
Oct 15 22:17:35: //1842/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByRef: No tdObject found in profileTable for tagID[26] of callID[1842]
Oct 15 22:17:35: //1842/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x732, mask=1 flag=1
Oct 15 22:17:35: //1842/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x732, mask=1
Oct 15 22:17:36: //1842/xxxxxxxxxxxx/CCAPI/cc_api_call_proceeding: (vdbPtr=0x62FF69D4, callID=0x732,
prog_ind=0x0)
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDUtilSetDataInstance: Setting data for callID[1842], tagID[5], instID[-1], data[0x62F73F28], dataSize[276]
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructInstanceTDObject: tdObject[0x63737604], nxtElem[0x0], magic[0xFACE0FFF] tagID[5], dataLen[276], modif[4]
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructHashProfileTab: profileTable[0x636C6FDC], numBuckets[11], numEntries[0]
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x636C6FDC], tdObject[0x63737604]
Oct 15 22:17:36: ccTDUtilDumpAllElemInProfileTab: profileTable[0x636C6FDC], numBuckets[11], numEntries[1]
Oct 15 22:17:36: Bucket { 0 } ------>0x63737604[0x0,t-5,l-276,d-0x63737624,m-4,u-350643,g-FACE0FFF]
Oct 15 22:17:36:
Oct 15 22:17:36: //1841/FA773F1A887D/CCAPI/cc_api_open_channel_ind: i/f type=6, srcCallID=732 (1842), dstCallId=731 (1841), channel_info ptr=62F73F28
Oct 15 22:17:36: //1842/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(21=CC_EV_CALL_PROCEEDING), cid(1842), disp(0)
Oct 15 22:17:36: //1842/FA773F1A887D/SSAPP:0:-1/ssaTraceSct: cid(1842)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING)
Oct 15 22:17:36: //1842/FA773F1A887D/SSAPP:0:-1/ssaTraceSct: -cid2(1841)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
Oct 15 22:17:36: //1842/FA773F1A887D/SSAPP:0:-1/ssaCallProc:
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/CCAPI/ccGetDialpeerTag: (callID=0x731)
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/CCAPI/ccCallProceeding: (callID=0x731, prog_ind=0x0)
Oct 15 22:17:36: //1842/FA773F1A887D/SSAPP:0:-1/ssaIgnore: cid(1842), st(SSA_CS_CALL_SETTING),oldst(1), ev(21)
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x636522F8], magic[FACE0FFF]
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x636C6FDC] with objects in container[0x636522F8]
Oct 15 22:17:36:
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x636522F8]
Oct 15 22:17:36: //1842/xxxxxxxxxxxx/CCAPI/cc_api_call_cut_progress: (vdbPtr=0x62FF69D4, callID=0x732, prog_ind=0x8, sig_ind=0x1)
Oct 15 22:17:36: //1842/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(22=CC_EV_CALL_PROGRESS), cid(1842), disp(0)
Oct 15 22:17:36: //1842/FA773F1A887D/SSAPP:0:-1/ssaTraceSct: cid(1842)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROGRESS)
Oct 15 22:17:36: //1841/FA773F1A887D/SSAPP:1:-1/ssaCutProgress:
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/CCAPI/ccCallCutProgress: (callID=0x731, prog_ind=0x8, sig_ind=0x1)
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/CCAPI/ccConferenceCreate: (confID=0x631C1184, callID1=0x731, callID2=0x732, tag=0x0)
Oct 15 22:17:36: //1842/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done: (confID=0x2A9, srcIF=0x62FF69D4, srcCallID=0x732, dstCallID=0x731, disposition=0, tag=0x0)
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63709E1C], magic[FACE0FFF]
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x636F40E0] with objects in container[0x63709E1C]
Oct 15 22:17:36: ccTDUtilDumpAllElemInProfileTab: profileTable[0x636F40E0], numBuckets[11], numEntries[2]
Oct 15 22:17:36: Bucket { 0 } ------>0x63152460[0x0,t-5,l-276,d-0x63152480,m-1,u-350643,g-FACE0FFF]
Oct 15 22:17:36:
Oct 15 22:17:36: Bucket { 5 } ------>0x6370AD60[0x0,t-6,l-16,d-0x6370AD80,m-2,u-350643,g-FACE0FFF]
Oct 15 22:17:36:
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63709E1C]
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done: (confID=0x2A9, srcIF=0x631E5194, srcCallID=0x731, dstCallID=0x732, disposition=0, tag=0x0)
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (dstVdbPtr=0x62FF69D4, dstCallId=0x732, srcCallId=0x731,
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (Playout: mode 0, initial 60,min 40, max 300)
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(29=CC_EV_CONF_CREATE_DONE), cid(1841), disp(0)
Oct 15 22:17:36: //1841/FA773F1A887D/SSAPP:1:681/ssaTraceSct: cid(1841)st(SSA_CS_CONFERENCING_PROGRESS)ev(SSA_EV_CONF_CREATE_DONE)
oldst(SSA_CS_CALL_SETTING)cfid(681)csize(0)in(1)fDest(1)
Oct 15 22:17:36: //1841/FA773F1A887D/SSAPP:1:681/ssaTraceSct: -cid2(1842)st2(SSA_CS_CONFERENCING_PROGRESS)oldst2(SSA_CS_CALL_SETTING)
Oct 15 22:17:36: //1842/FA773F1A887D/SSAPP:0:681/ssaConfCreateDoneAlert:
Oct 15 22:17:36: //1842/FA773F1A887D/SSAPP:0:681/ssaConfCreateDoneAlert: Other call leg not found
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done: (event=0x631AE0D0)
Oct 15 22:17:36: //1842/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (dstVdbPtr=0x631E5194, dstCallId=0x731, srcCallId=0x732,
Oct 15 22:17:36: //1842/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (Playout: mode 0, initial 60,min 40, max 300)
Oct 15 22:17:36: //1842/xxxxxxxxxxxx/CCAPI/cc_api_caps_ack: (dstVdbPtr=0x631E5194, dstCallId=0x731, srcCallId=0x732,
codec_bytes=20, signal_type=2, seq_num_start=7792})
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/CCAPI/cc_api_caps_ack: (dstVdbPtr=0x62FF69D4, dstCallId=0x732, srcCallId=0x731,
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode_event: callID=0x731
Oct 15 22:17:36: //1841/FA773F1A887D/CCAPI/cc_api_voice_mode_event: Call Pointer =636C55F8
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(52=CC_EV_VOICE_MODE_DONE), cid(1841), disp(679)
Oct 15 22:17:36: //1841/FA773F1A887D/SSAPP:1:681/ssaTraceSct: cid(1841)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_VOICE_MODE_DONE)
oldst(SSA_CS_CONFERENCING_PROGRESS)cfid(681)csize(0)in(1)fDest(1)
Oct 15 22:17:36: //1841/FA773F1A887D/SSAPP:1:681/ssaTraceSct: -cid2(1842)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CALL_SETTING)
Oct 15 22:17:36: //1841/FA773F1A887D/SSAPP:1:681/ssaIgnore: cid(1841), st(SSA_CS_CONFERENCED_ALERT),oldst(4), ev(52)
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63708264], magic[FACE0FFF]
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x636C6FDC] with objects in container[0x63708264]
Oct 15 22:17:36:
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63708264]
Oct 15 22:17:36: //1842/FA773F1A887D/SSAPP:0:681/ssaTraceSct: cid(1842)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_PROGRESS)
oldst(SSA_CS_CALL_SETTING)cfid(681)csize(0)in(0)fDest(0)
Oct 15 22:17:36: //1842/FA773F1A887D/SSAPP:0:681/ssaTraceSct: -cid2(1841)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:17:36: //1841/FA773F1A887D/SSAPP:1:681/ssaProgIndProgress:
Oct 15 22:17:36: //1841/xxxxxxxxxxxx/CCAPI/ccCallProgIndProgress: (callID=0x731)
Oct 15 22:17:36: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x636F40E0] with objects in container[0x636522F8]
Oct 15 22:17:36:
Oct 15 22:17:36:
Oct 15 22:17:40: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63710F74], magic[FACE0FFF]
