historical number of calls through voice gateway
kendalle01
The IP Communication section has been very helpful. I'm able to see how many calls are going through our voice gateways via a browser. Life if good :)
Since I missed so much is there any way to query a voice gateway (it's a 1760) or maybe the call manager to see historically how many calls a particular voice gateway processed?
Aaron Harrison
I'm not sure how you're monitoring your gateways, but...
I normally use windows performance monitor (the same counters are visible through RTMT)... you can set this up to log to CSV, but as for going back to before you set this up... then no, you can't...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
I use the following web page...
http://the_call_manager/ast/ast.asp
it's a java applet...
gogasca
Level 10
Level 10
You can use CDR Administration Tool
CAR Device Reports Configuration
Check table 18-1 and table 18-3
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_3/service/serv332/ccmsrva/sacar5.htm#84975
You can generate a report for all outbound calls that originate from a Cisco IP phone and terminate in a gateway.
