03-16-2018 02:52 AM - last edited on 03-25-2019 07:05 PM by ciscomoderator
router configured with PIM stops streaming after several minutes. Access switch has client connected.
Can anyone suggest some common reasons why this may happen ?
Solved! Go to Solution.
03-17-2018 04:00 AM
03-16-2018 09:04 AM
03-16-2018 07:25 PM - edited 03-16-2018 08:39 PM
Hi Nipun, I know the detail is sometimes important but I really don't want to answer lots of questions. I am asking for common reasons for multicast traffic to works initially and then to stop after a few minutes.
I noticed that it was using incoming or outgoing port channels that seemed to change. Would that be an issue and does that mean I might want to use the "multipath" option?
03-17-2018 04:00 AM