Oct 15 22:17:40: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:17:40: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x636C6FDC] with objects in container[0x63710F74]
Oct 15 22:17:40: ccTDUtilDumpAllElemInProfileTab: profileTable[0x636C6FDC], numBuckets[11], numEntries[1]
Oct 15 22:17:40: Bucket { 0 } ------>0x63737604[0x0,t-5,l-276,d-0x63737624,m-4,u-350643,g-FACE0FFF]
Oct 15 22:17:40:
Oct 15 22:17:40: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63710F74]
Oct 15 22:17:40: //1842/xxxxxxxxxxxx/CCAPI/cc_api_call_cut_progress: (vdbPtr=0x62FF69D4, callID=0x732, prog_ind=0x8, sig_ind=0x1)
Oct 15 22:17:40: //1842/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(22=CC_EV_CALL_PROGRESS), cid(1842), disp(0)
Oct 15 22:17:40: //1842/FA773F1A887D/SSAPP:0:681/ssaTraceSct: cid(1842)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_PROGRESS)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(681)csize(0)in(0)fDest(0)
Oct 15 22:17:40: //1842/FA773F1A887D/SSAPP:0:681/ssaTraceSct: -cid2(1841)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:17:40: //1841/FA773F1A887D/SSAPP:1:681/ssaProgIndProgress:
Oct 15 22:17:40: //1841/xxxxxxxxxxxx/CCAPI/ccGetDialpeerTag: (callID=0x731)
Oct 15 22:17:40: //1841/xxxxxxxxxxxx/CCAPI/ccCallProgIndProgress: (callID=0x731)
Oct 15 22:17:40: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63152D40], magic[FACE0FFF]
Oct 15 22:17:40: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x636F40E0] with objects in container[0x63152D40]
Oct 15 22:17:40: ccTDUtilDumpAllElemInProfileTab: profileTable[0x636F40E0], numBuckets[11], numEntries[2]
Oct 15 22:17:40: Bucket { 0 } ------>0x63152460[0x0,t-5,l-276,d-0x63152480,m-1,u-350643,g-FACE0FFF]
Oct 15 22:17:40:
Oct 15 22:17:40: Bucket { 5 } ------>0x6370AD60[0x0,t-6,l-16,d-0x6370AD80,m-2,u-350643,g-FACE0FFF]
Oct 15 22:17:40:
Oct 15 22:17:40: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63152D40]
Oct 15 22:17:40: //1842/xxxxxxxxxxxx/CCAPI/cc_api_call_alert: (vdbPtr=0x62FF69D4, callID=0x732, prog_ind=0x0, sig_ind=0x1)
Oct 15 22:17:40: //1842/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(7=CC_EV_CALL_ALERT), cid(1842), disp(0)
Oct 15 22:17:40: //1842/FA773F1A887D/SSAPP:0:681/ssaTraceSct: cid(1842)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_ALERT)
Oct 15 22:17:40: //1841/FA773F1A887D/SSAPP:1:681/ssaAlertPass:
Oct 15 22:17:40: //1841/xxxxxxxxxxxx/CCAPI/ccCallAlert: (callID=0x731, prog_ind=0x0, sig_ind=0x1)
Oct 15 22:17:42: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x6370DDAC], magic[FACE0FFF]
Oct 15 22:17:42: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:17:42: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x636C6FDC] with objects in container[0x6370DDAC]
Oct 15 22:17:42: ccTDUtilDumpAllElemInProfileTab: profileTable[0x636C6FDC], numBuckets[11], numEntries[1]
Oct 15 22:17:42: Bucket { 0 } ------>0x63737604[0x0,t-5,l-276,d-0x63737624,m-4,u-350643,g-FACE0FFF]
Oct 15 22:17:42:
Oct 15 22:17:42: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x6370DDAC]
Oct 15 22:17:42: //1842/xxxxxxxxxxxx/CCAPI/cc_api_call_connected: (vdbPtr=0x62FF69D4, callID=0x732), prog_ind = 0
Oct 15 22:17:42: //1842/FA773F1A887D/CCAPI/cc_api_call_connected: setting callEntry->connected to TRUE
Oct 15 22:17:42: //1842/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(8=CC_EV_CALL_CONNECTED), cid(1842), disp(0)
Oct 15 22:17:42: //1842/FA773F1A887D/SSAPP:0:681/ssaTraceSct: cid(1842)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_CONNECTED)
Oct 15 22:17:42: //1842/FA773F1A887D/SSAPP:0:681/ssaTraceSct: -cid2(1841)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:17:42: //1842/FA773F1A887D/SSAPP:0:681/ssaConnectAlert: .
Oct 15 22:17:42: //1841/xxxxxxxxxxxx/CCAPI/ccGetDialpeerTag: (callID=0x731)
Oct 15 22:17:42: //1841/xxxxxxxxxxxx/CCAPI/ccCallConnect: (callID=0x731), prog_ind = 0
Oct 15 22:17:42: //1841/FA773F1A887D/CCAPI/ccCallConnect: setting callEntry->connected to TRUE
Oct 15 22:17:42: //1841/FA773F1A887D/SSAPP:1:681/ssaDebugPeers: ssaFlushPeerTagQueue cid(1841) peer list: tag(224) called number (0605655258)
Oct 15 22:17:42: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63152D40], magic[FACE0FFF]
Oct 15 22:17:42: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x636F40E0] with objects in container[0x63152D40]
Oct 15 22:17:42: ccTDUtilDumpAllElemInProfileTab: profileTable[0x636F40E0], numBuckets[11], numEntries[2]
Oct 15 22:17:42: Bucket { 0 } ------>0x63152460[0x0,t-5,l-276,d-0x63152480,m-1,u-350643,g-FACE0FFF]
Oct 15 22:17:42:
Oct 15 22:17:42: Bucket { 5 } ------>0x6370AD60[0x0,t-6,l-16,d-0x6370AD80,m-2,u-350643,g-FACE0FFF]
Oct 15 22:17:42:
Oct 15 22:17:42: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63152D40]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x6373A6C4], magic[FACE0FFF]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDUtilAddDataToUsrContainer: container=0x6373A6C4, tagID=6, dataSize=16, instID=-1,modifier=1
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructInstanceTDObject: tdObject[0x636C40A0], nxtElem[0x0], magic[0xFACE0FFF] tagID[6], dataLen[16], modif[1]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToContainer: Adding tdObject[0x636C40A0] instID[-1] into container[0x6373A6C4]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDUtilAddDataToUsrContainer: container=0x6373A6C4, tagID=5, dataSize=276, instID=-1,modifier=1
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructInstanceTDObject: tdObject[0x63756BA8], nxtElem[0x0], magic[0xFACE0FFF] tagID[5], dataLen[276], modif[1]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToContainer: Adding tdObject[0x63756BA8] instID[-1] into container[0x6373A6C4]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
Oct 15 22:17:49: cc_api_call_setup_ind:
Oct 15 22:17:49: cisco-username=
Oct 15 22:17:49: ----- ccCallInfo IE subfields -----
Oct 15 22:17:49: cisco-ani=225760101
Oct 15 22:17:49: cisco-anitype=0
Oct 15 22:17:49: cisco-aniplan=1
Oct 15 22:17:49: cisco-anipi=0
Oct 15 22:17:49: cisco-anisi=0
Oct 15 22:17:49: dest=0691440511
Oct 15 22:17:49: cisco-desttype=0
Oct 15 22:17:49: cisco-destplan=1
Oct 15 22:17:49: cisco-rdn=
Oct 15 22:17:49: cisco-rdntype=-1
Oct 15 22:17:49: cisco-rdnplan=-1
Oct 15 22:17:49: cisco-rdnpi=-1
Oct 15 22:17:49: cisco-rdnsi=-1
Oct 15 22:17:49: cisco-redirectreason=-1
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: (vdbPtr=0x631E5194, callInfo={called=0691440511,called_oct3=0x81,calling=225760101,calling_oct3=0x81,calling_oct3a=0x0,calling_xlated=false,subscriber_type_str=RegularLine,fdest=1,peer_tag=1, prog_ind=0,callingIE_present 1, src_route_label=, tgt_route_label= clid_transparent=0},callID=0x6374DD54)
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: type 6 , prot 0
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
Oct 15 22:17:49: ccCheckClipClir: calling number is: "225760101", calling oct3a is: 0x0
Oct 15 22:17:49: Calling Party number is User Provided
Oct 15 22:17:49: Leaving ccCheckClipClir
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: Increment call volume: 1
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: current call volume: 2
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: entry's incoming TRUE.
