03-25-2003 07:20 AM - edited 03-12-2019 11:12 PM
I have two servers, one with CCM 3.3 and the other with CRS 3.0(2).
IVR is configured on CRS and works perfectly, so JTAPI should work.
I configured ICD subsystem with all users, icd extensions, CTI enabling, rmjtapi etc., and the RM subsystem is working and IN_SERVICE.
I installed agent on a win2000 pc, and when i try to login with one of the configured users, i receive the "Unable to login to CTI manager".
Looking in the event viewer of CCM i notice the following text.
Any idea?
THX
Error: kCtiIncompatibleProtocolVersion - Incompatible protocol version.
Message Version: 30000
Minimum Version: 40000
Current Version: 40000
CallManager Version:
QBE Client Version:
IPAddress: 10.10.53.151
App ID: Cisco CTIManager
Cluster ID: StandAloneCluster
Node ID: CCMPRI
Process ID: 11988
Process Name: CtiHandler
Explanation: The JTAPI/TAPI application version is not compatible with this version of CTIManager, so received message has been rejected.
Recommended Action: Verify correct version of application are being used; otherwise, contact TAC..
03-25-2003 11:29 AM
ICD 3.02 does not work with CCM 3.3, you will need ICD 3.03 which just got released.
Michael
03-26-2003 12:39 AM
i already know.
but "Desktop Supervisor" and IVR and "phone Agent", work fine.
Only "Desktop Agent" not work, and i think that a problem is only a Jtapi version.
There is a solution for this problem?
An other type of JTAPI, or....
04-23-2003 09:57 PM
It doesen't work with CCM3.2, even if you update the JTAPI from CCM plug-in page you won't get the RM-CM service running.
There is no solution.
04-24-2003 04:19 PM
I have 3.2.3 version of CallManager and version 3.0(2) working together with no problems.
Is this what you are talking about?
