Is there way of notifying another phone in the enterprise when a 911 call is made to PSAP ?
herbcampbell
Hi ,
    We have just upgraded our CUCM to version 11.5, a couple of days ago. The customer is asking whether the system has the capability of notify the call center whenever an nd user makes a 911 call?  I think Cisco Emergency responder has that capability.. We will eventually be integrating it with the current CUCM. Thanks and looking forward to your replies.
Jaime Valencia
Informacast now also provides that, you can configure it for a 90 days trial to see how it works
Page 40
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/11_5_1/SU3/cucm_b_release-notes-cucm-imp-1151su3.pdf
This is from CUCM and the config wizard:
Introduction to InformaCast Emergency Notifications
InformaCast Emergency Notifications enables IP paging and emergency alerting in the Cisco Unified Communications deployment. Complete the steps in this wizard to set up a 90-day trial of InformaCast Emergency Notifications with the following safety features:
  • Panic Button – Protect your employees – add a panic button to any Cisco IP phone.
  • Emergency Call Alerting – Set up Emergency Call Alerting so that your safety team gets notified right away whenever an emergency number is dialed.
java
if this helps, please rate
Andrew West
Level 4
Level 4
Built into CUCM there isnt much that way.
CER (Emergency Responder) does that.
Quite a few 3rd party ecosystem companies like Red Sky alert on it.
Many of the CDR Tools do it also..I use OfficeWatch by Metropolis for CDR and 911 alerting is great on it.
Jaime Valencia
Page 40
java