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: is_incoming is TRUE
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructHashProfileTab: profileTable[0x6372321C], numBuckets[11], numEntries[0]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6372321C] with objects in container[0x6373A6C4]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[5] for the tag[6]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x6372321C], tdObject[0x636C40A0]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[0] for the tag[5]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x6372321C], tdObject[0x63756BA8]
Oct 15 22:17:49: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6372321C], numBuckets[11], numEntries[2]
Oct 15 22:17:49: Bucket { 0 } ------>0x63756BA8[0x0,t-5,l-276,d-0x63756BC8,m-1,u-350657,g-FACE0FFF]
Oct 15 22:17:49:
Oct 15 22:17:49: Bucket { 5 } ------>0x636C40A0[0x0,t-6,l-16,d-0x636C40C0,m-1,u-350657,g-FACE0FFF]
Oct 15 22:17:49:
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x6373A6C4]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: not the VoIP or MMoIP
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x733, mask=2
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x733, mask=2 flag=1
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByRef: No tdObject found in profileTable for tagID[26] of callID[1843]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x733, mask=1 flag=1
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x733, mask=1
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1843], tagID[17], instID[-1]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[17] of callID[1843]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1843], tagID[18], instID[-1]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[18] of callID[1843]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1843], tagID[15], instID[-1]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[15] of callID[1843]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1843], tagID[16], instID[-1]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[16] of callID[1843]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1843], tagID[23], instID[-1]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[23] of callID[1843]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1843], tagID[21], instID[-1]
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[21] of callID[1843]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/cc_process_call_setup_ind: (event=0x631A25F0)
Oct 15 22:17:49: //1843/02D6D87E8880/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 1843 with tag 1 to app "DEFAULT"
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(24=CC_EV_CALL_SETUP_IND), cid(1843), disp(0)
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(1843), disp(0)
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/SSAPP:-1:-1/ssaCallSetupInd:
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccCallSetContext: (callID=0x733, context=0x63717040)
Oct 15 22:17:49: //1843/02D6D87E8880/SSAPP:1:-1/ssaCallSetupInd: cid(1843), st(SSA_CS_MAPPING),oldst(0), ev(24)ev->e.evCallSetupInd.nCallInfo.finalDestFlag = 1
Oct 15 22:17:49: //1843/02D6D87E8880/SSAPP:1:-1/ssaCallSetupInd: src route label=, tgt route label= tg_label_flag 0x0
Oct 15 22:17:49: //1843/02D6D87E8880/SSAPP:1:-1/ssaCallSetupInd: finalDest cllng(225760101), clled(0691440511) tgt_route_label()tg_label_flag 0x0
Oct 15 22:17:49: //1843/02D6D87E8880/SSAPP:1:-1/ssaCallSetupInd: cid(1843), st(SSA_CS_CALL_SETTING),oldst(0), ev(24)dpMatchPeersMoreArg result= 0
Oct 15 22:17:49: //1843/02D6D87E8880/SSAPP:1:-1/ssaDebugPeers: ssaSetupPeer cid(1843) peer list: tag(6) called number (0691440511) tag(224) called number (0691440511)
Oct 15 22:17:49: //1843/02D6D87E8880/SSAPP:1:-1/ssaSetupPeer: dialpeer tags in rotary= 6 224
Oct 15 22:17:49: //1843/02D6D87E8880/SSAPP:1:-1/ssaSetupPeer: cid(1843), destPat(0691440511), matched(2), prefix(), peer(634901A4), peer->encapType (2)
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/cc_can_gateway: Call legs: In=6, Out=1
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest: (Inbound call = 0x733, outbound peer =6, dest=,
Oct 15 22:17:49: //1843/02D6D87E8880/CCAPI/ccCallSetupRequest:
Oct 15 22:17:49: ccCallSetupRequest numbering_type 0x81
Oct 15 22:17:49: ccCallSetupRequest: calling number is:225760101
Oct 15 22:17:49: //1843/02D6D87E8880/CCAPI/ccCallSetupRequest: calling oct3a is:0x0
Oct 15 22:17:49: //1843/02D6D87E8880/CCAPI/ccCallSetupRequest: after ccCheckClipClir - calling oct3a is:0x0
Oct 15 22:17:49: //1843/02D6D87E8880/CCAPI/ccCallSetupRequest: dest pattern 06........, called 0691440511, digit_strip 0
Oct 15 22:17:49: callingNumber=225760101, calledNumber=0691440511, redirectNumber= display_info= calling_oct3a=0
Oct 15 22:17:49: accountNumber=, finalDestFlag=1,
guid=02d6.d87e.dfb2.11d6.8880.b975.8016.80b1
Oct 15 22:17:49: peer_tag=6
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate: (vdbPtr=0x62FF69D4, dest=, callParams={called=0691440511,called_oct3=0x81, calling=225760101,calling_oct3=0x81, calling_oct3a= 0x0, calling_xlated=false, subscriber_type_str=RegularLine, fdest=1, voice_peer_tag=6},mode=0x0)
Oct 15 22:17:49: ccIFCallSetupRequestPrivate: src route label tgt route label tg_label_flag 0x0
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate: vdbPtr type = 1
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate: (vdbPtr=0x62FF69D4, dest=, callParams={called=0691440511, called_oct3 0x81, calling=225760101,calling_oct3 0x81, calling_oct3a 0x0, calling_xlated=false, fdest=1, voice_peer_tag=6}, mode=0x0, xltrc=-5)
Oct 15 22:17:49: //1844/02D6D87E8880/CCAPI/cc_insert_call_entry: not incoming entry
Oct 15 22:17:49: //1844/02D6D87E8880/CCAPI/cc_insert_call_entry: entry's incoming FALSE.
