02-04-2005 11:40 AM - edited 03-15-2019 03:14 AM
The IP Communication section has been very helpful. I'm able to see how many calls are going through our voice gateways via a browser. Life if good :)
Since I missed so much is there any way to query a voice gateway (it's a 1760) or maybe the call manager to see historically how many calls a particular voice gateway processed?
02-04-2005 11:55 AM
I'm not sure how you're monitoring your gateways, but...
I normally use windows performance monitor (the same counters are visible through RTMT)... you can set this up to log to CSV, but as for going back to before you set this up... then no, you can't...
Aaron
02-07-2005 05:37 AM
02-06-2005 01:36 PM
You can use CDR Administration Tool
CAR Device Reports Configuration
Check table 18-1 and table 18-3
You can generate a report for all outbound calls that originate from a Cisco IP phone and terminate in a gateway.
