02-03-2003 12:01 PM - edited 03-12-2019 10:32 PM
If anyone knows what a typical pbx system "sees" a link to Unity as, I would be grateful for an answer. I believe it is either a trunk, or a control line and a rs-232 link.
02-03-2003 12:12 PM
The way you connect the PBX to Unity is dependent on the type of PBX.
Unity supports some Dialogic analog cards and one T1 card.
To see the supported voice card in Unity 3.1, check the link -
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/prod_pre_installation_guide09186a008010a339.html#1287486
To get information on the PBX's supported by Unity and the integration type and components, check -
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/prod_pre_installation_guide09186a008010a339.html#1287610
For more details about a specific integration, check the configuration guide books that are available at -
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/ps2238/index.html
- Anil
Log in to Community