Oct 15 22:17:49: //1844/02D6D87E8880/CCAPI/cc_insert_call_entry: is_incoming is FALSE
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccSaveDialpeerTag: (callID=0x733, dialpeer_tag=6)
Oct 15 22:17:49: //1844/xxxxxxxxxxxx/CCAPI/ccCallSetContext: (callID=0x734, context=0x637709E4)
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/ccCallReportDigits: (callID=0x733, enable=0x0)
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done: (vdbPtr=0x631E5194, callID=0x733, disp=0)
Oct 15 22:17:49: //1843/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(54=CC_EV_CALL_REPORT_DIGITS_DONE), cid(1843), disp(0)
Oct 15 22:17:49: //1843/02D6D87E8880/SSAPP:1:-1/ssaTraceSct: cid(1843)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_REPORT_DIGITS_DONE)
Oct 15 22:17:49: //1843/02D6D87E8880/SSAPP:1:-1/ssaTraceSct: -cid2(1844)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
Oct 15 22:17:49: //1843/02D6D87E8880/SSAPP:1:-1/ssaDebugPeers: ssaReportDigitsDone cid(1843) peer list: tag(224) called number (0691440511)
Oct 15 22:17:49: //1843/02D6D87E8880/SSAPP:1:-1/ssaReportDigitsDone: callid=1843 Reporting disabled.
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data: data_mode=0x10082
Oct 15 22:17:49: //1844/xxxxxxxxxxxx/CCAPI/cc_api_get_ic_leg_obtained_numbers: callID=0x734
Oct 15 22:17:49: //1844/xxxxxxxxxxxx/CCAPI/ccTDUtilGetInstanceCount: For tagID[1] of callID[1844]
Oct 15 22:17:49: //1844/02D6D87E8880/CCAPI/ccTDPvtProfileTableObjectAccessManager: No profileTable set for callID[1844]
Oct 15 22:17:49: //1844/xxxxxxxxxxxx/CCAPI/ccTDUtilGetInstanceCount: For tagID[2] of callID[1844]
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: remote IP is 10.10.3.1
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: hwidb is Serial3/1
Oct 15 22:17:49: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: added for entry: 12, voip: 12, mmoip: 0
Oct 15 22:17:49: //1844/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x734, mask=2
Oct 15 22:17:49: //1844/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x734, mask=2 flag=1
Oct 15 22:17:49: //1844/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByRef: No tdObject found in profileTable for tagID[26] of callID[1844]
Oct 15 22:17:49: //1844/xxxxxxxxxxxx/CCAPI/ccCallSetVoipFlag: ccCallSetVoipFlag: callID=0x734, mask=1 flag=1
Oct 15 22:17:49: //1844/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x734, mask=1
Oct 15 22:17:50: //1844/xxxxxxxxxxxx/CCAPI/cc_api_call_proceeding: (vdbPtr=0x62FF69D4, callID=0x734,
prog_ind=0x0)
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDUtilSetDataInstance: Setting data for callID[1844], tagID[5], instID[-1], data[0x637656A8], dataSize[276]
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructInstanceTDObject: tdObject[0x637716F4], nxtElem[0x0], magic[0xFACE0FFF] tagID[5], dataLen[276], modif[4]
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructHashProfileTab: profileTable[0x6371C07C], numBuckets[11], numEntries[0]
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x6371C07C], tdObject[0x637716F4]
Oct 15 22:17:50: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6371C07C], numBuckets[11], numEntries[1]
Oct 15 22:17:50: Bucket { 0 } ------>0x637716F4[0x0,t-5,l-276,d-0x63771714,m-4,u-350658,g-FACE0FFF]
Oct 15 22:17:50:
Oct 15 22:17:50: //1843/02D6D87E8880/CCAPI/cc_api_open_channel_ind: i/f type=6, srcCallID=734 (1844), dstCallId=733 (1843), channel_info ptr=637656A8
Oct 15 22:17:50: //1844/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(21=CC_EV_CALL_PROCEEDING), cid(1844), disp(0)
Oct 15 22:17:50: //1844/02D6D87E8880/SSAPP:0:-1/ssaTraceSct: cid(1844)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING)
Oct 15 22:17:50: //1844/02D6D87E8880/SSAPP:0:-1/ssaTraceSct: -cid2(1843)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
Oct 15 22:17:50: //1844/02D6D87E8880/SSAPP:0:-1/ssaCallProc:
Oct 15 22:17:50: //1843/xxxxxxxxxxxx/CCAPI/ccGetDialpeerTag: (callID=0x733)
Oct 15 22:17:50: //1843/xxxxxxxxxxxx/CCAPI/ccCallProceeding: (callID=0x733, prog_ind=0x0)
Oct 15 22:17:50: //1844/02D6D87E8880/SSAPP:0:-1/ssaIgnore: cid(1844), st(SSA_CS_CALL_SETTING),oldst(1), ev(21)
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63705FA4], magic[FACE0FFF]
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6371C07C] with objects in container[0x63705FA4]
Oct 15 22:17:50:
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63705FA4]
Oct 15 22:17:50: //1844/xxxxxxxxxxxx/CCAPI/cc_api_call_cut_progress: (vdbPtr=0x62FF69D4, callID=0x734, prog_ind=0x8, sig_ind=0x1)
Oct 15 22:17:50: //1844/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(22=CC_EV_CALL_PROGRESS), cid(1844), disp(0)
Oct 15 22:17:50: //1844/02D6D87E8880/SSAPP:0:-1/ssaTraceSct: cid(1844)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROGRESS)
Oct 15 22:17:50: //1843/02D6D87E8880/SSAPP:1:-1/ssaCutProgress:
Oct 15 22:17:50: //1843/xxxxxxxxxxxx/CCAPI/ccCallCutProgress: (callID=0x733, prog_ind=0x8, sig_ind=0x1)
Oct 15 22:17:50: //1843/xxxxxxxxxxxx/CCAPI/ccConferenceCreate: (confID=0x631C1184, callID1=0x733, callID2=0x734, tag=0x0)
Oct 15 22:17:50: //1844/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done: (confID=0x2AA, srcIF=0x62FF69D4, srcCallID=0x734, dstCallID=0x733, disposition=0, tag=0x0)
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x6371D1DC], magic[FACE0FFF]
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6372321C] with objects in container[0x6371D1DC]
Oct 15 22:17:50: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6372321C], numBuckets[11], numEntries[2]
Oct 15 22:17:50: Bucket { 0 } ------>0x63756BA8[0x0,t-5,l-276,d-0x63756BC8,m-1,u-350657,g-FACE0FFF]
Oct 15 22:17:50:
Oct 15 22:17:50: Bucket { 5 } ------>0x636C40A0[0x0,t-6,l-16,d-0x636C40C0,m-2,u-350657,g-FACE0FFF]
Oct 15 22:17:50:
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x6371D1DC]
Oct 15 22:17:50: //1843/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done: (confID=0x2AA, srcIF=0x631E5194, srcCallID=0x733, dstCallID=0x734, disposition=0, tag=0x0)
Oct 15 22:17:50: //1843/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (dstVdbPtr=0x62FF69D4, dstCallId=0x734, srcCallId=0x733,
