01-26-2021 01:57 PM - edited 01-26-2021 10:26 PM
Hi Everyone,
I have an issue with Inbound calls from ITSP that has been connected to my cisco VGW through SIP trunk, I got the following disconnect cause:
Disconnect Cause (CC) : 57
Disconnect Cause (SIP) : 403
appreciate you support to figure out this issue,
Attached are ccsip debug files
Thanks and Regards,
Solved! Go to Solution.
01-27-2021 12:41 AM - edited 01-27-2021 03:10 AM
Your inbound dial-peers are
dial-peer voice 2000 voip
description #TO_Y Inside_01#
answer-address [1-8]...$
destination-pattern 21
session protocol sipv2
session target ipv4:10.11.200.20
dtmf-relay sip-info sip-kpml sip-notify rtp-nte
codec g711alaw
dial-peer voice 2001 voip
description #TO_Y Inside_02#
session target ipv4:10.11.200.21
codec g711alaw
The five configurable dial peer attributes are:
Incoming called number--A string representing the called number or DNIS. It is configured by using the incoming called-numberdial-peer voice configuration command in POTS or multimedia mail over IP (MMoIP) dial peers.
Answer address--A string representing the calling number or ANI. It is configured by using the answer-address dial-peer voice configuration command in POTS or VoIP dial peers and is used only for inbound calls from the IP network.
Destination pattern--A string representing the calling number or ANI. It is configured by using the destination-pattern dial-peer voice configuration command in POTS or voice-network dial peers.
Application--A string representing the predefined application that you wish to enable on the dial peer. It is configured by using the applicationdial-peer voice configuration command on inbound POTS dial peers.
Port--The voice port through which calls to this dial peer are placed.
Your inbound call information
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7F62F9E8AEE8
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : +96477xxxxxxx4
Called Number : 78xxxxxxx8
There is nothing to match with your dial-peer configuration.
01-26-2021 04:16 PM
Do you have the correct codec defined in the dial peers?
is there any possibility that you can share debug sip message for the inbound calls?
01-26-2021 06:58 PM - edited 01-26-2021 07:02 PM
Can you share your VG configuration and debug ccsip messages
01-26-2021 10:50 PM
01-27-2021 12:22 AM
Could you please clarify the device name with IP .214 and .213?
Could you please let us know the call flow?
Zain (ITSP) --> CUBE (.250) --> .213/.214 (Is it CUCM? )
Shalid
01-27-2021 06:10 AM - edited 01-27-2021 06:16 AM
Hi Shalid,
I'm using this VGW t connect ITSP from a side (SIP servers 172.21.175.212, 213 and 214), from other side it connects to internal servers used for contact center (10.11.200.20, and 21 don't think it shown in debug).
So, for inbound call flow:
ITSP (SIP Signal 172.21.175.212-214, RTP Traffic 10.x.x.100) --->> Voice Gateway (Dial-peer 1000 > dest dpg 2) --->> CC Servers (10.11.200.20-21)
for now, I got different cause code
Disconnect Cause (SIP) : 480 CC: 31
Disconnect Cause (SIP) : 487 CC: 102
01-27-2021 06:32 AM - edited 01-27-2021 06:35 AM
Thanks for the details.
as @Nithin Eluvathingal since you don't have a dial-peer for the destination number to the call manager, it is taking the route back to ITSP via dial-peer 1013 and 1014.
could you please modify your 2001 dial peer for testing as below and make a call.
description #TO_CUCM#
destination-pattern 78........$ (or any of DID) --> this is based on your first call sample.
codec g711alaw
no vad
Either use TP to translate the DID to an extension or choose significant digit = 4 in your SIP trunk configuration page depends on your dial plan.
codec g711alaw
codec g711alaw
01-27-2021 06:22 AM
Hi Nithin,
Dial-peer voice 2000 and 2001 should be forward inbound calls to CC servers (DN consist of 4 digits XXXX) which is the answer-address, n the other hand Dial-peer 1000 should be receive the calls from ITSP and forward to Dial-peers 2000&2001 (DPG 2).
ITSP SIP Trunk-->DP 1000 >> DP 2000&2001 (DN XXXX) -->> CC servers SIP Trunk
Please correct me if wrong,
01-27-2021 06:37 AM
your called number is 78xxxxxxx8
and your dial peer is for 4 digit.
Use translation to convert 78xxxxxxx8
to 4 digit .
01-27-2021 07:33 AM
The OP is trying to use DPG to route the calls, then the legacy match part of the dial peers should be irrelevant.
01-27-2021 07:41 AM
I hope your internal numbers are 4 digit, if yes translate 78xxxxxxx8 to a 4 digit and sent it to CC or do it from CC if possible.
01-27-2021 02:43 PM
exactly, my internal number are 4 digit and I did configured translation-rule but still cannot receive the call.
Also, I did register an IP Phone to VGW with extension 1000 so the call flow will be:
ITSP-->> VGW-->>IP Phone
So, for inbound calls I've to configure a dial-peer.. can you please share the correct configuration of this dial-peer?? and the right expression for translation-rule?
Thanks a lot,
01-27-2021 08:50 PM - edited 01-27-2021 08:51 PM
Try below
voice translation-rule 1
rule 1 /^78....\([1-8]...$\)/ /\1/
voice translation-profile Incoming
translate called 1
translation-profile incoming Incoming
Testing Voice translation Rule
jlrvg#test voice translation-rule 1 7845122154
Matched with rule 1
Original number: 7845122154 Translated number: 2154
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
