intermittent CDR insert errors
rbradfield
Level 5
Level 5
I intermittently get the following in the event log of the Publisher,the files get left in the BAD directory. when I go to the CDR directoery I see the files coming in and getting cleared, so most of the time the cdr insert is working( I see the data in the SQL database Calldetailrecord,
anybody have any ideas?
Event Type: Error
Event Source: Cisco CDR Insert
Event Category: None
Event ID: 3
Date: 4/11/2005
Time: 3:52:24 PM
User: N/A
Computer: SIMPLOTCM1
Description:
Error: kErrorCDRServerDown - Error connecting to CDR Database.
ODBC Error: Error executing "insert into CallDetailRecord (cdrRecordType,globalCallID_callManagerId,globalCallID_callId,origLegCallIdentifier
App ID: Cisco CDR Insert
Cluster ID: SIMPLOTCM1-Cluster
Node ID: 172.16.5.226
Explanation: CDR database server is not responding. CDRs cannot be written.
Recommended Action: Either bring server back online or reconfigure CDRs to be written to a different server..
beth-martin
Level 10
Level 10
I believe that you may be running into the bug: CSCdz79065
Erick Bergquist
Level 11
Level 11
With CCM 3.3 this could be bug id CSCec25549 also, fixed in 3.3(3)es19 which 3.3(3)sr3 or higher should fix.
If this is 4.0x then could be bug id CSCeg39215 which is fixed in 4.0(2a) es 18 or higher. That is newer then 4.0(2a)SR1 so you will need to contact TAC to get that right now until a new SR comes out.