Oct 15 22:17:50: //1843/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (Playout: mode 0, initial 60,min 40, max 300)
Oct 15 22:17:50: //1844/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (dstVdbPtr=0x631E5194, dstCallId=0x733, srcCallId=0x734,
Oct 15 22:17:50: //1844/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: (Playout: mode 0, initial 60,min 40, max 300)
Oct 15 22:17:50: //1844/xxxxxxxxxxxx/CCAPI/cc_api_caps_ack: (dstVdbPtr=0x631E5194, dstCallId=0x733, srcCallId=0x734,
codec_bytes=20, signal_type=2, seq_num_start=5467})
Oct 15 22:17:50: //1843/xxxxxxxxxxxx/CCAPI/cc_api_caps_ack: (dstVdbPtr=0x62FF69D4, dstCallId=0x734, srcCallId=0x733,
Oct 15 22:17:50: //1843/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(29=CC_EV_CONF_CREATE_DONE), cid(1843), disp(0)
Oct 15 22:17:50: //1843/02D6D87E8880/SSAPP:1:682/ssaTraceSct: cid(1843)st(SSA_CS_CONFERENCING_PROGRESS)ev(SSA_EV_CONF_CREATE_DONE)
oldst(SSA_CS_CALL_SETTING)cfid(682)csize(0)in(1)fDest(1)
Oct 15 22:17:50: //1843/02D6D87E8880/SSAPP:1:682/ssaTraceSct: -cid2(1844)st2(SSA_CS_CONFERENCING_PROGRESS)oldst2(SSA_CS_CALL_SETTING)
Oct 15 22:17:50: //1844/02D6D87E8880/SSAPP:0:682/ssaConfCreateDoneAlert:
Oct 15 22:17:50: //1844/02D6D87E8880/SSAPP:0:682/ssaConfCreateDoneAlert: Other call leg not found
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done: (event=0x631A49E0)
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x62F757BC], magic[FACE0FFF]
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6371C07C] with objects in container[0x62F757BC]
Oct 15 22:17:50:
Oct 15 22:17:50: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x62F757BC]
Oct 15 22:17:50: //1844/02D6D87E8880/SSAPP:0:682/ssaTraceSct: cid(1844)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_PROGRESS)
oldst(SSA_CS_CALL_SETTING)cfid(682)csize(0)in(0)fDest(0)
Oct 15 22:17:50: //1844/02D6D87E8880/SSAPP:0:682/ssaTraceSct: -cid2(1843)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCING_PROGRESS)
Oct 15 22:17:50: //1843/02D6D87E8880/SSAPP:1:682/ssaProgIndProgress:
Oct 15 22:17:50: //1843/xxxxxxxxxxxx/CCAPI/ccCallProgIndProgress: (callID=0x733)
Oct 15 22:17:51: //1843/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode_event: callID=0x733
Oct 15 22:17:51: //1843/02D6D87E8880/CCAPI/cc_api_voice_mode_event: Call Pointer =63717040
Oct 15 22:17:51: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x62F757BC], magic[FACE0FFF]
Oct 15 22:17:51: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:17:51: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6372321C] with objects in container[0x62F757BC]
Oct 15 22:17:51: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6372321C], numBuckets[11], numEntries[2]
Oct 15 22:17:51: Bucket { 0 } ------>0x63756BA8[0x0,t-5,l-276,d-0x63756BC8,m-1,u-350657,g-FACE0FFF]
Oct 15 22:17:51:
Oct 15 22:17:51: Bucket { 5 } ------>0x636C40A0[0x0,t-6,l-16,d-0x636C40C0,m-2,u-350657,g-FACE0FFF]
Oct 15 22:17:51:
Oct 15 22:17:51: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x62F757BC]
Oct 15 22:17:51: //1843/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(52=CC_EV_VOICE_MODE_DONE), cid(1843), disp(0)
Oct 15 22:17:51: //1843/02D6D87E8880/SSAPP:1:682/ssaTraceSct: cid(1843)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_VOICE_MODE_DONE)
oldst(SSA_CS_CONFERENCING_PROGRESS)cfid(682)csize(0)in(1)fDest(1)
Oct 15 22:17:51: //1843/02D6D87E8880/SSAPP:1:682/ssaTraceSct: -cid2(1844)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:17:51: //1843/02D6D87E8880/SSAPP:1:682/ssaIgnore: cid(1843), st(SSA_CS_CONFERENCED_ALERT),oldst(4), ev(52)
Oct 15 22:17:51: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x636C4798], magic[FACE0FFF]
Oct 15 22:17:51: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6371C07C] with objects in container[0x636C4798]
Oct 15 22:17:51: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6371C07C], numBuckets[11], numEntries[1]
Oct 15 22:17:51: Bucket { 0 } ------>0x637716F4[0x0,t-5,l-276,d-0x63771714,m-4,u-350658,g-FACE0FFF]
Oct 15 22:17:51:
Oct 15 22:17:51: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x636C4798]
Oct 15 22:17:51: //1844/xxxxxxxxxxxx/CCAPI/cc_api_call_alert: (vdbPtr=0x62FF69D4, callID=0x734, prog_ind=0x8, sig_ind=0x1)
Oct 15 22:17:51: //1844/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(7=CC_EV_CALL_ALERT), cid(1844), disp(0)
Oct 15 22:17:51: //1844/02D6D87E8880/SSAPP:0:682/ssaTraceSct: cid(1844)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_ALERT)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(682)csize(0)in(0)fDest(0)
Oct 15 22:17:51: //1844/02D6D87E8880/SSAPP:0:682/ssaTraceSct: -cid2(1843)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:17:51: //1843/02D6D87E8880/SSAPP:1:682/ssaAlertPass:
Oct 15 22:17:51: //1843/xxxxxxxxxxxx/CCAPI/ccGetDialpeerTag: (callID=0x733)
Oct 15 22:17:51: //1843/xxxxxxxxxxxx/CCAPI/ccCallAlert: (callID=0x733, prog_ind=0x8, sig_ind=0x1)
Oct 15 22:17:51: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63705FA4], magic[FACE0FFF]
Oct 15 22:17:51: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6372321C] with objects in container[0x63705FA4]
Oct 15 22:17:51:
Oct 15 22:17:51:
Oct 15 22:17:51: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63705FA4]
Oct 15 22:18:00: //-1/xxxxxxxxxxxx/CCAPI/cc_handle_periodic_timer: Calling the callback, ccTimerctx - 0x62A3B2B0
Oct 15 22:18:00: //-1/xxxxxxxxxxxx/CCAPI/ccTimerStart: ccTimerctx - 0x62A3B2B0
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63739E3C], magic[FACE0FFF]
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6371C07C] with objects in container[0x63739E3C]
Oct 15 22:18:16: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6371C07C], numBuckets[11], numEntries[1]
Oct 15 22:18:16: Bucket { 0 } ------>0x637716F4[0x0,t-5,l-276,d-0x63771714,m-4,u-350658,g-FACE0FFF]
Oct 15 22:18:16:
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63739E3C]
Oct 15 22:18:16: //1844/xxxxxxxxxxxx/CCAPI/cc_api_call_cut_progress: (vdbPtr=0x62FF69D4, callID=0x734, prog_ind=0x8, sig_ind=0x1)
Oct 15 22:18:16: //1844/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(22=CC_EV_CALL_PROGRESS), cid(1844), disp(0)
