Problems in reinstalling agent deskyop
banalas_2
I had unistalled cisco desktop because it was logging me off frequently,
Try to reinsatll and its comes up installig screen and when i select desktop agent and try install , it gives me scren saying that agent desktop is installed. but nothing will be there in program files nor it is installed , please help me
adignan
Level 8
Level 8
E-meail me at adignan@berbee.com and I will send you the manual removal process for CAD.
