02-04-2010 10:32 AM - edited 03-13-2019 06:50 PM
I am trying to build a 3845 of the following spec.with the configurator tool.
in the NM slots:
2x EVM-HD-8FXS/DID each with 2x EM3-HDA-8FXS/DID
2x NM-HD-2V each with 2x VIC2-2BRI-NT/TE
in the HWIC slots:
1x VIC2-2BRI-NT/TE
1x HWIC-4ESW
I specify IOS upgrade to S384RSPSK9-12424T so that the EM3-HDA is supported.
But when I finally click check configuration, it says there are only 4 HWIC slots available in CISCO3800, it doesn't appear to take into account that 4 of them are going into the NM-HD-2V modules.
Is this a configurator bug?
Now someone has told me that the 3845 doesn't support 2x EVM-HD-8FXS/DID each with 2x EM3-HDA-8FXS/DID as well.
Is this true or not?
HELP!
Paul
02-05-2010 02:10 AM
Seems to me you are pushing the envelope, should split in two boxes one for analog breakout (VG224), one for trunking to PSTN.
And avoid the NM-HDx that are older technology. Also you will find that rather a miriad of BRI, one PRI is infinitely better, and cheaper.
02-05-2010 03:04 AM
I thought that the VG224/248 were non-preferred (going end-of-life) as the newer routers (28xx,38xx,29xx,39xx) have absorbed the functionality into their capability.
Customer wants to remain on analog handsets and TDM for voice, so VOIP is not an option.
Unfortunately, I have a requirement to interface to 8 ISDN BRI user devices, BRI is an essential component. I am using E1 for the PSTN trunking.
So, pushing the envelope or not, does anyone know if a 3845 can give me 48x analog voice ports, 8x BRI ports, 1x E1 port and 4x Ethernet switch ports? If so, what modules do I need to achieve this?
02-05-2010 12:45 PM
The VG248 is EOS, but not the V224 that runs IOS and sells in big numbers.
Once you move the FSX to a separate box, you can accomodate the PSTN cards to an ISR router. It does not need to be a 3845, it can be as a 28xx or 29xx.
Usually the dynamic configurator is correct in determing what cards can be supported on it.