Oct 15 22:18:16: //1844/02D6D87E8880/SSAPP:0:682/ssaTraceSct: cid(1844)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_PROGRESS)
Oct 15 22:18:16: //1844/02D6D87E8880/SSAPP:0:682/ssaTraceSct: -cid2(1843)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:18:16: //1843/02D6D87E8880/SSAPP:1:682/ssaProgIndProgress:
Oct 15 22:18:16: //1843/xxxxxxxxxxxx/CCAPI/ccGetDialpeerTag: (callID=0x733)
Oct 15 22:18:16: //1843/xxxxxxxxxxxx/CCAPI/ccCallProgIndProgress: (callID=0x733)
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x634757C0], magic[FACE0FFF]
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6372321C] with objects in container[0x634757C0]
Oct 15 22:18:16: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6372321C], numBuckets[11], numEntries[2]
Oct 15 22:18:16: Bucket { 0 } ------>0x63756BA8[0x0,t-5,l-276,d-0x63756BC8,m-1,u-350657,g-FACE0FFF]
Oct 15 22:18:16:
Oct 15 22:18:16: Bucket { 5 } ------>0x636C40A0[0x0,t-6,l-16,d-0x636C40C0,m-2,u-350657,g-FACE0FFF]
Oct 15 22:18:16:
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x634757C0]
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x6370B120], magic[FACE0FFF]
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6371C07C] with objects in container[0x6370B120]
Oct 15 22:18:16:
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x6370B120]
Oct 15 22:18:16:
Oct 15 22:18:16:
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x63709A18], magic[FACE0FFF]
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6371C07C] with objects in container[0x63709A18]
Oct 15 22:18:16:
Oct 15 22:18:16: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x63709A18]
Oct 15 22:18:16:
Oct 15 22:18:16:
Oct 15 22:18:16:
Oct 15 22:18:16: //1844/xxxxxxxxxxxx/CCAPI/cc_api_call_connected: (vdbPtr=0x62FF69D4, callID=0x734), prog_ind = 1
Oct 15 22:18:16: //1844/02D6D87E8880/CCAPI/cc_api_call_connected: setting callEntry->connected to TRUE
Oct 15 22:18:16: //1844/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(8=CC_EV_CALL_CONNECTED), cid(1844), disp(0)
Oct 15 22:18:16: //1844/02D6D87E8880/SSAPP:0:682/ssaTraceSct: cid(1844)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_CONNECTED)
Oct 15 22:18:16: //1844/02D6D87E8880/SSAPP:0:682/ssaConnectAlert: .
Oct 15 22:18:16: //1843/xxxxxxxxxxxx/CCAPI/ccCallConnect: (callID=0x733), prog_ind = 1
Oct 15 22:18:16: //1843/02D6D87E8880/CCAPI/ccCallConnect: setting callEntry->connected to TRUE
Oct 15 22:18:16: //1843/02D6D87E8880/SSAPP:1:682/ssaDebugPeers: ssaFlushPeerTagQueue cid(1843) peer list: tag(224) called number (0691440511)
Oct 15 22:18:16:
Oct 15 22:18:16:
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/ccTDConstructTDUsrContainer: usrContainer[0x62BF3A98], magic[FACE0FFF]
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x6372321C] with objects in container[0x62BF3A98]
Oct 15 22:18:27: ccTDUtilDumpAllElemInProfileTab: profileTable[0x6372321C], numBuckets[11], numEntries[2]
Oct 15 22:18:27: Bucket { 0 } ------>0x63756BA8[0x0,t-5,l-276,d-0x63756BC8,m-1,u-350657,g-FACE0FFF]
Oct 15 22:18:27:
Oct 15 22:18:27: Bucket { 5 } ------>0x636C40A0[0x0,t-6,l-16,d-0x636C40C0,m-2,u-350657,g-FACE0FFF]
Oct 15 22:18:27:
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x62BF3A98]
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnected: (vdbPtr=0x631E5194, callID=0x733, cause=0x10)
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(11=CC_EV_CALL_DISCONNECTED), cid(1843), disp(0)
Oct 15 22:18:27: //1843/02D6D87E8880/SSAPP:1:682/ssaTraceSct: cid(1843)st(SSA_CS_ACTIVE)ev(SSA_EV_CALL_DISCONNECTED)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(682)csize(0)in(1)fDest(1)
Oct 15 22:18:27: //1843/02D6D87E8880/SSAPP:1:682/ssaTraceSct: -cid2(1844)st2(SSA_CS_ACTIVE)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:18:27: ssa: Disconnected cid(1843) state(5) cause(0x10)
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy: (confID=0x2AA, tag=0x0)
Oct 15 22:18:27: //1844/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done: (confID=0x2AA, srcIF=0x62FF69D4, srcCallID=0x734, dstCallID=0x733, disposition=0 tag=0x0)
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done: (confID=0x2AA, srcIF=0x631E5194, srcCallID=0x733, dstCallID=0x734, disposition=0 tag=0x0)
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(30=CC_EV_CONF_DESTROY_DONE), cid(1843), disp(0)
Oct 15 22:18:27: //1843/02D6D87E8880/SSAPP:1:-1/ssaTraceSct: cid(1843)st(SSA_CS_CONF_DESTROYING)ev(SSA_EV_CONF_DESTROY_DONE)
Oct 15 22:18:27: //1843/02D6D87E8880/SSAPP:1:-1/ssaTraceSct: -cid2(1844)st2(SSA_CS_CONF_DESTROYING)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:18:27: //1844/02D6D87E8880/SSAPP:0:682/ssaConfDestroyDone:
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: (callID=0x733, cause=0x10 tag=0x0)
Oct 15 22:18:27: //1843/02D6D87E8880/CCAPI/ccCallDisconnect: existing_cause = 0x10, new_cause = 0x10
Oct 15 22:18:27: //1843/02D6D87E8880/CCAPI/ccCallDisconnect: using the existing_cause 0x10
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/CCAPI/cc_api_get_transfer_info: (callID=0x733)
Oct 15 22:18:27: //1844/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: (callID=0x734, cause=0x10 tag=0x0)
Oct 15 22:18:27: //1844/02D6D87E8880/CCAPI/ccCallDisconnect: existing_cause = 0x0, new_cause = 0x10
Oct 15 22:18:27: //1844/xxxxxxxxxxxx/CCAPI/cc_api_get_transfer_info: (callID=0x734)
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x733, mask=1
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[1843], tagID[22], instID[-1]
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[22] of callID[1843]
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x733, mask=2
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: not the VoIP or MMoIP
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done: (vdbPtr=0x631E5194, callID=0x733, disp=0, tag=0x0)
Oct 15 22:18:27: //1843/02D6D87E8880/CCAPI/cc_delete_call_entry: ccFreeRawMsgInfo(0x631AFEC4)
Oct 15 22:18:27: //1843/02D6D87E8880/CCAPI/cc_delete_call_entry: Decrement call volume counter 2
Oct 15 22:18:27: //1843/02D6D87E8880/CCAPI/cc_delete_call_entry: current call volume: 1
Oct 15 22:18:27: //1843/02D6D87E8880/CCAPI/cc_delete_call_entry: entry's incoming TRUE.
