02-09-2009 05:22 PM - edited 03-13-2019 06:03 PM
I have 2 x 2851 cme router forming a HA reducdant. For this condition, how can I config the routers to support load balancing for 2 x E1 ?
Please find the attached drawing for your information.
Leung Che Man
02-10-2009 01:53 AM
The failure rate of cisco router is extremely small, if you want to keep a secondary CME that's ok, but the easier way is that in case of failure you move circuits from one box to another. Having the PRI connected to two different boxes involves more configuration. However it can be done a pots and voip DP. If you do not have experience in configuring voip I recommend you hire a professional to save you time and frustration.
02-10-2009 02:10 AM
Thanks for your advice.
Leung Che Man
02-10-2009 02:20 AM
You are welcome, please remember to rate useful posts with the scrollbox below.
