How Location Assignment works on CUCM?
korkiatcisco
Hi there
I just wonder in Location assignment in CUCM that there is Location configuration on Device and also the device pool on that device. The question is what if I assign with the different Location, what Location will be used?
For example;
There are SIP Trunk: SIP_A
Device Pool: DP_A (uses Loc_A), DP_none(uses Location Hub_none)
In SIP_A configuration;
Device Pool: DP_A
What Location will be used?
Device Pool: DP_A
Device Pool: DP_none
Anurag Srivastava
The location that is configured in a device pool takes precedence over the location configured in the device when the location in the device is set to Hub_None. If the device location is set to any other user-defined location, standard rules apply and the device parameter takes priority.
According to the above the answers of for your situations will be as below-
Device Pool: DP_A
On Device its set as Loc_B so it will be preferred
Device Pool: DP_A
Device pool : DP_A will be preferred as on device it is set as Hub_None
DP_A will be preferred.
Thanks.
Please rate if it is helpful.....
This is what I looking for, Thank you very much.