Oct 15 22:18:27: //1843/02D6D87E8880/CCAPI/cc_delete_call_entry: is_incoming is TRUE
Oct 15 22:18:27: //1843/02D6D87E8880/CCAPI/cc_delete_call_entry: Deleting profileTable[0x6372321C]
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDHashProfileTab: Destructor Profile Table (0x6372321C)
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructInstanceTDObject: tdObject[0x63756BA8] tagID[5]
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructInstanceTDObject: tdObject[0x636C40A0] tagID[6]
Oct 15 22:18:27: //1843/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(1843), disp(0)
Oct 15 22:18:27: //1843/02D6D87E8880/SSAPP:1:-1/ssaTraceSct: cid(1843)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
Oct 15 22:18:27: //1843/02D6D87E8880/SSAPP:1:-1/ssaTraceSct: -cid2(1844)st2(SSA_CS_DISCONNECTING)oldst2(SSA_CS_CONFERENCED_ALERT)
Oct 15 22:18:27: //1843/02D6D87E8880/SSAPP:1:-1/ssaDisconnectDone:
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif: expect factor = 0
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/g113_calculate_impairment: (delay=101,
loss=0), Io=0 Iq=0 Idte=0 Idd=0 Ie=9 Itot=9
Oct 15 22:18:27: //1844/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x734, mask=1
Oct 15 22:18:27: //1844/xxxxxxxxxxxx/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x734, mask=2
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: the remote IP is 10.10.3.1
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: hwidb is Serial3/1
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: reduce callnum of entry: 11, voip: 11, mmoip: 0
Oct 15 22:18:27: //1844/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done: (vdbPtr=0x62FF69D4, callID=0x734, disp=0, tag=0x0)
Oct 15 22:18:27: //1844/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByRef: No tdObject found in profileTable for tagID[6] of callID[1844]
Oct 15 22:18:27: //1844/02D6D87E8880/CCAPI/cc_delete_call_entry: not incoming entry
Oct 15 22:18:27: //1844/02D6D87E8880/CCAPI/cc_delete_call_entry: entry's incoming FALSE.
Oct 15 22:18:27: //1844/02D6D87E8880/CCAPI/cc_delete_call_entry: is_incoming is FALSE
Oct 15 22:18:27: //1844/02D6D87E8880/CCAPI/cc_delete_call_entry: Deleting profileTable[0x6371C07C]
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructTDHashProfileTab: Destructor Profile Table (0x6371C07C)
Oct 15 22:18:27: //-1/xxxxxxxxxxxx/CCAPI/ccTDDestructInstanceTDObject: tdObject[0x637716F4] tagID[5]
Oct 15 22:18:27: //1844/xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(1844), disp(0)
Oct 15 22:18:27: //1844/02D6D87E8880/SSAPP:0:-1/ssaTraceSct: cid(1844)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
Oct 15 22:18:27: //1844/02D6D87E8880/SSAPP:0:-1/ssaDisconnectDone:
###GOOD CALL END#################################################################################
Well, it just couldn't have been something easy like a codec mismatch, could it? Nothing obvious in this debug.
Let's see. You must have a num-exp somewhere on router A, right? Not that that should matter, just trying to make sure I understand the call flow.
I'm still stumped about this part of the isdn debug:
Oct 15 09:42:18: ISDN BR2/0 Q931: TX -> CONNECT pd = 8 callref = 0xDB
Channel ID i = 0x89
Oct 15 09:42:18: ISDN BR2/0 Q931: RX <- STATUS pd = 8 callref = 0x5B
Cause i = 0x81E01C - Mandatory information element missing
Call State i = 0x04
Oct 15 09:42:18: ISDN BR2/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xDB
Cause i = 0x82E0 - Mandatory information element missing
Router B seems to be originating the disconnect, and it does so immediately following the RX <- STATUS. I'm wondering if there could be a cause-effect there. Do you also get that STATUS request from the panasonic on a good call?
no, I don't think so - in Poland we use primary-net5 and basin-net3.
yes, I have some num-exps - sorry I missed them in conf. I was sure they are not problem so I strip them.
this is good call on routerB - I do not see STATUS after CONNECT.
for good call routerB in answer to STATUS sends CONNECT_ACK.
what could be the reason of that?
also in CONNECT msg for good call there are two fields:
Channel ID i = 0x8A
Date/Time i = 0x020A100910
for bad call in CONNECT I'v got only Cahnnel ID. It seems the field Date/Time could be the problem. Maybe you know Whan can be the reason of missing Data/Time field in CONNECT?
kind regard.
Oct 16 09:27:45: ISDN BR2/0 Q931: RX <- SETUP pd = 8 callref = 0x49
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Calling Party Number i = 0x81, '225760511'
Plan:ISDN, Type:Unknown
High Layer Compat i = 0x9181
Oct 16 09:27:45: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x323 calltype 2 HOST_INCOMING_CALL
Oct 16 09:27:45: ISDN BR2/0 Q931: TX -> SETUP_ACK pd = 8 callref = 0xC9
Channel ID i = 0x8A
Oct 16 09:27:46: ISDN BR2/0 Q931: RX <- INFORMATION pd = 8 callref = 0x49
Called Party Number i = 0x81, '0'
Oct 16 09:27:46: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x323 calltype 2 HOST_INFORMATION
Called Party Number i = 0x81, '6'
Oct 16 09:27:47: ISDN BR2/0 Q931: RX <- INFORMATION pd = 8 callref = 0x49
Called Party Number i = 0x81, '9'
Oct 16 09:27:47: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x323 calltype 2 HOST_INFORMATION
Called Party Number i = 0x81, '1'
Called Party Number i = 0x81, '4'
Oct 16 09:27:48: ISDN BR2/0 Q931: RX <- INFORMATION pd = 8 callref = 0x49
Oct 16 09:27:48: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x323 calltype 2 HOST_INFORMATION
Called Party Number i = 0x81, '5'
Oct 16 09:27:49: ISDN BR2/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xC9
Oct 16 09:27:49: ISDN BR2/0 Q931: TX -> PROGRESS pd = 8 callref = 0xC9
Progress Ind i = 0x8288 - In-band info or appropriate now available
Oct 16 09:27:53: ISDN BR2/0 Q931: TX -> PROGRESS pd = 8 callref = 0xC9
Oct 16 09:27:53: ISDN BR2/0 Q931: TX -> ALERTING pd = 8 callref = 0xC9
Oct 16 09:27:53: %SEC-6-IPACCESSLOGP: list 100 denied udp 10.10.17.100(138) -> 10.10.19.255(138), 1 packet
Oct 16 09:27:54: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x323 calltype 2 HOST_CONNECT
Oct 16 09:27:54: ISDN BR2/0 Q931: TX -> CONNECT pd = 8 callref = 0xC9
Channel ID i = 0x8A
Date/Time i = 0x020A10091B
Oct 16 09:27:54: ISDN BR2/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x49
Oct 16 09:27:55: ISDN BR2/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xC7
Cause i = 0x8090 - Normal call clearing
Oct 16 09:27:58: ISDN BR2/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x49
Cause i = 0x8190 - Normal call clearing
Oct 16 09:27:58: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x323 calltype 2 HOST_DISCONNECT
Oct 16 09:27:58: ISDN BR2/0 Q931: TX -> RELEASE pd = 8 callref = 0xC9
Oct 16 09:27:58: ISDN BR2/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x49
Oct 16 09:27:58: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x323 calltype 2 HOST_DISCONNECT_ACK
Oct 16 09:28:02: ISDN BR2/0 Q931: RX <- RELEASE pd = 8 callref = 0x47
Oct 16 09:28:02: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x321 calltype 2 HOST_DISCONNECT_ACK
Oct 16 09:28:02: ISDN BR2/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xC7===
and this is bad again:
Oct 16 09:22:33: ISDN BR2/0 Q931: RX <- SETUP pd = 8 callref = 0x46
Standard = CCITT
Channel ID i = 0x8A
Oct 16 09:22:33: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x320 calltype 2 HOST_INCOMING_CALL
Oct 16 09:22:33: ISDN **ERROR**: Module-lif Function-LIF_AddTimer Error-Unknown Class.
