02-12-2004 11:51 PM - edited 03-13-2019 03:50 AM
I've got a strange problem. I configured an 1760 PRI connection in MGCP and it's working fine. But on the CCM Administration, I see that the endpoints are not registered. Has anyone already seen this problem.
I've the CCM 3.3(3)sr3 and IOS 12.2.15(ZL1) for the 1760.
jp
02-16-2004 06:31 AM
I've seen this. If you do a show ccm-manager on the gateway, I bet it says registered. Try rebooting the CallManager a couple of times. I havn't found any bug IDs for this, but i have seen it on a couple of installs. Changes arn't reflecting on the admin page correctly. After rebooting a couple of times the admin page seems to work fine afterwords.
02-16-2004 07:43 AM
Thanks for your answer,
It's strange, because just after the installation it was OK, but one day I saw it was not registered.
Concerning the sh ccm-manager on the gateway, it's not the same, because with this command you can see that your MGCP config is OK even if your channels are down. On the CCM Admin page, the endpoint is "registered" only when the channels are up.
Anyway, it's a cosmetic problem, but it's quite anoying for checking the PRI status.
Cheers
jp
