Problem about CallMananger Installation!!!Urgent!!!
startryst
My hardware platform is below:
HP DL320 G2 P4 3060MHz, partnumber:336549-002
I install CallManager from CD-Rom, I insert the first CD(Hardware Detction),everything is OK,but when Hardware Detction pass,the following screen display:
===================7825H02===========================
Please insert the CD titled:
OS_Disk3
This process will continue automatically after
detecting the correct CD.
but when I insert the OS_Disk3, CD_rom read for a while, and then seems not responding and this screen continue to display...
dacole
Disk 3 is a DVD.
The Cisco build spec will show that you should have a DVD drive in this server.
It is possible to use a DVD drive on another pc to extract the files you need and then burn a CD with these files, but is probably simpler in the long term to just get a DVD drive in the CM server.
Dave
dacole
Disk 3 is a DVD.
Dave
Dave, Thanks a lot, my problem has been solved