Oct 16 09:22:33: ISDN BR2/0 Q931: TX -> SETUP_ACK pd = 8 callref = 0xC6
Channel ID i = 0x8A
Oct 16 09:22:34: ISDN BR2/0 Q931: RX <- INFORMATION pd = 8 callref = 0x46
Oct 16 09:22:34: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x320 calltype 2 HOST_INFORMATION
Oct 16 09:22:35: ISDN BR2/0 Q931: RX <- INFORMATION pd = 8 callref = 0x46
Oct 16 09:22:35: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x320 calltype 2 HOST_INFORMATION
Called Party Number i = 0x81, '7'
Oct 16 09:22:36: ISDN BR2/0 Q931: RX <- INFORMATION pd = 8 callref = 0x46
Oct 16 09:22:36: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x320 calltype 2 HOST_INFORMATION
Oct 16 09:22:37: ISDN BR2/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xC5
Oct 16 09:22:37: ISDN BR2/0 Q931: RX <- RELEASE pd = 8 callref = 0x45
Oct 16 09:22:37: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x31F calltype 2 HOST_DISCONNECT_ACK
Oct 16 09:22:37: ISDN BR2/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xC5
Oct 16 09:22:44: ISDN BR2/0 Q931: TX -> PROGRESS pd = 8 callref = 0xC6
Oct 16 09:22:45: ISDN BR2/0 Q931: TX -> ALERTING pd = 8 callref = 0xC6
Oct 16 09:22:53: ISDN BR2/0 Q931: TX -> FACILITY pd = 8 callref = 0xC6
Oct 16 09:22:53: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x320 calltype 2 HOST_CONNECT
Oct 16 09:22:53: ISDN BR2/0 Q931: TX -> CONNECT pd = 8 callref = 0xC6
Channel ID i = 0x8A
Oct 16 09:22:53: ISDN BR2/0 Q931: RX <- STATUS pd = 8 callref = 0x46
Call State i = 0x04
Oct 16 09:22:53: ISDN BR2/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xC6
Oct 16 09:22:53: ISDN BR2/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x46
Oct 16 09:22:53: ISDN BR2/0 **ERROR**: Ux_BadMsg: Invalid Message for call state 11, call id 0x320, call ref 0xC6, event 0xF
Oct 16 09:22:53: ISDN BR2/0 Q931: TX -> STATUS pd = 8 callref = 0xC6
Cause i = 0x80E20F - Message not compatible with call state or not implemented
Call State i = 0x0C
Oct 16 09:22:53: %SEC-6-IPACCESSLOGP: list 100 denied udp 10.10.17.100(138) -> 10.10.19.255(138), 1 packet
Oct 16 09:22:57: ISDN BR2/0 Q931: RX <- RELEASE pd = 8 callref = 0x46
Cause i = 0x81E0 - Mandatory information element missing
Oct 16 09:22:57: ISDN BR2/0 EVENT: process_rxstate: ces/callid 1/0x320 calltype 2 HOST_DISCONNECT_ACK
Oct 16 09:22:57: ISDN BR2/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xC6no deb all
one more - below isdn debug from router A. good call, and bad call. both looks the same. both have Date/Time field...
===bad call on router A ====================
Oct 16 07:55:07: ISDN Se6/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0304
Standard = CCITT
Channel ID i = 0xA98381
Exclusive, Channel 1
Called Party Number i = 0x81, '4501705041'
Oct 16 07:55:07: ISDN Se6/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8304
Oct 16 07:55:07: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8304 calltype 2 CALL_SETUP_ACK
Oct 16 07:55:11: ISDN Se6/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8304
Oct 16 07:55:11: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8304 calltype 2 CALL_PROCEEDING
Oct 16 07:55:11: ISDN Se6/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8304
Oct 16 07:55:11: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8304 calltype 2 CALL_PROGRESS
Oct 16 07:55:23: ISDN Se6/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8304
Date/Time i = 0x020A100937
Oct 16 07:55:23: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8304 calltype 2 CALL_CONNECT
Oct 16 07:55:23: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8304 calltype 2 CALL_PROGRESS
Oct 16 07:55:23: ISDN Se6/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0304
Oct 16 07:55:27: ISDN Se6/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8304
Oct 16 07:55:27: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8304 calltype 2 CALL_DISC
Oct 16 07:55:27: ISDN Se6/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0304
Oct 16 07:55:27: ISDN Se6/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8304
Oct 16 07:55:27: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8304 calltype 2 CALL_CLEARED
====good call on routerA===========
Oct 16 07:55:59: ISDN Se6/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0305
Standard = CCITT
Called Party Number i = 0x81, '3904'
Oct 16 07:55:59: ISDN Se6/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8305
Oct 16 07:55:59: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8305 calltype 2 CALL_PROCEEDING
Oct 16 07:55:59: ISDN Se6/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8305
Oct 16 07:55:59: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8305 calltype 2 CALL_PROGRESS
Oct 16 07:56:05: ISDN Se6/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8305
Oct 16 07:56:05: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8305 calltype 2 CALL_CONNECT
Oct 16 07:56:05: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8305 calltype 2 CALL_PROGRESS
Oct 16 07:56:05: ISDN Se6/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0305
Oct 16 07:56:07: ISDN Se6/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0305
Oct 16 07:56:07: ISDN Se6/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8305
Oct 16 07:56:07: ISDN Se6/0:15 EVENT: process_rxstate: ces/callid 1/0x8305 calltype 2 CALL_CLEARED
Oct 16 07:56:07: ISDN Se6/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0305
Okay, my guess is that the immediate cause of the problem is that Router B is transmitting a FACILITY message with no facility. So the panasonic sends back the STATUS message that says "Mandatory information element missing" which in turn causes Router B to disconnect. *Why* Router B sends this empty FACILITY for the bad call but not the good call is still a mystery to me... Maybe it has something to do with the fact that the message exchange on Router A is *slightly* different (for the bad call, Router A receives a SETUP_ACK, which is doesn't for the good call).
What version of IOS are you running on Router B? Upgrading may help the invalid FACILITY message.
Shelly
it's mystery for me too ;) we are going to reload both routers this night (in Poland it will be in 2-3 hours) - then I will let you know, did it fix the problem or not.
as about IOS versions, both routers have 12.2(11)T.
best regards
Well, that's a bummer. I think it's time to open a TAC case if you haven't already. Sorry I couldn't help.
Shelly
both routers reloaded. problem still exists. I am wondering do the people from problem mobile net change somethink?.. I will call them again - let they check thet. piotr
hi Shelly,
problem fixed - upgrade of routerB from 12.2.(11)T to 12.2(11)T1 have fixed the problem. Probably it was problem similar to that one:
CSCdy16847
Symptoms The AOC-E facility information element (IE) is not passed across Voice over IP (VoIP) links if the AOC-E facility IE is received as part of an ISDN release message.
Conditions This symptom is observed on a Cisco router that is running Cisco IOS Release 12.2(6a).
Workaround There is no workaround.
piotr
Cool! Thanks for letting me know. It was a thought-provoking problem...
Shelly
