03-04-2004 09:58 AM - edited 03-13-2019 04:07 AM
Hi Community,
I´m having the following problem.
A Callmanager running 3.3(3)SR4a and a H.323 Gateway running IOS 12.2-15-ZJ2.
A pstn-caller hears no ringback after a call-transfer from one IP-Phone (1) to another IP-Phone (2) while the IP-Phone (2) is ringing.
I had a look at CCO and found some hints:
Pots Dial-peer:
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
VoIP Dial-peer:
progress_ind setup enable 3
and further on the Callmanager to set
Service Parameters -> callmanager -> ToSendH225UserInfoMsg = true.
This must be under CCM-Ver. 3.0 in Ver 3.3.3 I found the parameter "Send H225 User Info Message " I´ve tried the settings: "User Info for Ring Back Tone" and "H225 Info for Ring Back".
All this settings did not solve my problem.
Has anybody any idea about this problem?
Thanks a lot in advance.
Geri
Solved! Go to Solution.
03-04-2004 11:19 AM
You can tried 12.2(15)ZJ3. I was having the same problem but the upgrade works for me.
Let me know if you need anything else.
-Jose
03-04-2004 11:19 AM
-Jose
03-05-2004 01:11 AM
Hi Jose,
upgrading to 12.2(15)ZJ3 was the solution.
Muchas Gracias,
Geri
