Jabber for iPhone, Incoming Calls go Missed Call
hamed1900
Incoming Calls on Jabber for iPhone, shows immediately as a missed Call.Has anyone had this issue? It is intermittent, and happens especially when the Mobile is locked.
HA
Javier Cuadros
Hi Hamed, i have the same problem.
Do you still having the issue? any solution provided so far?
thanks.
The service paramater  adjusted  1500 as default. it means 1.5 second is not enough to deliver call to Jabber , it  terminated the call and appeared  "missed call"  ,,, the issue will be resolved by increasing  the value of SIP Dual Mode Alert Timer to 4500  on  Service paramater (CUCM)
Halit
Changed the parameter still the same do you have any other updates on this issue
